CC2340R5: Serial Bootloader Commands given in user manual is not responding in boot mode.
Part Number: CC2340R5
I am using,
IC : CC2340R5 Launchpad
Example Stack : Data Stream
IDE : CCS 12.7.1
I am tryining to Implement serial bootloader in my data stream modified example
Sys Config Settings Screenshot:
before starting the program i made the DIO25 pin high to go in boot mode
Serial Command response for setting Baud Rate:
When i entered into the boot mode, the command of Set Baud Rate(0x55) responses ACK(0x00 CC).But when i am trying to send some other commands given in user manual, they are not responding either NACK or ACK.
How to solve this problem???
Waiting for a fruitful response.
Thank You
