CC2642R: Power Saving with enabled Standby Policy: After 1 minute working we observe stopped data collection form the Sensor Controller and stopped timer(clock) - related activities
Part Number: CC2642R
Other Parts Discussed in Thread: SYSBIOS, CC2640, , ENERGYTRACE, CC2640R2F, SYSCONFIG
We use SimpleLink SDK CC13xx CC26xx version 6.10.0.29, and the TI tool CCS12:
We use POWER_SAVING in the Compiler predefined symbols, and we enabled Standby policy in the same way as it is enabled in the TI FW app simple_peripheral in the same SDK 6.10.0.29: parameter comparison attached in a screenshot:
When we start our Firmware in this Power saving mode, it works well for approx. 1 minute, after that the data collection from sensor controller stops, and some timer(clock) related activities stop working as well.
Details:
1) We use Sensor Controller RTC-driven Alert interrupts to the main processor in the MCU. These interrupts/events invoke ADC read operations.
2) For LED on/off scheduling we are using timer (clock) APIs from file utils.c.
Util_constructClock: it calls ti_sysbios_knl_Clock_construct
Util_startClock: it calls Clock_start(handle) that calls ti_sysbios_knl_Clock_start
Question 1 for TI: Is it possible that the failures in these 2 above areas 1) and 2) are caused by a problem in the communication between drivers and the Power manager?
According to: SimpleLink SDK Power Management: MSP432, MSP432E4, CC13xx/CC26xx, and CC32xx    User’s Guide (2019)
“1.3 Power Manager API
Driver development: A device driver communicates with the Power Manager to enable/disable access to its peripherals. “
The above spec is a bit old, Question 2 for TI: What is the best Power management TI spec to follow for our SDK CC13xx CC26xx version 6.10.0.29? We also used a TI spec (link below), but it is for a higher SDK version 6.40:
software-dl.ti.com/.../power.html
According to our battery usage measurements: our previous TI MCU CC2640 saved battery 2 times better compared to our new current prototype using 6.10.0.29: We also had POWER_SAVING there as a predefined symbol. We did not have .syscfg file with power policy options. We had the standby policy defined in a .cfg file, no longer used in the new SDK.
  • For our new MCU cc2642 I found a good sources of info:
    file:///C:/ti/simplelink_cc13xx_cc26xx_sdk_6_10_00_29/docs/drivers/doxygen/html/_power_8h.html#ti_drivers_Power_Examples_enable
    and file PowerCC26X2.h: they show several settings and the following steps to enable Power Policy:
    // Import Power Driver definitions
    // One-time initialization of Power manager
    // Enable power policy
    We have in our code the first two: #include for the drivers above, and the Power_init(). Looking at our FW app .cfg file: when I select the box: "Enable Policy", Power_enablePolicy() will be called, correct? I could not find other setup suggested in the TI docs.
    I tested and measured the initial period when all works OK on our device in Power saving mode: This period is: the first 3 min 35 secs during an established Bluetooth 5 connection. After this period the connection works OK for at least 1 hour and longer, and our I2C bus chip in the device works OK communicating with a mobile app, but our device RGB LED and events from the sensor controller get lost, i.e stop working at the end of this period.
    The CC2642R datasheet says:
    "SCLK_MF is an internal 2 MHz clock that is used by the Sensor Controller in low-power mode and also for internal power management circuitry. The SCLK_MF clock is always driven by the internal 2 MHz RC Oscillator (RCOSC_MF)."
    Will it help if I enable this symbol: USE_RCOSC  ? We inherited this code from TI examples:
    #ifdef USE_RCOSC
    // Set device's Sleep Clock Accuracy
    #if ( HOST_CONFIG & ( CENTRAL_CFG | PERIPHERAL_CFG ) )
    HCI_EXT_SetSCACmd(500);
    #endif // (CENTRAL_CFG | PERIPHERAL_CFG)
    RCOSC_enableCalibration();
    #endif // USE_RCOSC
    I tried but had RCOSC_enableCalibration rejected as unresolved symbol. It does not exist in the TI src code as part of the 6.10 SDK, that we are using.
    I should probably use the TI doc on link:
    Measuring CC13xx and CC26xx current consumption (Rev. D)
  • Hello Ludmil,
    Thanks for reaching out. Please help me with the following questions to assist you further:
    1. From what I understand, you have been using the CC2640 device and now migrating your code to CC2642 correct? or is this a new SW development for CC2642 based on an out of the box example? Have you checked this migration guide: https://software-dl.ti.com/simplelink/esd/simplelink_cc13xx_cc26xx_sdk/7.40.00.77/exports/docs/ble5stack/ble_user_guide/html/ble-stack-5.x-guide/porting-guides/cc2640r2_to_cc26x2.html
    2. Could you confirm if the entire sensor controller functionality also stops working after > 1 hour or the LEDs are the only ones failing here (previously I understood the ADC and comms (?) were also not working correctly)?
    3. If the standby policy is not enabled, will the issue reproduce?
    4. Regarding the RCOSC: The RCOSC build configuration no longer exists. To use RCOSC, add the following define in the project predefined symbols: USE_RCOSC.
    5. Do you know where is the extra power consumption (x2 more than 2640) coming from? Measuring CC13xx and CC26xx current consumption (Rev. D) can me help for for this. You can also leverage Energy Trace, especially EnergyTrace++ Instructions.
    BR,
    David
  • Hi David, Thanks very much for your reply.
    RE 1: Yes: we have an old CC2640 device, and we migrated most of our code to CC2642R. We used the TI migration guide and re-used bits from Simple Peripheral TI app.
    RE 2:
    The cc2642R datasheet says on p49: "In Standby mode, only the always-on (AON) domain is active. An external wake-up event, RTC event, or Sensor Controller event is required to bring the device back to active mode. …. All GPIOs are latched in standby mode."
    When the periodic RTC event comes, our SC code task runs and enables power to a voltage sensor and all LEDs by driving a digital output:
    gpioClearOutput(AUXIO_O_SG_POWER);
    After this our SC code reads the ADC to provide voltage sensor data to the MCU, and schedules its own execution:
    // Schedule the next execution <in ticks>  (1 sample period on the SC: default 100 ms)
    fwScheduleTask(1);
    All this works well in the following modes:
    - Standard “No Power policy enabled” mode,
    - In WFI Power Management mode,
    - In the first 1 to 3 mins in standby mode.
    After this variable period 1 to 3 mins in Power standby policy mode, we observe the following:
    1) My debug shows all LEDs turned off (red, blue, green), so the above SC gpio call has not been made by our SC code, or it has not enabled the power for the LEDs.
    2) No voltage sensor values are reported by the MCU over Bluetooth. I added debug code to the alert callback function: scTaskAlertCallback() to confirm that the alert interrupts from the SC to our MCU Firmware app have stopped. Also: If interrupts were available, our MCU code would read and report some ADC values: random or 0, but we see last value frozen (no more values present) in the mobile app still connected OK to our device.
    3) The Bluetooth connection is still in place and a separate IMU chip on our PCBA controlled only by the MCU (not the SC), is sending correct data to our mobile app.
    As a next debugging step, I can modify our SC task to remove the suspected dig output operation: gpioClearOutput(AUXIO_O_SG_POWER);
    RE your 3:
    If the standby policy is not enabled, will the issue reproduce?  Reply : No.
