Other Parts Discussed in Thread: LP-XDS110ET,
I'm attempting to run Energy Trace on a CC2340R5 through CCS 12.7.1.00001. When I try to run it in standalone mode nothing happens after the loading dialog. I've attached my configuration and the error log. I was able to get it to work a couple of times after a reinstallation, but for some reason it stops working after a few times. From the error logs something is causing Energy Trace to crash.config.txt
!SESSION 2024-07-09 13:41:09.072 -----------------------------------------------
eclipse.buildId=4.23.0.I20220308-0310
java.version=11.0.13
java.vendor=Eclipse Adoptium
BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=en_US
Framework arguments: -product com.ti.ccstudio.branding.product
Command-line arguments: -os win32 -ws win32 -arch x86_64 -product com.ti.ccstudio.branding.product
!ENTRY com.ti.common.core 1 0 2024-07-09 13:41:43.871
!MESSAGE path=ccs_base/DebugServer
!MESSAGE debugServerDir=C:/ti/ccs1271/ccs/ccs_base/DebugServer
!ENTRY com.ti.dbgtrc.webapp.CloudTraceInterface 0 0 2024-07-09 13:41:45.199
!MESSAGE constructor
!MESSAGE done with directories
!MESSAGE loading ti_logger
!ENTRY com.ti.dbgtrc.webapp.CloudTraceInterface 0 0 2024-07-09 13:41:45.215
!MESSAGE Platform os: win32
!MESSAGE loading cToolsIF
!MESSAGE loading TraceFactory
!MESSAGE loading sqlite3
!MESSAGE loading CloudTrace
!MESSAGE CloudTrace interface loaded
!ENTRY org.eclipse.equinox.event 4 0 2024-07-09 13:41:48.172
!MESSAGE Exception while dispatching event org.osgi.service.event.Event [topic=org/eclipse/e4/ui/model/application/ApplicationElement/tags/ADD] {ChangedElement=org.eclipse.e4.primaryDataStack=org.eclipse.e4.ui.model.application.ui.basic.impl.PartStackImpl@eb09112 (tags: [org.eclipse.e4.primaryDataStack, EditorStack, active, Maximized], contributorURI: null) (widget: CTabFolder {} [layout=org.eclipse.swt.custom.CTabFolderLayout@4daa53e0], renderer: org.eclipse.e4.ui.workbench.renderers.swt.StackRenderer@5bfeb9ba, toBeRendered: true, onTop: false, visible: true, containerData: null, accessibilityPhrase: null), org.eclipse.e4.data={ChangedElement=org.eclipse.e4.primaryDataStack=org.eclipse.e4.ui.model.application.ui.basic.impl.PartStackImpl@eb09112 (tags: [org.eclipse.e4.primaryDataStack, EditorStack, active, Maximized], contributorURI: null) (widget: CTabFolder {} [layout=org.eclipse.swt.custom.CTabFolderLayout@4daa53e0], renderer: org.eclipse.e4.ui.workbench.renderers.swt.StackRenderer@5bfeb9ba, toBeRendered: true, onTop: false, visible: true, containerData: null, accessibilityPhrase: null), AttName=tags, EventType=ADD, Position=3, Widget=CTabFolder {} [layout=org.eclipse.swt.custom.CTabFolderLayout@4daa53e0], NewValue=Maximized}, AttName=tags, EventType=ADD, Position=3, Widget=CTabFolder {} [layout=org.eclipse.swt.custom.CTabFolderLayout@4daa53e0], NewValue=Maximized} to handler org.eclipse.e4.ui.internal.di.UIEventObjectSupplier$UIEventHandler@6b989889
!STACK 0
org.eclipse.e4.core.di.InjectionException: java.lang.IllegalArgumentException:
at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:68)
at org.eclipse.swt.widgets.Synchronizer.syncExec(Synchronizer.java:236)
at org.eclipse.ui.internal.UISynchronizer.syncExec(UISynchronizer.java:133)
at org.eclipse.swt.widgets.Display.syncExec(Display.java:4779)
at org.eclipse.e4.ui.workbench.swt.DisplayUISynchronize.syncExec(DisplayUISynchronize.java:34)
at org.eclipse.e4.ui.internal.di.UIEventObjectSupplier$UIEventHandler.handleEvent(UIEventObjectSupplier.java:64)
at org.eclipse.equinox.internal.event.EventHandlerWrapper.handleEvent(EventHandlerWrapper.java:205)
at org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:203)
at org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:1)
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:234)
at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:151)
at org.eclipse.equinox.internal.event.EventAdminImpl.dispatchEvent(EventAdminImpl.java:133)
