Part Number: CC2640R2F
My customer have 1pcs CC2640R2FYFVR after mounting no signal, please check can we apply FA? thanks!
Thank you for reaching out.
Could you please provide more details on the issue so our experts can investigate? Among others, could you please answer these questions?
- Can you please provide a rough estimation of the number of working units vs non-working units?
- Can you please describe the way the board is tested to assess the absence of signal?
- Can you describe the other tests you have run on the units?
Also, could you please specify what you meant by "can we apply FA?" I am afraid I am not familiar with this terminology.
Appreciate your help,
Productio 293000pcs, only1pcs fail.
Can you please describe the way the board is tested to assess the absence of signal ?
VDDS 1.8V above,Xtal no change,nRESET normal,IC X-ray no issue.
Test station Fail,phone APP can not find sign.
Thank you for providing these details.
I have looped in our hardware experts.
To speed investigations, could you please provide the marking on the IC? This will help us finding back the lot number.
Thanks and regards,
Hi Jayce,
We don't initiate failure analysis proceedings on this platform. Please contact the local TI FQE (Field Quality Engineer) for your region, so they can request the correct information and start this process.
Rafael
