CC2564CSTBTBLESW: CC2564C
Part Number: CC2564CSTBTBLESW
Other Parts Discussed in Thread: CC2564C,
We are working on an application which using CC2564C + STM32F4 with CC2564CSTBTBLESW stack.
Now we are using HCI tester to run the DTM for RF testing.
The current implementation is:
TX: HCI Tester -> STM32F401 -> (UART data forwarder) -> CC2564C
RX: CC2564C -> STM32F401 -> (UART data forwarder) -> HCI Tester
The TX part is no problem, but we encountered a problem at HCI Tester side on RX part.
HCI Tester can receive the data returned from CC2564C but separated in two UART handling.
Once STM32F401 receives one bye from CC2564C, STM32F401 send this byte to HCI Tester immediately.
However, if the total number of data returned from CC2564C is 15 bytes, HCI tester will treat the 15-byte data into two UART handling,
one is 10-byte and one is 5-byte. So HCI Tester will return error for insufficient data analysis for the first 10-byte data.
Please refer to the log file: HCITester Trace Log_byte_by_byte_interrupt.htm
Question: What is the timeout of UART consecutive data byte receiving for HCI Tester?
So we try to change another implementation by sending a load of data to HCI Tester instead of byte by byte.
And we found that there is totally no problem at the HCI tester.
Please refer to the attached log file: HCITester Trace Log4.htm
So is it possible to send the data to the HCI tester by judging the data returned format, like the first bye is 0x04, and the 2nd byte is always the number of data bytes and
we use the 2nd byte value to judge the whole data set returned from CC2564C, and then send to HCI tester in one load.
Question: Is there any risk if we use this method to send the CC2456C returned data in one load? any situation that the 2nd byte value is not the number of data bytes?
Thank you very much.
<HTML>
<HEAD>
<TITLE>HCITester Log</TITLE>
</HEAD>
<BODY>
<FONT face="Courier New">
<TABLE ALIGN=LEFT CELLSPACING=0 width=3500 CELLPADDING=0>
<tr bgcolor="ffffe6"><td><font color="0000c0">21:17:42.885 --</font></td></tr>
<tr bgcolor="ffffe6"><td><font color="0000c0">21:17:42.885 Packet "HCI_VS_Read_Patch_Version", Opcode 0xff22</font></td></tr>
<tr bgcolor="60c0c0"><td><font color="ffffff">21:17:42.885 Outgoing Dump:</font></td></tr>
<tr bgcolor="60c0c0"><td><font color="ffffff">21:17:42.885     0000: 01 22 ff 00                                     ."..</font></td></tr>
<tr bgcolor="408080"><td><font color="ffffff">21:17:42.890 Incoming Dump:</font></td></tr>
<tr bgcolor="408080"><td><font color="ffffff">21:17:42.890     0000: 04 0e 0e 01 22 ff 00 00 00 00 00 98 2a 00 00 00 ....".......*...</font></td></tr>
<tr bgcolor="408080"><td><font color="ffffff">21:17:42.890     0010: 1a                                              .</font></td></tr>
<tr bgcolor="fff7fa"><td><font color="006400">21:17:42.890 --</font></td></tr>
<tr bgcolor="fff7fa"><td><font color="006400">21:17:42.890 Packet "HCI_Command_Complete_VS_Read_Patch_Version_Event", Opcode 0xff22</font></td></tr>
<tr bgcolor="fff7fa"><td><font color="006400">21:17:42.890 Parameters:</font></td></tr>
<tr bgcolor="fff7fa"><td><font color="006400">21:17:42.890 | Number HCI commands : 0x01</font></td></tr>
<tr bgcolor="fff7fa"><td><font color="006400">21:17:42.890 | Command Opcode      : 0xff22</font></td></tr>
<tr bgcolor="fff7fa"><td><font color="006400">21:17:42.890 | Status              : 0x00 (Success)</font></td></tr>
<tr bgcolor="fff7fa"><td><font color="006400">21:17:42.890 | Enabled Mask        : 0x00000000</font></td></tr>
<tr bgcolor="fff7fa"><td><font color="006400">21:17:42.890 | ReleaseMajor        : -104</font></td></tr>
<tr bgcolor="fff7fa"><td><font color="006400">21:17:42.890 | ReleaseMinor        : 42</font></td></tr>
<tr bgcolor="fff7fa"><td><font color="006400">21:17:42.890 | PackageID           : 0</font></td></tr>
<tr bgcolor="fff7fa"><td><font color="006400">21:17:42.890 | Build Number        : 0</font></td></tr>
<tr bgcolor="ffc0a0"><td><font color="000000">21:17:42.890 ERROR - Packet Size. Got: 17 (0x11), Expected: 15 (0x0f)</font></td></tr>
<tr bgcolor="ffffe6"><td><font color="0000c0">21:20:06.376 --</font></td></tr>
<tr bgcolor="ffffe6"><td><font color="0000c0">21:20:06.376 Packet "HCI_Read_Local_Version_Information", Opcode 0x1001</font></td></tr>