    RE your 4: Thanks for the info. As I indicated in my previous message: I tried the predefined this symbol: USE_RCOSC, but had RCOSC_enableCalibration rejected as unresolved symbol. It does not exist in the TI src code as part of the 6.10 SDK, that we are using:
    #ifdef USE_RCOSC
    #endif // USE_RCOSC
    RE your 5: "Do you know where is the extra power consumption (x2 more than 2640) coming from? " Reply: No, not measured yet, we will try. I looked at the doc you mentioned. We do not have such Power measurement equipment. Will check if it is possible to hire.
  • Hi David, I ran another test on the Sensor Controller: No digital outputs driven by our SC code, no ADC read, empty SC task code apart from only periodic RTC events (alert interrupts) generated from SC to the main MCU FW application core + our FW rescheduling itself. This setup generated successfully periodic alert interrupts for over 1 hour in MCU standby mode. This shows that these events can survive the standby mode alone, but they probably get stopped when all our SC code runs, because of a crash or a deadlock related to gpio calls to power up or down sensors, or an ADC-related FW call.
    Further debugging showed that the suspected Digital output operations:
    Enable then disable sensor power supply:
    gpioSetOutput(AUXIO_O_SG_POWER);
    stop the SC alert interrupts to the MCU, when added to the beginning of our empty (reduced) SC FW app that runs every sample period in Power standby mode (using external crystals, indicated via X in the .syscfg file).
    Our empty (reduced) FW app contains only: generate a periodic alert interrupt + reschedule our SC FW task by calling fwScheduleTask(1).
    I suspected a race condition between our gpio calls and the TI power manager operation: "enable digital io" during wakeup, so I added 2ms delay before our first dig out operation => the RTC alert interrupts were recovered and received by our MCU FW app.
    Next step: I kept this 2ms delay and restored all our FW code to run in Power policy mode => after 2 mins the alert interrupts disappeared similar to our first configuration in Standby mode.
    The .syscfg file setup used, is shown below:
    SC power setup shown below:
  • Hello Ludmil,
    Thanks for the extra information.
    Would it be possible to ask you to try to reproduce this issue using one of our out of the box examples considering the modifications you have done (utilizing drivers and sensor controller)? Also, are you using a custom board or an evaluation board from TI?
    BR,
    David.
  • Hi Dave, My experiments use configuration that is close to the standard TI environment:
    I use a custom board, but as I said in my first message: We use POWER_SAVING in the Compiler predefined symbols, and we enabled Standby policy in the same way as it is enabled in the TI FW app simple_peripheral in the same SDK 6.10.0.29: parameter comparison attached in a screenshot:
    During my experiments when the SC alert interrupts stop, I cannot reduce our SC FW app any further, I removed the main code. As I said above it only has:
    - 2x digio API calls
    - generate a periodic alert interrupt
    - reschedule our SC FW task by calling fwScheduleTask(1).
    Looking at the results, I think the issue is related to the 2x digio API calls in our SC code: they somehow cause the alert interrupt to stop in Standby mode.
    I may need to check the effect of the logic: We power up sensors and L
    EDs by setting the dig. output to 0: gpioClearOutput(AUXIO_O_SG_POWER);
    These APIs work reliably when Power Saving is not enabled, and when it is enabled in WFI mode. I will think again, but at present I cannot see how changing our main FW and custom board will resolve the problem.
  • Hello Ludmil,
    I see, please allow me until tomorrow to go through these findings and be able to take a more detailed look at it while also requesting help from the team experts in sensor controller because it seems it will be difficult to reproduce the issue on our side at the moment.
    BR,
    David.
  • Hi David, thanks a lot. I checked the usage of XOSC boxes in the syscfg power settings in the simple peripheral example TI app and our FW app:
    The settings are the same: We use and tick the same XOSC LF and HF options/boxes: i.e. external crystal oscillators are used on our PCBA, and on the simple peripheral Hardware:
  • Hello Ludmil,
    Thanks. I have discuss this further with the team and it does not seem like a known issue. Please help me with the following:
    1. If you use the simple_peripheral out of the box example with the minimal SC functionalities and same power saving setups, does this issue reproduces in your board?
    2. Are you running this test in debug mode?
    3. Have you had your custom board review by TI?
    4. Can you dump register data after the devices crashes to analyze some of the flags by connecting to the target in debug mode?
      1. AON_RTC register (SEC / SUBSEC / CH2CMP) - Page 1385 of TRM. This is done with the objective of checking if the RTC has been modified (if CH2CMP value is more than SEC and SUBSEC then that will evidence this scenario that will potentially cause issues.
      2. AUX_SCE --> CTL Register to see if CLK_EN is enabled - Page 1811 of TRM.
      3. AUX_SCE --> FETCHSTAT - Page 1812 of TRM.
      4. AUX_SCE --> CPUSTAT  - Page 1813 of TRM.
    5. Could you please try setting Default Power Mode to "Low Power"?
    BR,
    David.
  • Hi David, thanks a lot for the advice. RE your 5. Could you please try setting Default Power Mode to "Low Power"?    I will try today. I wanted to do this, but noticed in the SC Power help table that Low-power mode is not available for ADC (screenshot below), is this correct? We use ADC enable and select API calls in our SC FW code.
    RE your 1. If you use the simple_peripheral out of the box example with the minimal SC functionalities:
    I wanted to do this but I only have a simple peripheral project file that has no SC files and does not use the sensor controller:
    simple_peripheral_CC26X2R1_LAUNCHXL_tirtos_ccs
    If you know a link for a simple peripheral variant using SC code and provides the SC project, it will be useful.
    I will have to search for such project to see the SC source code.
  • Hi Daved, RE your 5. Try Default power mode set to "Low Power" for SC: I tried 2 variants with "Low Power" for SC: With this config shown below, I cannot connect over Bluetooth to our mobile app, or rarely connect, but the LEDs and main voltage sensor are not working:
    With this second possible variant I cannot connect over Bluetooth:
    RE: Your questions:
    2. Are you running this test in debug mode? LK: I am running in Release mode. WFI Power mode runs OK in Release mode and saves 32% more power compared to Release mode with no Power policy.
    3. Have you had your custom board review by TI? LK: The updated board with CC2642R has not been reviewed by TI. I cannot say this now for the original board with cc2640: it was designed 8 years ago.
  • Hi David, RE your 4.: dump register data:
    I found some TI code that reads these registers, so I think I can read them in our code after my detection of the missing alert interrupt from SC:
    // Read the current RTC value
    key = scifOsalEnterCriticalSection();
    sec = HWREG(AON_RTC_BASE + AON_RTC_O_SEC);
    subsec = HWREG(AON_RTC_BASE + AON_RTC_O_SUBSEC);
    ch2Cmp= HWREG(AON_RTC_BASE + AON_RTC_O_CH2CMP);
    RE your 2.: Are you running this test in debug mode?
    As I said I was running in Release mode, I switched to Debug mode now, I am trying to reproduce the issue and use the serial port to dump the RTC registers.
  • Hi David, please find attached an RTC log showing the loss of the SC alert interrupt event on the main MCU application code. The RTC registers are dumped every sample instant around the loss event, marked with "ERROR" in the log (sample period 100 ms). Time to the loss event is different on different runs: range 1-6 minutes, one run of 11 mins did not have the problem.
    Our FW app runs in debug mode, I am using the serial port for the debug messages. The app is in standby Power management mode. SC is in active mode, 'cos the low power mode did not work.
    I did a quick sanity check and could not find an apparent issue in the AON, but a specialist is needed to check.
