Hi TI Team,
I'm looking for the IC 48MHz Oscillator functional mode (VDD gain), is it :
-Variable gain without gain setting (software) ? for example > Loopcontrol function, gain switch function . . . (high gain for start up, reduced gain for steady state)
-Constant gain without gain setting (software) ? for example > Fullswingmode
-Constant gain with gain setting (software) ? for example > low, medium, high or Ampsel 00, 01, 11 . . .
-Variable gain with gain setting (software) ? for example > low, medium, high or Ampsel 00, 01, 11 . . . (high gain for start up, reduced gain for steady state)
Can you tell me what is the gain/loop control is (strategy, timing etc.) ?
Secondly, when we do our process to calculate the oscillation margin of the 48MHz oscillator, if the resistor is too high, we notice that the oscillator starts with a significant frequency drift and it never sets up at the right frequency. What is this and why? Normally the oscillator won't start if the resistor is too high.
Finally, is there a minimum magnitude of the 48MHz oscillator to be respected for the µC PLL?
Have a good day,
Titouan
