I found that running CC2340 for a long time may cause a crash. I turned on the Debug mode to observe and found System Stack Overflow but CC2340 was still running normally. Is it normal that CC2340 will not immediately enter functions such as faultISR if System Stack Overflow occurs? Or how to make CC2340 enter faultISR whenever System Stack Overflow occurs? I tried adjusting the System Stack Size to 1200, the default is 800, and then used ROV to observe the same. I found that when I tried to connect, the Stack Peak was about 804, and when I used Notify, the Stack Peak reached 936.