    In case RTC is OK, I think one scenario to explain the events, could be: RTC ticks are OK. Our SC task crashes probably on digio 0 output attempt (this stops voltage from SC and PCBA LEDs, we see and know the dependency). Our SC task cannot re-schedule itself on the next RTC interrupt, and never runs again, so it never generates again the SC Alert interrupt to the main core. Our main FW finds no Alert. This matches the attached log.
    SC Alert OK AON_RTC_O_SEC  AON_RTC_O_SUBSEC  AON_RTC_O_CH2CMP:
    44   335675392   2894531
    44   765460480   2901084
    44   1195507712   2907637
    44   1625292800   2914190
    44   2055340032   2920743
    voltage: 3587
    44   2485125120   2927296
    44   2915172352   2933849
    44   3344957440   2940402
    44   3775004672   2946955
    44   4204789760   2953508
    45   339476480   2960061
    45   769523712   2966614
    45   1199308800   2973167
    45   1629224960   2979720
    45   2059272192   2986273
    45   2489188352   2992826
    45   2919104512   2999379
    45   3349020672   3005932
    45   3778805760   3012485
    45   4208852992   3019038
    46   343670784   3025591
    46   773586944   3032144
    46   1203372032   3038697
    46   1633288192   3045250
    46   2063204352   3051803
    46   2493120512   3058356
    46   2923036672   3064909
    46   3352952832   3071462
    46   3782868992   3078015
    46   4212785152   3084568
    47   347734016   3091121
    47   777650176   3097674
    47   1207435264   3104227
    47   1637351424   3110780
    47   2067136512   3117333
    47   2497052672   3123886
    47   2926968832   3130439
    47   3356884992   3136992
    47   3786801152   3143545
    47   4216717312   3150098
    48   351666176   3156651
    48   781582336   3163204
    48   1211498496   3169757
    48   1641414656   3176310
    48   2071199744   3182863
    48   2500984832   3189416
    48   2930900992   3195969
    48   3360817152   3202522
    48   3790733312   3209075
    48   4220649472   3215628
    49   355598336   3222181
    49   785514496   3228734
    49   1215430656   3235287
    49   1645346816   3241840
    49   2075131904   3248393
    49   2505179136   3254946
    49   2934964224   3261499
    49   3364618240   3268052
    49   3794534400   3274605
    49   4224450560   3281158
    50   359530496   3287711
    50   789446656   3294264
    50   1219362816   3300817
    50   1649278976   3307370
    50   2079195136   3313923
    50   2509111296   3320476
    50   2938896384   3327029
    50   3368812544   3333582
    50   3798597632   3340135
    50   4228513792   3346688
    51   363462656   3353241
    51   793378816   3359794
    51   1223294976   3366347
    51   1653211136   3372900
    51   2083127296   3379453
    51   2513043456   3386006
    51   2942959616   3392559
    51   3372875776   3399112
    51   3802791936   3405665
    51   4232577024   3412218
    52   367263744   3418771
    52   797179904   3425324
    52   1227227136   3431877
    52   1657012224   3438430
    52   2087059456   3444983
    voltage: 3588
    52   2516975616   3451536
    52   2946891776   3458089
    52   3376676864   3464642
    52   3806593024   3471195
    52   4236509184   3477748
    53   371458048   3484301
    53   801243136   3490854
    53   1231159296   3497407
    53   1661075456   3503960
    53   2090991616   3510513
    voltage: 3588
    53   2520907776   3517066
    53   2950823936   3523619
    53   3380740096   3530172
    53   3810656256   3536725
    53   4240572416   3543278
    54   375521280   3549831
    54   805437440   3556384
    54   1235222528   3562937
    54   1665007616   3569490
    54   2094792704   3576043
    54   2524708864   3582596
    54   2954625024   3589149
    54   3384672256   3595702
    54   3814457344   3602255
    54   4244504576   3608808
    55   379322368   3615361
    55   809369600   3621914
    55   1239285760   3628467
    55   1669070848   3635020
    55   2098855936   3641573
    voltage: 3589
    55   2528772096   3648126
    55   2958688256   3654679
    55   3388735488   3661232
    55   3818651648   3667785
    55   4248567808   3674338
    56   383516672   3680891
    56   813301760   3687444
    56   1243348992   3693997
    56   1673265152   3700550
    56   2103181312   3707103
    56   2533097472   3713656
    56   2962751488   3720209
    56   3392536576   3726762
    56   3822583808   3733315
    56   4252499968   3739868
    57   387448832   3746421
    57   817233920   3752974
    57   1247150080   3759527
    57   1677197312   3766080
    57   2107113472   3772633
    57   2537029632   3779186
    57   2966814720   3785739
    57   3396599808   3792292
    57   3826515968   3798845
    57   4256301056   3805398
    58   391380992   3811951
    58   821166080   3818504
    58   1251213312   3825057
    58   1681129472   3831610
    58   2111045632   3838163
    58   2540961792   3844716
    58   2970746880   3851269
    58   3400663040   3857822
    58   3830579200   3864375
    58   4260495360   3870928
    59   395313152   3877481
    59   825229312   3884034
    59   1255145472   3890587
    59   1685061632   3897140
    59   2114977792   3903693
    59   2544762880   3910246
    59   2974810112   3916799
    59   3404595200   3923352
    59   3834511360   3929905
    59   4264558592   3936458
    60   399376384   3943011
    60   829161472   3949564
    60   1259077632   3956117
    60   1688993792   3962670
    60   2119041024   3969223
    60   2548826112   3975776
    60   2978873344   3982329
    60   3408789504   3988882
    60   3838705664   3995435
    60   4268621824   4001988
    App Message received (BATTERY_MONITOR_EVENT)
    voltage: 3587
    61   403570688   4008541
    61   833486848   4015094
    61   1263403008   4021647
    61   1693057024   4028200
    61   2122973184   4034753
    61   2552889344   4041306
    61   2982805504   4047859
    61   3412590592   4054412
    61   3842637824   4060965
    61   4272553984   4067518
    62   407502848   4074071
    62   837287936   4080624
    62   1267335168   4087177
    62   1697251328   4093730
    62   2127036416   4100283
    voltage: 3588
    62   2556821504   4106836
    62   2986606592   4113389
    62   3416653824   4119942
    62   3846569984   4126495
    62   4276486144   4133048
    63   411435008   4139601
    63   841351168   4146154
    63   1271267328   4152707
    63   1701183488   4159260
    63   2131099648   4165813
    63   2561015808   4172366
    63   2990800896   4178919
    63   3420585984   4185472
    63   3850502144   4192025
    63   4280418304   4198578
    64   415367168   4205131
    64   845283328   4211684
    64   1275068416   4218237
    64   1705115648   4224790
    64   2135031808   4231343
    voltage: 3589
    64   2564947968   4237896
    64   2994864128   4244449
    64   3424649216   4251002
    64   3854303232   4257555
    64   4284350464   4264108
    65   419299328   4270661
    65   849215488   4277214
    65   1279131648   4283767
    65   1709047808   4290320
    65   2138963968   4296873
    65   2568880128   4303426
    65   2998796288   4309979
    65   3428581376   4316532
    65   3858628608   4323085
    65   4288413696   4329638
    66   423231488   4336191
    66   853147648   4342744