at org.eclipse.equinox.internal.event.EventAdminImpl.sendEvent(EventAdminImpl.java:75)
at org.eclipse.equinox.internal.event.EventComponent.sendEvent(EventComponent.java:44)
at org.eclipse.e4.ui.services.internal.events.EventBroker.send(EventBroker.java:55)
at org.eclipse.e4.ui.internal.workbench.UIEventPublisher.notifyChanged(UIEventPublisher.java:63)
at org.eclipse.emf.common.notify.impl.BasicNotifierImpl.eNotify(BasicNotifierImpl.java:424)
at org.eclipse.emf.ecore.util.EcoreEList.dispatchNotification(EcoreEList.java:249)
at org.eclipse.emf.common.notify.impl.NotifyingListImpl.addUnique(NotifyingListImpl.java:304)
at org.eclipse.emf.common.util.AbstractEList.add(AbstractEList.java:304)
at org.eclipse.ui.internal.WorkbenchIntroManager.setIntroStandby(WorkbenchIntroManager.java:200)
at org.eclipse.ui.internal.WorkbenchIntroManager.showIntro(WorkbenchIntroManager.java:139)
at org.eclipse.ui.application.WorkbenchWindowAdvisor.openIntro(WorkbenchWindowAdvisor.java:188)
at org.eclipse.ui.internal.ide.application.IDEWorkbenchWindowAdvisor.openIntro(IDEWorkbenchWindowAdvisor.java:573)
at org.eclipse.ui.internal.WorkbenchWindow.setup(WorkbenchWindow.java:933)
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
at java.base/java.lang.reflect.Method.invoke(Unknown Source)
at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:58)
at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:995)
at org.eclipse.e4.core.internal.di.InjectorImpl.internalInject(InjectorImpl.java:140)
at org.eclipse.e4.core.internal.di.InjectorImpl.inject(InjectorImpl.java:96)
at org.eclipse.e4.core.contexts.ContextInjectionFactory.inject(ContextInjectionFactory.java:83)
at org.eclipse.ui.internal.Workbench.createWorkbenchWindow(Workbench.java:1469)
at org.eclipse.ui.internal.StandardTrim.createStatusLine(StandardTrim.java:118)
at org.eclipse.ui.internal.StandardTrim.createWidget(StandardTrim.java:48)
at org.eclipse.e4.core.internal.di.InjectorImpl.internalMake(InjectorImpl.java:403)
at org.eclipse.e4.core.internal.di.InjectorImpl.make(InjectorImpl.java:344)
at org.eclipse.e4.core.contexts.ContextInjectionFactory.make(ContextInjectionFactory.java:227)
at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.createFromBundle(ReflectionContributionFactory.java:94)
at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.doCreate(ReflectionContributionFactory.java:60)
at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.create(ReflectionContributionFactory.java:37)
at org.eclipse.e4.ui.workbench.renderers.swt.ToolControlRenderer.createWidget(ToolControlRenderer.java:129)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createWidget(PartRenderingEngine.java:995)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:659)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:763)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$2.run(PartRenderingEngine.java:728)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:45)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createGui(PartRenderingEngine.java:712)
at org.eclipse.e4.ui.workbench.renderers.swt.SWTPartRenderer.processContents(SWTPartRenderer.java:72)
at org.eclipse.e4.ui.workbench.renderers.swt.TrimBarRenderer.processContents(TrimBarRenderer.java:109)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:673)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$1.run(PartRenderingEngine.java:544)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createGui(PartRenderingEngine.java:528)
at org.eclipse.e4.ui.workbench.renderers.swt.WBWRenderer.processContents(WBWRenderer.java:680)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$5.run(PartRenderingEngine.java:1083)
at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:338)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1046)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:155)
