Hi, Ti
I need to send data through l2cap after reporting the BLEAPPUTIL_PAIRING_STATE_ENCRYPTED event.
How do I get the current channel id in app_pairing.c?
Preston
Hi, Ti
Preston
Hi, Ti
I tried referencing the CID here
void L2CAPCOC_signalHandler(uint32 event, BLEAppUtil_msgHdr_t *pMsgData) { if (!pMsgData) { // Caller needs to figure out by himself that pMsg is NULL return; } /*Handle the l2cap event */ switch (event) { case BLEAPPUTIL_L2CAP_CHANNEL_ESTABLISHED_EVT: { l2capChannelEstEvt_t *pConnEvt = &((l2capSignalEvent_t *)pMsgData)->cmd.channelEstEvt; gL2CAPCOC_AppData.CID = pConnEvt->CID; gL2CAPCOC_AppData.peerCID = pConnEvt->info.peerCID;
However, it appears that the CID is obtained only after reporting the BLEAPPUTIL_L2CAP_CHANNEL_ESTABLISHED_EVT event.
The log shows that this happens after BLEAPPUTIL_PAIRING_STATE_ENCRYPTED
When BLEAPPUTIL_PAIRING_STATE_ENCRYPTED reports, how do I get the CID I need to send data through l2cap?
Preston
