Part Number: CC2340R2
Other Parts Discussed in Thread: CC2340R5, TMP61
Is there an applicaiton note to interface a two wire RTD Pt-100 to the on-board ADC 12-Bit conversion?
Loay Suffer
Loay,
Thank you for your inquiry.
PTD thermal sensors are essentially variable resistors controlled by temperature, therefore the same basic principles to a thermistor have to be used.
Thermistor temperature transducer-to-ADC application (SLYT156)
Although we don't have a specific application note to interface a thermistor with the CC2340R5, given that it has more than one ADC input you can use the topology shown in the application note below for our TMP61 NTC
Ultra-Small, Low-Cost Analog Temperature Sensor Measurement Circuit With ADC
Hope this helps,
Rafael