at org.eclipse.ui.internal.Workbench.lambda$3(Workbench.java:644)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:551)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:156)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:152)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:203)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:136)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:104)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:401)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:255)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:659)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:596)
at org.eclipse.equinox.launcher.Main.run(Main.java:1467)
Caused by: java.lang.IllegalArgumentException:
at org.eclipse.core.runtime.Assert.isLegal(Assert.java:66)
at org.eclipse.core.runtime.Assert.isLegal(Assert.java:50)
at org.eclipse.e4.ui.internal.workbench.ModelServiceImpl.findElementsRecursive(ModelServiceImpl.java:175)
at org.eclipse.e4.ui.internal.workbench.ModelServiceImpl.findElements(ModelServiceImpl.java:437)
at org.eclipse.e4.ui.internal.workbench.ModelServiceImpl.findElements(ModelServiceImpl.java:430)
at org.eclipse.e4.ui.workbench.addons.minmax.MinMaxAddon.findValidElementsToMinimize(MinMaxAddon.java:855)
at org.eclipse.e4.ui.workbench.addons.minmax.MinMaxAddon.getElementsToMinimize(MinMaxAddon.java:798)
at org.eclipse.e4.ui.workbench.addons.minmax.MinMaxAddon.maximize(MinMaxAddon.java:734)
at org.eclipse.e4.ui.workbench.addons.minmax.MinMaxAddon.subscribeTopicTagsChanged(MinMaxAddon.java:408)
at jdk.internal.reflect.GeneratedMethodAccessor16.invoke(Unknown Source)
... 89 more
!ENTRY com.ti.ccstudio.project.ui.webcontent 1 0 2024-07-09 13:41:48.482
!MESSAGE CCS HTTP adapter started! [ccs.port:50131] - Open 'http://localhost:50131/ide' in web browser to see listing of available APIs...
!ENTRY com.ti.ccstudio.ui 1 0 2024-07-09 13:41:49.886
!MESSAGE CCS IDE session started!
CCS build: 12.7.1.00001
CCS location: C:/ti/ccs1271/ccs
Workspace location: C:/Users/****************/CCS_workspaces/setup_testing_v12-0-7
!ENTRY org.eclipse.equinox.p2.repository 2 0 2024-07-09 13:41:51.601
!MESSAGE Using unsafe http transport to retrieve http://software-dl.ti.com/dsps/dsps_public_sw/sdo_ccstudio/codegen/Updates/p2win32/artifacts.xml.xz, see CVE-2021-41033. Consider using https instead.
!ENTRY org.eclipse.equinox.p2.repository 2 0 2024-07-09 13:41:52.112
!MESSAGE Using unsafe http transport to retrieve http://software-dl.ti.com/dsps/dsps_public_sw/sdo_ccstudio/codegen/Updates/p2linux/artifacts.xml.xz, see CVE-2021-41033. Consider using https instead.
!ENTRY org.eclipse.equinox.p2.repository 2 0 2024-07-09 13:41:52.631
!MESSAGE Using unsafe http transport to retrieve http://software-dl.ti.com/dsps/dsps_public_sw/sdo_ccstudio/codegen/Updates/p2mac/artifacts.xml.xz, see CVE-2021-41033. Consider using https instead.
!ENTRY org.eclipse.equinox.p2.repository 2 0 2024-07-09 13:41:53.054
!MESSAGE Using unsafe http transport to retrieve http://software-dl.ti.com/dsps/dsps_public_sw/sdo_ccstudio/codegen/Updates/p2win32/content.xml.xz, see CVE-2021-41033. Consider using https instead.
!ENTRY org.eclipse.equinox.p2.repository 2 0 2024-07-09 13:41:54.574
!MESSAGE Using unsafe http transport to retrieve http://software-dl.ti.com/dsps/dsps_public_sw/sdo_ccstudio/codegen/Updates/p2linux/content.xml.xz, see CVE-2021-41033. Consider using https instead.
!ENTRY org.eclipse.equinox.p2.repository 2 0 2024-07-09 13:41:55.918
!MESSAGE Using unsafe http transport to retrieve http://software-dl.ti.com/dsps/dsps_public_sw/sdo_ccstudio/codegen/Updates/p2mac/content.xml.xz, see CVE-2021-41033. Consider using https instead.
!ENTRY org.eclipse.equinox.p2.repository 2 0 2024-07-09 13:41:57.075
!ENTRY org.eclipse.equinox.p2.repository 2 0 2024-07-09 13:41:57.373
!ENTRY org.eclipse.equinox.p2.repository 2 0 2024-07-09 13:41:57.623
!ENTRY org.eclipse.equinox.p2.repository 2 0 2024-07-09 13:41:57.888
!MESSAGE Using unsafe http transport to retrieve http://software-dl.ti.com/dsps/dsps_public_sw/sdo_ccstudio/CCSv5/Updates/, see CVE-2021-41033. Consider using https instead.
