Part Number: CC2745P10-Q1
When using the official OAD project, the recipe for target 'post-build' failed compiler error (failed to execute the sbtool script) is as follows:
UnicodeDecodeError: 'gbk' codec can't decode byte 0xf9 in position 12: illegal multibyte sequence
[16692] Failed to execute script 'sbtool' due to unhandled exception!
There is no problem with these paths, help to see what else needs to be configured to carry out normal compilation?
thank you
