Part Number: CC2340R5
Dear Sir,
We are currently working with a panel of 32 modules, along with a separate reference module that shares the same IC as the modules on the panel. To measure RSSI, we follow this process:
- Power on one module at a time from the panel.
- Establish a connection between the powered-on module and the reference module.
- Issue a command to the module on the panel to retrieve the RSSI value.
This approach is functional but time-consuming, as it requires creating a connection for each module individually before retrieving the RSSI.
We are exploring the possibility of obtaining the RSSI values without having to establish a connection for each module. Could you please let us know if there are any commands, methods, or alternatives that allow us to directly measure RSSI without going through the connection process?