    66   1283063808   4349297
    66   1712979968   4355850
    66   2142896128   4362403
    voltage: 3588
    66   2572812288   4368956
    66   3002728448   4375509
    66   3432644608   4382062
    66   3862560768   4388615
    66   4292476928   4395168
    67   427294720   4401721
    67   857079808   4408274
    67   1286864896   4414827
    67   1717436416   4421380
    67   2147221504   4427933
    67   2577137664   4434486
    67   3007053824   4441039
    67   3436969984   4447592
    67   3866886144   4454145
    68   1835008   4460698
    68   431751168   4467251
    68   861667328   4473804
    68   1291583488   4480357
    68   1721499648   4486910
    68   2151284736   4493463
    68   2581069824   4500016
    68   3010985984   4506569
    68   3440902144   4513122
    68   3870818304   4519675
    69   5767168   4526228
    69   435683328   4532781
    69   865599488   4539334
    69   1295515648   4545887
    69   1725431808   4552440
    69   2155347968   4558993
    69   2585264128   4565546
    69   3015049216   4572099
    69   3444834304   4578652
    69   3874619392   4585205
    ERROR: LOST SC Alert AON_RTC_O_SEC  AON_RTC_O_SUBSEC  AON_RTC_O_CH2CMP:
    70   12976128   4591758
    70   442892288   4598311
    70   872808448   4604864
    70   1302724608   4611417
    70   1732771840   4617970
    70   2162688000   4624523
    70   2592473088   4631076
    70   3022389248   4637629
    70   3452174336   4644182
    70   3881959424   4650735
    71   16908288   4657288
    71   446824448   4663841
    71   876740608   4670394
    71   1306656768   4676947
    71   1736572928   4683500
    71   2166620160   4690053
    71   2596536320   4696606
    71   3026452480   4703159
    71   3456237568   4709712
    71   3886153728   4716265
    72   20971520   4722818
    72   450756608   4729371
    72   880672768   4735924
    72   1310588928   4742477
    72   1740505088   4749030
    72   2170421248   4755583
    voltage: 3588
    72   2600337408   4762136
    72   3030384640   4768689
    72   3460300800   4775242
    72   3890085888   4781795
    73   25034752   4788348
    73   454819840   4794901
    73   884604928   4801454
    73   1314521088   4808007
    73   1744437248   4814560
    73   2174353408   4821113
    voltage: 0
    73   2604400640   4827666
    73   3034316800   4834219
    73   3464232960   4840772
    73   3894280192   4847325
    74   29229056   4853878
    74   459145216   4860431
    74   888930304   4866984
    74   1318715392   4873537
    74   1748500480   4880090
    74   2178416640   4886643
    74   2608332800   4893196
    74   3038248960   4899749
    74   3468165120   4906302
    74   3898081280   4912855
    75   33161216   4919408
    75   463077376   4925961
    75   892993536   4932514
    75   1322778624   4939067
    75   1752694784   4945620
    75   2182479872   4952173
    voltage: 0
    75   2612264960   4958726
    75   3042181120   4965279
    75   3472228352   4971832
    75   3902144512   4978385
    76   37093376   4984938
    76   467009536   4991491
    76   896925696   4998044
    76   1326972928   5004597
    76   1756889088   5011150
    76   2186674176   5017703
    76   2616590336   5024256
    76   3046375424   5030809
    Stack Message received (GAP_MSG_EVENT), status: 0
    Gap Message received (GAP_LINK_TERMINATED_EVENT), status: 0, opcode: 6
  • syscfg and SC Power settings used when collecting RTC logs:
  • Another log attached: includes SC registers as well (decimal numbers are shown):
    Point of Error:
    23 2295857152 1543048
    AUX_SCE_O_CTL AUX_SCE_O_CPUSTAT:
    1 1281
    23 2729050112 1549601
    1 774
    17   982515712   1130209
    1   1281
    17   1412300800   1136762
    1   1281
    17   1842085888   1143315
    1   1281
    17   2272002048   1149868
    1   1281
    17   2701918208   1156421
    1   1281
    17   3131834368   1162974
    1   1281
    17   3561750528   1169527
    1   1281
    17   3991666688   1176080
    1   1281
    18   126615552   1182633
    1   1281
    18   556531712   1189186
    1   1281
    18   986447872   1195739
    1   1281
    18   1416364032   1202292
    1   1281
    18   1846280192   1208845
    1   1281
    18   2276065280   1215398
    1   1281
    18   2705850368   1221951
    1   1281
    18   3135766528   1228504
    1   1281
    18   3565682688   1235057
    1   1281
    18   3995598848   1241610
    1   1281
    19   130547712   1248163
    1   1281
    19   560463872   1254716
    1   1281
    19   990380032   1261269
    1   1281
    19   1420296192   1267822
    1   1281
    19   1850212352   1274375
    1   1281
    19   2280128512   1280928
    1   1281
    19   2709913600   1287481
    1   1281
    19   3139698688   1294034
    1   1281
    19   3569614848   1300587
    1   1281
    19   3999531008   1307140
    1   1281
    20   134479872   1313693
    1   1281
    20   564396032   1320246
    1   1281
    20   994312192   1326799
    1   1281
    20   1424228352   1333352
    1   1281
    20   1854144512   1339905
    1   1281
    20   2284060672   1346458
    1   1281
    20   2713976832   1353011
    1   1281
    20   3143892992   1359564
    1   1281
    20   3573678080   1366117
    1   1281
    20   4003463168   1372670
    1   1281
    21   138412032   1379223
    1   1281
    21   568328192   1385776
    1   1281
    21   998244352   1392329
    1   1281
    21   1428160512   1398882
    1   1281
    21   1858076672   1405435
    1   1281
    21   2287992832   1411988
    1   1281
    21   2717908992   1418541
    1   1281
    21   3147825152   1425094
    1   1281
    21   3577741312   1431647
    1   1281
    21   4007526400   1438200
    1   1281
    22   142344192   1444753
    1   1281
    22   572260352   1451306
    1   1281
    22   1002176512   1457859
    1   1281
    22   1432092672   1464412
    1   1281
    22   1862008832   1470965
    1   1281
    22   2291924992   1477518
    1   1281
    22   2721841152   1484071
    1   1281
    22   3151757312   1490624
    1   1281
    22   3581673472   1497177
    1   1281
    22   4011589632   1503730
    23   146538496   1510283
    1   1281
    23   576323584   1516836
    1   1281
    23   1006108672   1523389
    1   1281
    23   1436024832   1529942
    1   1281
    23   1865940992   1536495
    1   1281
    1   1281
    1   774
    23   3159097344   1556154
    1   774
    23   3589013504   1562707
    1   774
    23   4019060736   1569260
    1   774
    24   154009600   1575813
    1   774
    24   583794688   1582366
    1   774
    24   1013710848   1588919
    1   774
    24   1443495936   1595472
    1   774
    24   1873412096   1602025
    1   774
    24   2303328256   1608578
    1   774
    24   2733244416   1615131
    1   774
    24   3163291648   1621684
    1   774
    24   3593207808   1628237
    1   774
    24   4023123968   1634790
    1   774
    25   158072832   1641343
    1   774
    25   588120064   1647896
    1   774
    25   1018036224   1654449
    1   774
    25   1447952384   1661002
    1   774
    25   1877999616   1667555
    1   774
    25   2307784704   1674108
    1   774
    25   2737700864   1680661
    1   774
    25   3167617024   1687214
    1   774
    25   3597402112   1693767
    1   774
    25   4027318272   1700320
    1   774
