LAUNCHXL-CC1352P: How to merge a Sensor Controller example with ble project
Part Number: LAUNCHXL-CC1352P
HI all,
I refer to the following discussion and try to merge a Sensor Controller example with project. But sensor controller does not work correctly(BLE project work correctly). Looks like the discussions does not use latest SDK. How to merge a Sensor Controller example with latest SDK
SDK : 7.41.00.17
Sensor controller : 2.9.0.208(path1, 2, 3 and 4)
https://e2e.ti.com/support/wireless-connectivity/bluetooth-group/bluetooth/f/bluetooth-forum/1014267/faq-cc2640r2f-how-to-merge-a-sensor-controller-example-with-simple_peripheral-step-by-step-guide
https://www.ti.com/lit/an/swru537/swru537.pdf?ts=1727233288205
  • Please start with doing the following SLA for the CC13XX CC26XX SimpleLink Academy
    Sensor Controller Project From Scratch (ti.com)
    This will guide you on how to add a SCS project to the empty project (select the empty project for the CC1352P Launchpad that you are using.
    Once you have confirmed that you can do that, you can repreat the exersize, but them use your LAUNCHXL-CC1352P BLE example as the destination for the Sensor Controller files (not the empty project).
    Siri
