LP-EM-CC2340R5: After the Bluetooth connection is established, the L2CAP cannot transmit after a few hours.
Part Number: LP-EM-CC2340R5
Other Parts Discussed in Thread: CC2340R5
Hi, Ti
I used two CC2340s to stress test L2cap for data transmission. After the L2cap is established, the periphery sends test data to the center and outputs logs. We will periodically turn off the power of the central device, disconnect the Bluetooth, then power it on again, and reconnect the Bluetooth (already bonding).
After a period of time, after more than a hundred tests (Bluetooth reconnection), the transmission of data will be abnormal (through the log to see that the transmission has been successful), and after restarting the peripheral device, the data transmission will return to normal.
What might be the reason for this? In addition, is there any way to monitor the status of the Bluetooth stack (such as the remaining space on the stack)?
Best regards
Preston