    26   162267136   1706873
    1   774
    26   592314368   1713426
    1   774
    26   1022230528   1719979
    1   774
    26   1452146688   1726532
    1   774
    26   1882062848   1733085
    1   774
    26   2312110080   1739638
    1   774
    26   2742026240   1746191
    1   774
    26   3171942400   1752744
    1   774
    26   3601727488   1759297
    1   774
    26   4031643648   1765850
    1   774
    27   166461440   1772403
    1   774
    27   596377600   1778956
    1   774
    27   1026293760   1785509
    1   774
    27   1456340992   1792062
    1   774
    27   1886257152   1798615
    1   774
    27   2316173312   1805168
    1   774
    27   2746089472   1811721
    1   774
    27   3176005632   1818274
    1   774
    27   3606052864   1824827
    1   774
    27   4036100096   1831380
    1   774
    28   171180032   1837933
    1   774
    28   601096192   1844486
    1   774
    28   1031143424   1851039
    1   774
    28   1460928512   1857592
    1   774
    28   1890713600   1864145
    1   774
    28   2320629760   1870698
    1   774
    28   2750414848   1877251
    1   774
    28   3180462080   1883804
    1   774
    28   3610378240   1890357
    1   774
    28   4041080832   1896910
    1   774
    29   175505408   1903463
    1   774
    29   605552640   1910016
    1   774
    29   1035862016   1916569
    1   774
    29   1465516032   1923122
    1   774
    29   1895563264   1929675
    1   774
    29   2325479424   1936228
    1   774
    29   2755395584   1942781
    1   774
    29   3185442816   1949334
    1   774
    29   3615358976   1955887
    1   774
    29   4048027648   1962440
    1   774
    30   182845440   1968993
    1   774
    30   612106240   1975546
    1   774
    30   1041629184   1982099
    1   774
    30   1471152128   1988652
    1   774
    30   1900675072   1995205
    1   774
    30   2330198016   2001758
    1   774
    30   2759720960   2008311
    1   774
    30   3189506048   2014864
    1   774
    30   3619553280   2021417
    1   774
    30   4049731584   2027970
    1   774
    31   184811520   2034523
    1   774
    31   614465536   2041076
    1   774
    31   1044119552   2047629
    1   774
    31   1474297856   2054182
    1   774
    31   1904214016   2060735
    1   774
    31   2333736960   2067288
    1   774
    31   2763784192   2073841
    1   774
    31   3193700352   2080394
    1   774
    31   3623485440   2086947
    1   774
    31   4053401600   2093500
    1   774
    32   188350464   2100053
    1   774
    32   621019136   2113159
    1   774
    32   1050935296   2119712
    1   774
    32   1480327168   2126265
    1   774
    32   1909850112   2132818
    1   774
    32   2339504128   2139371
    1   774
    32   2769027072   2145924
    1   774
    32   3200122880   2152477
    1   774
    32   3630170112   2159030
    1   774
    32   4059430912   2165583
    1   774
    33   194248704   2172136
    1   774
    33   623509504   2178689
    1   774
    33   1053032448   2185242
    1   774
    33   1482555392   2191795
    1   774
    33   1912471552   2198348
    1   774
    33   2342256640   2204901
    1   774
    33   2772041728   2211454
    1   774
    33   3201957888   2218007
    1   774
    ForceSensor disabled!
    IMU disabled!
    Advertising Timer for 60 seconds started; device is advertising connection!
    Device Disconnected!
    !!! IMU Timer not enabled !!!
    Looks like the moment of Lost SC alert is random: can be even 23x100ms = 2.3 seconds after the Bluetooth connection established with our Mobile app. The app just displays data on the screen.
    I read this post and what you are experiencing is a code hang or an implementation issue. Also, I do not think the power management is causing your issue. By default if you use simple peripheral is set to low power, it will go to standby mode if there is no event.
    I did this project using CC2640R2F integrated sensor controller to simple peripheral. If you do the integration of sensor controller to the simple peripheral correctly, then there will be no problem.
    Soil Moisture Sensor Controller Project.
    -kel
  • H David,
    RE: your a: Here is my decoding of the RTC registers': From log 7 above: AON_RTC Seconds numbers seem to be  always correct, including and after the error. A new log entry comes every 100 ms.  Around the error we have all 10 RTC second indications: 23, then number 24 repeated 10 times correctly as well. I see no loss of RTC ticks. We have a battery measurement task
    RE: your b: Decoding of the log for
    CTL is 1 in all cases before and after the error: hence CLK_EN bit is set, clock always enabled.
    RE: your d: Here is my decoding of the SC CPUSTAT register, at the transition point:" all good" => "SC Alert to main core lost":
    Value 1281 decimal in SC CPUSTAT in all good cases "SC Alert OK" before the error:
    0101 0000 0001 => 2 bits set: HALTED and SLEEP
    Value 774 decimal in SC CPUSTAT in all bad cases: ERROR: ALERT to main LOST
    0011 0000 0110 => 2 bits set: HALTED and WEV
    RE: WEV: Is this some kind of "Write Event" to a register that gets frozen - did not complete? My log indicates that 774 remained in all subsequent samples, is this an SC crash for all tasks? I found that 3 secs after the ERROR: Alert interrupt missing, our other SC battery monitor task starts reporting 0 for battery voltage, previous value: almost full battery.
  • H David,
    I removed different parts of our SC task source code to debug and try to remove the failure, but in all experiments, I reproduced the loss of SC Alert interrupts at random moments in time after startup (ie. clicking play button in CCS debugger). The transitions to the error had the same CPUSTAT change: 1281 => 774.
    RE: WEV CPUSTAT bit: Is this some kind of "Write Event" to an SC register that gets frozen when the error occurs ? Write did not complete?
    My log indicates that 774 remained in all subsequent sample periods after the error occurred. Is this an SC crash for all tasks? I found that 3 secs after the ERROR: Alert interrupt missing, our other SC battery monitor task started reporting 0 for battery voltage, all previous values: almost full battery.
  • Hello Ludmil,
    Thank you for providing this information! I will review these findings today with the expert and come back at you as soon as possible.
    BR,
    David
  • Hello Ludmil,
    The WEV refers to the "Wait for EVent" instructions. These instructions are not used by the run-time framework. Could you please confirm if you are using any of procedure that waits for some event, which might not occur at all or has occurred in the past? I would suggest to take a look at the documentation of Sensor Controller Studio.
    Do you have a Texas Instruments point of contact that could help you share the sensor controller studio project file with us to take a quick look at?
    BR,
    David.
  • Hi David, Thanks a lot for the info. In the SC task code that fails: we have a 5ms timer call to delay our SC task code: fwDelayUs(5000);. I removed this timer call as an experiment yesterday, but I still had WEV bit set: log attached. We used to have a TI contact years ago, but in 2022 were asked to use the forum. We are based in San Diego, CA.