!ENTRY org.eclipse.equinox.p2.repository 2 0 2024-07-09 13:41:58.357
!ENTRY org.eclipse.equinox.p2.repository 2 0 2024-07-09 13:41:58.827
!ENTRY org.eclipse.equinox.p2.repository 2 0 2024-07-09 13:41:59.296
!ENTRY org.eclipse.equinox.p2.repository 2 0 2024-07-09 13:41:59.577
!ENTRY org.eclipse.equinox.p2.repository 2 0 2024-07-09 13:42:00.529
!ENTRY org.eclipse.equinox.p2.repository 2 0 2024-07-09 13:42:00.811
!ENTRY org.eclipse.equinox.p2.repository 2 0 2024-07-09 13:42:01.045
!ENTRY org.eclipse.equinox.p2.repository 2 0 2024-07-09 13:42:01.451
!ENTRY org.eclipse.cdt.core 1 0 2024-07-09 13:42:44.470
!MESSAGE Indexed 'basic_ble_LP_EM_CC2340R5_freertos_ticlang' (30 sources, 130 headers) in 2.34 sec: 14,706 declarations; 18,706 references; 158 unresolved inclusions; 20 syntax errors; 2,463 unresolved names (6.9%)
!ENTRY org.eclipse.equinox.p2.core 4 0 2024-07-09 13:42:57.497
!MESSAGE Provisioning exception
!STACK 1
org.eclipse.equinox.p2.core.ProvisionException: No repository found at https://software-dl.ti.com/ccs/esd/CCSv12/Updates/CCS12.0.0.00009_update.
at org.eclipse.equinox.internal.p2.repository.helpers.AbstractRepositoryManager.fail(AbstractRepositoryManager.java:405)
at org.eclipse.equinox.internal.p2.repository.helpers.AbstractRepositoryManager.loadRepository(AbstractRepositoryManager.java:709)
at org.eclipse.equinox.internal.p2.metadata.repository.MetadataRepositoryManager.loadRepository(MetadataRepositoryManager.java:110)
at org.eclipse.equinox.internal.p2.metadata.repository.MetadataRepositoryManager.loadRepository(MetadataRepositoryManager.java:105)
at org.eclipse.equinox.internal.p2.metadata.repository.CompositeMetadataRepository.addChild(CompositeMetadataRepository.java:171)
at org.eclipse.equinox.internal.p2.metadata.repository.CompositeMetadataRepository.<init>(CompositeMetadataRepository.java:113)
at org.eclipse.equinox.internal.p2.metadata.repository.CompositeMetadataRepositoryFactory.load(CompositeMetadataRepositoryFactory.java:124)
at org.eclipse.equinox.internal.p2.metadata.repository.MetadataRepositoryManager.factoryLoad(MetadataRepositoryManager.java:63)
at org.eclipse.equinox.internal.p2.repository.helpers.AbstractRepositoryManager.loadRepository(AbstractRepositoryManager.java:787)
at org.eclipse.equinox.internal.p2.repository.helpers.AbstractRepositoryManager.loadRepository(AbstractRepositoryManager.java:685)
at org.eclipse.equinox.internal.p2.updatechecker.UpdateChecker.getAvailableRepositories(UpdateChecker.java:152)
at org.eclipse.equinox.internal.p2.updatechecker.UpdateChecker.checkForUpdates(UpdateChecker.java:130)
at org.eclipse.equinox.internal.p2.updatechecker.UpdateChecker$UpdateCheckThread.run(UpdateChecker.java:78)
!SUBENTRY 1 org.eclipse.equinox.p2.metadata.repository 4 1000 2024-07-09 13:42:57.497
!MESSAGE No repository found at https://software-dl.ti.com/ccs/esd/CCSv12/Updates/CCS12.0.0.00009_update.
!ENTRY org.eclipse.ui 2 2 2024-07-09 13:43:21.738
!MESSAGE com.ti.ccstudio.system.setup.ui.views.TargetConfigurationView: Deprecated relationship "fast" should be converted to "stack".