    1   1281
    41   405405696   2699484
    1   1281
    41   837156864   2706037
    1   1281
    500   1256718336   32787849
    1   774
    500   1686503424   32794402
    1   774
    500   2116419584   32800955
    1   774
    500   2546335744   32807508
    1   774
    500   2976251904   32814061
    1   774
    500   3406168064   32820614
    1   774
    voltage: 0
    500   3836084224   32827167
    1   774
    500   4266131456   32833720
    1   774
    501   401080320   32840273
    1   774
    501   830996480   32846826
    1   774
    501   1260781568   32853379
    1   774
    501   1690697728   32859932
    1   774
    501   2120482816   32866485
    1   774
    501   2550267904   32873038
    1   774
    501   2980184064   32879591
    1   774
    501   3410100224   32886144
    1   774
    501   3840016384   32892697
    1   774
    501   4269932544   32899250
    1   774
    502   404881408   32905803
    1   774
    502   834928640   32912356
    1   774
    502   1264844800   32918909
    1   774
    502   1694760960   32925462
    1   774
    502   2124546048   32932015
    1   774
    502   2554331136   32938568
    1   774
    502   2984116224   32945121
    1   774
    502   3414032384   32951674
    1   774
    voltage: 0
    502   3843948544   32958227
    1   774
    502   4273864704   32964780
    1   774
    503   408813568   32971333
    1   774
    503   838729728   32977886
    1   774
    503   1268776960   32984439
    1   774
    503   1698693120   32990992
    1   774
    503   2128609280   32997545
    1   774
    503   2558394368   33004098
    1   774
    503   2988310528   33010651
    1   774
    503   3418095616   33017204
    1   774
    503   3847880704   33023757
    1   774
    503   4277796864   33030310
    1   774
    504   412745728   33036863
    1   774
    504   842661888   33043416
    1   774
    504   1272578048   33049969
    1   774
    504   1702494208   33056522
    1   774
    504   2132541440   33063075
    1   774
    504   2562457600   33069628
    1   774
    504   2992373760   33076181
    1   774
    504   3422158848   33082734
    1   774
    voltage: 0
    504   3852206080   33089287
    1   774
    504   4281860096   33095840
    1   774
    505   416677888   33102393
    1   774
    505   846594048   33108946
    1   774
    505   1276510208   33115499
    1   774
    505   1706426368   33122052
    1   774
    505   2136473600   33128605
    1   774
    505   2566389760   33135158
    1   774
    505   2996305920   33141711
    1   774
    505   3426222080   33148264
    1   774
    505   3856007168   33154817
    1   774
    505   4285923328   33161370
    1   774
    506   420741120   33167923
    1   774
    506   850526208   33174476
    1   774
    506   1280573440   33181029
    1   774
    506   1710489600   33187582
    1   774
    506   2140405760   33194135
    1   774
    506   2570321920   33200688
    1   774
    506   3000238080   33207241
    1   774
    506   3430154240   33213794
    1   774
    voltage: 0
    506   3860201472   33220347
    1   774
    506   4290117632   33226900
    1   774
    507   424935424   33233453
    1   774
    507   854851584   33240006
    1   774
    507   1284636672   33246559
    1   774
    507   1714421760   33253112
    1   774
    507   2144337920   33259665
    1   774
    507   2574254080   33266218
    1   774
    507   3004170240   33272771
    1   774
    507   3434086400   33279324
    1   774
    voltage: 0
    507   3864133632   33285877
    1   774
    507   4294049792   33292430
    1   774
    508   428998656   33298983
    1   774
    508   858914816   33305536
    1   774
    508   1288699904   33312089
    1   774
    508   1718616064   33318642
    1   774
    508   2148401152   33325195
    1   774
    508   2578186240   33331748
    1   774
    508   3008102400   33338301
    1   774
    508   3438018560   33344854
    1   774
    508   3867934720   33351407
    1   774
    509   2883584   33357960
    1   774
    509   432799744   33364513
    1   774
    509   862846976   33371066
    1   774
    509   1292763136   33377619
    1   774
    509   1722679296   33384172
    1   774
    509   2152464384   33390725
    1   774
    509   2582249472   33397278
    1   774
    509   3012034560   33403831
    1   774
    509   3441950720   33410384
    1   774
    voltage: 0
    509   3871866880   33416937
    1   774
    510   6815744   33423490
    1   774
    510   436731904   33430043
    1   774
    510   866648064   33436596
    1   774
    510   1296695296   33443149
    1   774
    510   1726611456   33456255
    1   774
    510   2156527616   33462808
    1   774
    510   2586312704   33469361
    1   774
    510   3016228864   33475914
    1   774
    510   3446013952   33482467
    1   774
    510   3875799040   33489020
    1   774
    511   10747904   33495573
    1   774
    511   440664064   33502126
    1   774
    511   870580224   33508679
    1   774
    511   1300496384   33515232
    1   774
    511   1730412544   33521785
    1   774
    511   2160459776   33528338
    1   774
    511   2590375936   33534891
    1   774
    511   3020292096   33541444
    1   774
    511   3450077184   33547997
    1   774
    voltage: 0
    511   3879993344   33554550
    1   774
    512   14811136   33561103
    1   774
    512   444596224   33567656
    1   774
    512   874512384   33574209
    1   774
    512   1304428544   33580762
    1   774
    512   1734344704   33587315
    1   774
    512   2164260864   33593868
    1   774
    512   2594177024   33600421
    1   774
    512   3024224256   33606974
    1   774
    512   3454140416   33613527
    1   774
    512   3883925504   33620080
    1   774
    513   18874368   33626633
    1   774
    513   448659456   33633186
    1   774
    513   878444544   33639739
    1   774
    513   1308360704   33646292
    1   774
    513   1738276864   33652845
    1   774
    513   2168193024   33659398
    1   774
    513   2598109184   33665951
    1   774
    513   3028025344   33672504
    1   774
    513   3458072576   33679057
    1   774
    voltage: 0
    513   3888119808   33685610
    1   774
    514   22937600   33692163
    1   774
    514   452722688   33698716
    1   774
    514   882638848   33705269
    1   774
    514   1312423936   33711822
    1   774
    514   1742340096   33718375
    1   774
    514   2172256256   33724928
    1   774
    514   2602172416   33731481
    1   774
    514   3032088576   33738034
    1   774
    514   3462004736   33744587
    1   774
    514   3891920896   33751140
    1   774
    515   27000832   33757693
    1   774
    515   456916992   33764246
    1   774
    515   886833152   33770799
    1   774
    515   1316618240   33777352
    1   774
    515   1746534400   33783905
    1   774
    515   2176450560   33790458
    1   774
    515   2606235648   33797011
    1   774
    515   3036282880   33803564
    1   774
    515   3466199040   33810117
    1   774
    515   3895984128   33816670
    1   774
    516   30932992   33823223
    1   774
    516   460980224   33829776
    1   774
    516   890765312   33836329
    1   774
    516   1320812544   33842882
    1   774
    516   1750728704   33849435
    1   774
    516   2180513792   33855988
    1   774
    516   2610429952   33862541
    1   774
  • Hi Markel, thanks for the information. Our MCU is CC2642R. We ran successfully the same SC code for many months with no Power policy selected in the .syscfg file. The problem occurred when we selected Power Policy Standby in the .syscfg file. Can you provide a link to the simple peripheral source code including SC project and task that runs in standby mode?
    RE low-power mode:
    SC Power help table indicates that Low-power mode is not available for ADC (screenshot below), is this correct? We use ADC enable and select API calls in our SC FW code.
    As I indicated above in this post:
    Ludmil
  • I replaced the fwDelay() with a hard delay in the code and still observed the same error as before: frozen SC.
    //fwDelayUs(5000); //LK: removed
    for (U16 n = 0; n < 5000; n++) {
    sampleCounter = 0;
    I found in a TI SC doc that this delay API is independent of power modes:
    fwDelayUs
    Prototype: fwDelayUs(delay)
    Delays execution of the next line by the specified number of microseconds.
    To avoid busy waiting, the delay is implemented using the microsecond delay timer.
    The delay is independent of power modes (active and low-power) and switching between power modes.
    Parameter value(s)
    • delay : Delay value in microseconds (1-65534)
    I tried custom / dynamically switched on/off low-power mode on SC: same bad result.
    I tried no Power policy in CCS, .syscfg file: all good: Alerts coming well in Release FW mode on the main core.
    Is it possible that WEV is set because SC is waiting for an ACK from the main core, and this ACK does not come in standby mode ? I made an experiment that shows this:
    I left only Alert interrupt and self-reschedule in our SC code, tried longer and had the loss of the Alert on the main core with this very reduced SC code, which makes me think that the problem is no ACK from the main MCU core. SC waits on this event, main waits on Alert, so we have a deadlock. Our main core FW calls the API for Ack to SC, it works well in no power Manag. mode and in WFI Power Manag. mode. Maybe I can switch to custom Power mode on the main core and use this option.
    Ludmil
  • Hello Ludmil,
    It would seem you still have a procedure that waits for an event (WEV). Could you please help me with the following:
    1. Get the value after the devices crashes from AUX_SCE --> FETCHSTAT - Page 1812 of TRM.
    2. Look for that value (program address) inside the "sce.lst" listing file, which should be able to tell you which instruction is causing the WEV.
    3. Could you please confirm you are using the ADC only from the sensor controller and not MCU?
    4. Could you please share how you are reading the ADC buffer (code-snipped) would be helpful. There could be a risk of incorrect reading that generates the program to get stuck waiting for data that does not exists.
    BR,
    David.
  • Hi David, thanks a lot, I will work on 1. and 2. today.
    RE: 3 and 4:
    After the alert interrupt showing "data ready: on the main MCU core we only call: AUXADCAdjustValueForGainAndOffset(. . .) to read  .output and adjust value.
    LK: We use standard APIs that exist in TI manual:
    ADC — Sensor Controller Studio v2.9.0 CC13x2 CC26x2 documentation
    From the manual:
    // Select ADC input
    adcSelectGpioInput(AUXIO_A_SENSOR_OUTPUT);
    // Enable the ADC (fixed reference, 2.7 us sample time, manual trigger)
    adcEnableSync(ADC_REF_FIXED, ADC_SAMPLE_TIME_2P7_US, ADC_TRIGGER_MANUAL);
    // Sample the sensor and store the ADC value
    adcGenManualTrigger();
    adcReadFifo(output.adcValue);
    // Disable the ADC
    adcDisable();
    Our code sequence used successfully on the previous MCU CC2640 for more than 5 years:
    adcEnableSync(. . . )
    for (U16 n = 0; n < ADC_INPUT_COUNT; n++) {
    adcSelectGpioInput(Input[n]);
    U16 sample;
    adcReadFifo(sample);
    // Disable the ADC
    adcDisable();
  • I added more info in the following message
  • Hi David RE your 1. and 2:
    I ran a variant of our full SC code with dynamic power control (start/stop low-power mode). I decoded FETCHSTAT and found: The blocked place in the code is an ADC read at address 00e0. Instruction code 9990: input/read ADC. Looks like it is actually blocked by the preceding wev1 instruction. It shows the Program Counter at the next ADC input instruction:
                       ;? adcReadFifo(sample);
    00df ---- edb1 wev1         #WEVSEL_ADC_FIFO_NOT_EMPTY
    00e0 ---- 9990 in R1,       [#IOP_ANAIF_ADCFIFO]
    See attached below for all info:
    One possible root cause explanation: we are waiting for ADC input that does not happen because the previous dig output instruction did not supply power to our voltage sensor and also affected an OP-AMP circuit (low voltage impact confirmed by our HW engineer):
    Dig output not succeeded:
    ;? // Enable power supply
    ;? gpioClearOutput(AUXIO_O_SG_POWER);
    00d0 ---- 54bc iobclr #(20 & 0x7), [#(IOP_AIODIO0_GPIODOUT + (20 >> 3))]
    Another impact from the above dig output: The same power supply route supplies our LEDs, which are down every time when the error occurs.
    We can try to also confirm with an oscilloscope tomorrow.
    We defined this digio power pin only in our SC configuration, not in main MCU .syscfg file. The error however only occurs when Standpy policy is selected in the main FW syscfg file. All works OK in standard non-Power saving mode on the main MCU, and in WFI mode on the main MCU. CC2642 datasheet: I found this text on page 49: All GPIOs are latched in standby mode.
    This dig output is declared in our SC code section, for which I explicitly request active mode according to TI SC docs:
    // Enter active power mode
    pwrRequestAndWaitForActiveMode();
    The error also occurs if I remove this dynamic power control config in SC and the above API.
    Configs screenshots attached as well: .syscfg and SC: Power and Clock Settings.
  • I started using adcGetFifoStatus() and adcPopFifo() as a workaround. Will check a HW test point on the PCBA to confirm the above results.
  • Hello Ludmil,
    Is this workaround avoiding the issue of the SC stopping? Could you confirm you are not using the DAC module from sysconfig?
    Is there a way for you to share with us the scp file and the relevant code for the application?
    David.
  • Hi David,
    The workaround worked fine for 65 mins yesterday in Debug mode: no SC crashes. I am testing it in Release mode today and will let you know. I am using the attached .syscfg and SC power setups:
    I confirm that I am not using the DAC module from sysconfig: screenshot attached below:
  • Hello Ludmil,
    Understood. Let us know how it goes.
    BR,
    David.
  • Hi Dave, We hooked an oscilloscope and confirmed that my findings are correct for the dig output on SC: it stops working at the random time moment of freeze/deadlock of the SC:
    To remind you: Thiis output stops power to the voltage sensor and the LEDs. I reported at the time: We deadlock at WEV when we read the ADC, so I tried first: a more robust FIFO read: replaced adcReadFifo() with FIFO status read and check for status, retry the above Dig output...etc, all this helped a bit but the dig output problem was still there.
    Further changes and 2nd SC freeze:
    The TI SC help table is saying that ADC is not supported in low power mode, so I started calling in our SC code:
    then apply the dig output and do all operations, after which I switch to Low-power mode. On the main MCU code I also disable standby mode before any SC operations start, and re-enable it after all SC, BLE and other operations complete. I resolved my freeze on the dig output, but I got another 2nd type of freeze, see summary below in screenshots:
    Further change and 3rd freeze: very similar to the 2nd type:
    I replaced the above API pwrRequestAndWaitForActiveMode(); with the following menu selection that seems equivalent:
    This is a change in settings: Set "wake up active" option in the SC power settings. I also removed SCOSC calibration from .syscfg: This probably has no effect 'cos we use XOSC. I observed an SC crash after 33 mins:
    ERROR: LOST SC Alert  SEC  SUBSEC CH2CMP:
    2040  2230190080  0
    CTL  CPUSTAT  FETCHSTAT:
    1 1281 1879769235
    FETCHSTAT 1879769235 => Hex: 700B 0093
    lst file shows:
    PwrRequestAndWaitForActiveMode:
    ; Update Reference DAC clock divider before entering active mode
    0093 ---- 700b Id R7, #((ACTIVE_MODE_SCE_CLK_FREQ_MHZ / 2) - 1)
    0094 ---- fb96 out R7, [#IOP_ANAIF_DACSMPLCFG0]
    I think in freeze case 2 and 3 we have an output operation related to DAC (similar to my case1: dig output to control power).
    I think I resolved my old case 1, but I hit other "output" cases 2 and 3 in a different switching TI code area: how can I work in Active mode on SC 100% of the time without switching Active <=> Low-power mode ?