!ENTRY com.ti.ccstudio.debug 1 0 2024-07-09 13:43:25.581
!MESSAGE DS_ERROR: CS_DAP_0: Error initializing emulator: (Error -260 @ 0x0) An attempt to connect to the XDS110 failed. The cause may be one or more of: no XDS110 is connected, invalid firmware update, invalid XDS110 serial number, or faulty USB cable. The firmware and serial number may be updated using the xdsdfu utility found in the .../ccs_base/common/uscif/xds110 directory of your installation. View the XDS110SupportReadMe.pdf file there for instructions. (Emulation package 12.7.0.00130)
!ENTRY com.ti.ccstudio.debug 1 0 2024-07-09 13:43:25.644
!MESSAGE DS_ERROR: Error initializing emulator:
(Error -260 @ 0x0)
!ENTRY org.eclipse.equinox.p2.metadata.repository 4 1000 2024-07-09 13:43:26.791
!MESSAGE No repository found at file:/C:/Users/TEMP.SCPDOMAIN/AppData/Local/Temp/ccs_efad0a58-dad6-4d0e-661b-8b6d3d3a3c3d/INSTALLER.
!ENTRY com.ti.ccstudio.debug 1 0 2024-07-09 13:43:28.733
(Error -260 @ 0x0)
!ENTRY com.ti.ccstudio.debug 1 0 2024-07-09 13:43:53.441
!MESSAGE DS_ERROR: Warning:
A firmware update is required for the XDS110 probe. The current firmware is version 3.0.0.28. The probe must be upgraded to firmware version 3.0.0.29 to be compatible with this software.
Click the "Update" button to update the firmware.
DO NOT UNPLUG THE DEBUG PROBE DURING THE UPDATE.
!ENTRY org.eclipse.ui.ide 4 4 2024-07-09 14:57:47.110
!MESSAGE Not properly disposed SWT resource
!STACK 0
java.lang.Error: SWT Resource was not properly disposed
at org.eclipse.swt.graphics.Resource.initNonDisposeTracking(Resource.java:172)
at org.eclipse.swt.graphics.Resource.<init>(Resource.java:120)
at org.eclipse.swt.graphics.Image.<init>(Image.java:683)
at org.eclipse.jface.resource.URLImageDescriptor.createImage(URLImageDescriptor.java:275)
at org.eclipse.jface.resource.ImageDescriptor.createImage(ImageDescriptor.java:290)
at org.eclipse.jface.resource.ImageDescriptor.createImage(ImageDescriptor.java:268)
at com.ti.dvt.datamodel.ui.actions.DataAction.exportDataFromNonTable(DataAction.java:617)
at com.ti.dvt.datamodel.ui.actions.DataAction.exportData(DataAction.java:584)
at com.ti.dvt.datamodel.ui.actions.DataAction.saveAs(DataAction.java:494)
at com.ti.dvt.datamodel.ui.actions.DataAction.run(DataAction.java:93)
at org.eclipse.ui.internal.PluginAction.runWithEvent(PluginAction.java:239)
at org.eclipse.jface.action.ActionContributionItem.handleWidgetSelection(ActionContributionItem.java:580)
at org.eclipse.jface.action.ActionContributionItem.lambda$4(ActionContributionItem.java:414)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:89)
at org.eclipse.swt.widgets.Display.sendEvent(Display.java:4243)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1063)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4060)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3632)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$5.run(PartRenderingEngine.java:1155)
!ENTRY org.eclipse.ui.ide 4 4 2024-07-09 14:58:52.571
!STACK 0
!ENTRY org.eclipse.ui.ide 4 4 2024-07-09 15:05:17.478
!STACK 0
!ENTRY org.eclipse.ui.ide 4 4 2024-07-09 15:06:41.198
!STACK 0
at org.eclipse.swt.graphics.Image.<init>(Image.java:537)
at org.eclipse.jface.viewers.ColorCellEditor.updateContents(ColorCellEditor.java:235)
at org.eclipse.jface.viewers.DialogCellEditor.doSetValue(DialogCellEditor.java:311)
at org.eclipse.jface.viewers.CellEditor.setValue(CellEditor.java:853)