    I tried 4th case: no switch to low-power mode in our SC code, no dynamic Power control in SC settings: but had the same freeze as case 3, because I still have "wake up active" option in the SC power settings and it causes a switch in TI code in the same above PC=0093, op code 0093. 5th case using "init only" option in SC power settings also ends up freezing SC in this place:
    FETCHSTAT: 700B 0092
    0092 ---- 700b ld R7, #((ACTIVE_MODE_SCE_CLK_FREQ_MHZ / 2) - 1)
    0093 ---- fb96 out R7, [#IOP_ANAIF_DACSMPLCFG0]
    I tried power settings on SC: "Active" set for each task code block, with either option for default power mode: at every wake up / on init only: same result: frozen SC
    at the same point in the .lst file, shown below:
    0093 ---- 700b ld R7, #((ACTIVE_MODE_SCE_CLK_FREQ_MHZ / 2) - 1)
    I tried setting the frequencies for low-power and active mode the same at 2MHz (SC setting), but had the same problem in the TI code: frozen SC at the same address, opCode slightly different:
    0093 ---- 7000 ld R7, #((ACTIVE_MODE_SCE_CLK_FREQ_MHZ / 2) - 1)
    Maybe I need custom power mode in .syscfg? Or use constraints?
  • Hello Ludmil,
    To further be able to help you with this, would it be possible for you to try the following?
    1. Could you please confirm the issue occurs with default simple_peripheral and/or SCS ADC examples (either separately or together)?
    2. Do you have a TI CC2652XR1 LaunchPad you can use to reproduce the issue?
    3. Try with the latest F2 SDK (7.10.00.98 which has last update for SCS) and SCS (that has all patches applied).
    All this so that we can try to reproduce the issue on a TI environment that we can use a base reference.
    BR,
    David.
  • Hi David, Thanks for the advice and the doc link, I can try the SCS ADC examples with SDK 7.10, but this will take some time to port code / migrate from our current SDK 6.10. I checked the SC examples. I see that they are using RTC. I switched to Util_restartClock() before some recent code updates, so it will be faster to go back to RTC in my code first, test, and then look at SDK 7.10.
  • Hi David, I ran the RTC-driven test variant on our app but it ended up with a frozen SC and "wait for event" SC instruction when reading the ADC (same as the first issue).
    I had some compilation errors with SDK 7.10.00.98 and the TI Simple Peripheral app, I am trying to resolve them.
    I managed to run one successful test with our reduced, almost empty SC task that used to freeze when using dig Output, ADC channels, and delay:
    Using our current TI SimpleLink SDK CC13xx CC26xx version 6.10.0.29, I passed successfully an approx. 2 hours run of our reduced SC task that performs the same actions as described in the TI doc: Ultra-Low Power Sensing Applications With CC13x2/CC26x2, A.3 Wake Up and Sleep – Sensor Controller, plus 1 additional action:
    - Periodic SC task that reschedules itself in the Init block and the Execution block by calling: fwScheduleTask(1).
    - In the Execution block calls only:
    fwGenAlertInterrupt(); // Alert interrupt to Main MCU app - SC task's additional action compared to the above A.3
    fwScheduleTask(1); // Schedule the next execution <in ticks>, one tick 100 ms
    The main MCU app performed the same initialisation and start of the SC task as describe in section 6. of the TI doc: Ultra-Low Power Sensing Applications With CC13x2/CC26x2, A.3 Wake Up and Sleep – Sensor Controller, plus 4 additional actions:
    1) Ignore each Alert interrupt. This main MCU core app only does the standard acknowledge of this Alert interrupt:
    scifClearAlertIntSource();
    scifAckAlertEvents();
    2) Have the Power Management Policy enabled as "Standby" in .syscfg
    3) Connect to a mobile app running on a phone during the run
    4) Drive a periodic green device LED to indicate successful runs.
    Attached .syscfg Power section used during the successful test:
  • Hello Ludmil,
    Glad to hear the test with this reduced SC task works fine. Therefore can we say the issue is happening when enabling the ADC and using delays? Have you tried to add more of these features to see which one is generating the issue and narrow it even more? This is still being test in your custom board correct (no TI launchpad)?
    BR,
    David.
  • Hi David, Yes I did the testing described in my last post, with our custom board: no TI launchpad used.
    The SC power settings used were:
    RE: adding new features: I added the 2 digiIO operations: outputs that we had in the code previously to provide power to our voltage sensor. I am running the tests. Will let you know the results on Mon around lunch time.
  • Hi David, As agreed: I started adding lines of code to the SC main task to see when the errors will appear:
    1) PASSED a test after running in a 2 hr period OK: This is after adding 2 ON/OFF power operations via digital outputs: gpioClearOutput() and gpioSetOutput(), NO ADC operations used. Periodic Alerts OK gen-d by RTC clock. Our 2nd SC task to monitor battery voltage on the SC was commented out and not used. I did not call any APIs on the SC to explicitly change active <=>low power mode.
    Config:
    Power standby policy enabled on MCU main FW in Release mode (Debug mode also ran OK for around 34 mins and I stopped it, reg-s below).
    SC config: Default pwr mode Active, applied at every SC wake up. Debug trace repeatedly showed:
    SC Alert OK SEC SUBSEC CH2CMP:
    2497 62259200 163647064
    1 1281  1879769235
    1281 in Dec is: 0101 0000 0001  => bits set: HALTED  SLEEP (this is OK)
    2) 2nd test failed when I added ADC operations adcReadFifo(sample): read 4 voltages in total, to the 2 digital outputs: gpioClearOutput() and gpioSetOutput(),
    FAILED after 40 secs with device LEDs OFF and no voltage obtained, SC Periodic Alerts driven/gen-d by RTC clock. Our Battery code commented in SC. SC Periodic alerts stopped after 40 secs. Power standby policy again enabled on MCU main FW in Release mode. SC config: Default pwr mode Active, applied at every SC wake up.
    3) 3rd run same as 2nd run: Failed as above but in 25 mins. FW still in Release mode.
    4) Failed run: Same config as above in Debug mode with log trace: SC alerts lost after about 1 min, error log collected, debug info:
    91 2197946368 6000080
    1  774  2576351456
    774 decimal in SC CPUSTAT register, this is binary: 0011 0000 0110 => bits set: HALTED WEV
    FETCHSTAT has decimal 2576351456 => hex value: 999000E0
    SC code in the sce.lst file:
    ;? while(sampleCounter < ADC_MAXIMUM_SAMPLES) {
    /id0149:
    00dc ---- ea10 cmp R6, #16
    00dd ---- a606 bgeu /id0150
    ;? U16 sample;
    ;? adcGenManualTrigger();
    00de ---- 6491 iobset #0, [#IOP_ANAIF_ADCTRIG]
    I had this error weeks ago and reported it already in this post: CPUSTAT still shows WEV, so it seems to me that is a false "NON_EMPTY" event received by the SC code, that causes a read of an empty buffer and a deadlock/frozen SC state.
    5) Successful run: PASSED: I added my workaround to our SC code: polls via adcGetFifoStatus() and reads via adcPopFifo(sample). I made this according to the TI docs: manual ADCFIFO status check. I re-ran with this workaround and had a good run for 1hr 30 mins, main FW in DEBUG mode. Same config as the prev. run, only changed the read FIFO APIs.
    I will do more runs and will carry on adding our battery monitor.
  • Hi David, Thanks for your support.
    We ran more tests, and we think we have a stable Power standby mode on CC2642: no loss of periodic SC alert interrupts. The solution to a stopped and frozen SC because of a blocked TI API adcReadFifo(), seemed to be: instead of adcReadFifo(), poll via adcGetFifoStatus() and read via adcPopFifo(). Such scenario is discussed in the TI SC API documentation.
    As shown above, SC was frozen in the code:
    With our latest configurations, no other scenarios of frozen SC were observed.