at com.ti.dvt.ui.internal.DynamicCellEditor.doSetValue(DynamicCellEditor.java:127)
at org.eclipse.jface.viewers.EditingSupport.initializeCellEditorValue(EditingSupport.java:103)
at org.eclipse.jface.viewers.ColumnViewerEditor.activateCellEditor(ColumnViewerEditor.java:203)
at org.eclipse.jface.viewers.ColumnViewerEditor.handleEditorActivationEvent(ColumnViewerEditor.java:435)
at org.eclipse.jface.viewers.ColumnViewer.triggerEditorActivationEvent(ColumnViewer.java:680)
at org.eclipse.jface.viewers.ColumnViewer.handleMouseDown(ColumnViewer.java:655)
at org.eclipse.jface.viewers.ColumnViewer$1.mouseDown(ColumnViewer.java:100)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:196)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:823)
at org.eclipse.jface.window.Window.open(Window.java:799)
at com.ti.dvt.ui.views.core.ShowPropertyAction.show(ShowPropertyAction.java:62)
at com.ti.dvt.ui.views.core.ShowPropertyAction.run(ShowPropertyAction.java:38)
at com.ti.dvt.ui.views.AbstractViewActionDelegate.runWithEvent(AbstractViewActionDelegate.java:56)
at org.eclipse.ui.internal.PluginAction.runWithEvent(PluginAction.java:229)
!ENTRY org.eclipse.equinox.p2.core 4 0 2024-07-09 15:13:03.659
!STACK 1
org.eclipse.equinox.p2.core.ProvisionException: No repository found at file:/C:/Users/TEMP.SCPDOMAIN/AppData/Local/Temp/ccs_efad0a58-dad6-4d0e-661b-8b6d3d3a3c3d/INSTALLER.
at org.eclipse.equinox.p2.ui.LoadMetadataRepositoryJob.doLoad(LoadMetadataRepositoryJob.java:126)
at org.eclipse.equinox.p2.ui.LoadMetadataRepositoryJob.runModal(LoadMetadataRepositoryJob.java:110)
at org.eclipse.equinox.internal.p2.ui.sdk.PreloadingRepositoryHandler$1.runModal(PreloadingRepositoryHandler.java:84)
at org.eclipse.equinox.p2.operations.ProvisioningJob.run(ProvisioningJob.java:188)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:63)
!SUBENTRY 1 org.eclipse.equinox.p2.metadata.repository 4 1000 2024-07-09 15:13:03.659
!ENTRY org.eclipse.cdt.core 1 0 2024-07-09 15:50:17.548
!MESSAGE Indexed 'basic_ble_profiles_LP_EM_CC2340R5_freertos_ticlang' (41 sources, 139 headers) in 1.44 sec: 15,913 declarations; 23,188 references; 170 unresolved inclusions; 20 syntax errors; 2,692 unresolved names (6.4%)
!ENTRY org.eclipse.ui 4 0 2024-07-09 16:16:21.193
!MESSAGE Unhandled event loop exception
!STACK 0
java.lang.NullPointerException
at com.ti.dvt.energytrace.views.DSManager$DSDialog.createDialogArea(DSManager.java:519)
at org.eclipse.jface.dialogs.Dialog.createContents(Dialog.java:767)
at org.eclipse.jface.window.Window.create(Window.java:431)
at org.eclipse.jface.dialogs.Dialog.create(Dialog.java:1094)
at org.eclipse.jface.window.Window.open(Window.java:788)
at com.ti.dvt.energytrace.views.DSManager$DSDialog.open(DSManager.java:612)
at com.ti.dvt.energytrace.IDEHandler.launchHiddenDS(IDEHandler.java:440)
at com.ti.dvt.energytrace.IDEHandler.preNonDebugStartup(IDEHandler.java:224)
at com.ti.dvt.energytrace.IDEHandler.startupDashboard(IDEHandler.java:490)
at com.ti.dvt.energytrace.actions.DashboardAction.runET(DashboardAction.java:102)
at com.ti.dvt.energytrace.actions.DashboardAction.run(DashboardAction.java:55)
at org.eclipse.ui.internal.WWinPluginAction.runWithEvent(WWinPluginAction.java:218)
at org.eclipse.jface.action.ActionContributionItem.lambda$5(ActionContributionItem.java:453)
!ENTRY org.eclipse.ui 4 0 2024-07-09 16:16:34.836
!STACK 0
!ENTRY org.eclipse.ui 4 0 2024-07-09 16:16:53.040
!STACK 0