<tr bgcolor="60c0c0"><td><font color="ffffff">21:20:06.376 Outgoing Dump:</font></td></tr>
<tr bgcolor="60c0c0"><td><font color="ffffff">21:20:06.376     0000: 01 01 10 00                                     ....</font></td></tr>
<tr bgcolor="408080"><td><font color="ffffff">21:20:06.381 Incoming Dump:</font></td></tr>
<tr bgcolor="408080"><td><font color="ffffff">21:20:06.381     0000: 04 0e 0c 01 01 10 00 07 00 00 07 0d 00 1a 9a    ...............</font></td></tr>
<tr bgcolor="fff7fa"><td><font color="006400">21:20:06.381 --</font></td></tr>
<tr bgcolor="fff7fa"><td><font color="006400">21:20:06.381 Packet "HCI_Command_Complete_Read_Local_Version_Information_Event", Opcode 0x1001</font></td></tr>
<tr bgcolor="fff7fa"><td><font color="006400">21:20:06.381 Parameters:</font></td></tr>
<tr bgcolor="fff7fa"><td><font color="006400">21:20:06.381 | Number HCI commands : 0x01</font></td></tr>
<tr bgcolor="fff7fa"><td><font color="006400">21:20:06.381 | Command Opcode      : 0x1001</font></td></tr>
<tr bgcolor="fff7fa"><td><font color="006400">21:20:06.381 | Status              : 0x00 (Success)</font></td></tr>
<tr bgcolor="fff7fa"><td><font color="006400">21:20:06.381 | HCI Version         : 0x07</font></td></tr>
<tr bgcolor="fff7fa"><td><font color="006400">21:20:06.381 | HCI Revision        : 0x0000</font></td></tr>
<tr bgcolor="fff7fa"><td><font color="006400">21:20:06.381 | LMP Version         : 0x07</font></td></tr>
<tr bgcolor="fff7fa"><td><font color="006400">21:20:06.381 | Manufacturer Name   : 0x000d (Texas Instruments Inc.)</font></td></tr>
<tr bgcolor="fff7fa"><td><font color="006400">21:20:06.381 | LMP Subversion      : 0x9a1a</font></td></tr>
<tr bgcolor="ffffe6"><td><font color="0000c0">21:20:28.576 --</font></td></tr>
<tr bgcolor="ffffe6"><td><font color="0000c0">21:20:28.576 Packet "HCI_Read_Local_Supported_Commands", Opcode 0x1002</font></td></tr>
<tr bgcolor="60c0c0"><td><font color="ffffff">21:20:28.576 Outgoing Dump:</font></td></tr>
<tr bgcolor="60c0c0"><td><font color="ffffff">21:20:28.576     0000: 01 02 10 00                                     ....</font></td></tr>
<tr bgcolor="408080"><td><font color="ffffff">21:20:28.584 Incoming Dump:</font></td></tr>
<tr bgcolor="408080"><td><font color="ffffff">21:20:28.585     0000: 04 0e 44 01 02 10 00 ff ff ff 03 ce ff ff ff 0f ..D.............</font></td></tr>
<tr bgcolor="408080"><td><font color="ffffff">21:20:28.585     0010: ff ff 1f f2 0f e8 fe 3f f7 8f ff 1c 00 00 00 61 .......?.......a</font></td></tr>
<tr bgcolor="408080"><td><font color="ffffff">21:20:28.585     0020: f7 ff ff 7f 38 00 00 00 00 00 00 00 00 00 00 00 ....8...........</font></td></tr>
<tr bgcolor="408080"><td><font color="ffffff">21:20:28.585     0030: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................</font></td></tr>
<tr bgcolor="408080"><td><font color="ffffff">21:20:28.585     0040: 00 00 00 00 00 00 00                            .......</font></td></tr>
<tr bgcolor="fff7fa"><td><font color="006400">21:20:28.585 --</font></td></tr>
<tr bgcolor="fff7fa"><td><font color="006400">21:20:28.585 Packet "HCI_Command_Complete_Read_Local_Supported_Commands_Event", Opcode 0x1002</font></td></tr>
<tr bgcolor="fff7fa"><td><font color="006400">21:20:28.585 Parameters:</font></td></tr>
<tr bgcolor="fff7fa"><td><font color="006400">21:20:28.585 | Number HCI commands : 0x01</font></td></tr>
<tr bgcolor="fff7fa"><td><font color="006400">21:20:28.585 | Command Opcode      : 0x1002</font></td></tr>
<tr bgcolor="fff7fa"><td><font color="006400">21:20:28.585 | Status              : 0x00 (Success)</font></td></tr>
<tr bgcolor="fff7fa"><td><font color="006400">21:20:28.585 | Supported Commands  : "FF:FF:FF:03:CE:FF:FF:FF:0F:FF:FF:1F:F2:0F:E8:FE:3F:F7:8F:FF:1C:00:00:00:61:F7:FF:FF:7F:38:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00"</font></td></tr>
<tr bgcolor="ffffe6"><td><font color="0000c0">21:21:09.017 --</font></td></tr>
<tr bgcolor="ffffe6"><td><font color="0000c0">21:21:09.017 Packet "HCI_Read_Local_Supported_Features", Opcode 0x1003</font></td></tr>
<tr bgcolor="60c0c0"><td><font color="ffffff">21:21:09.017 Outgoing Dump:</font></td></tr>
<tr bgcolor="60c0c0"><td><font color="ffffff">21:21:09.017     0000: 01 03 10 00                                     ....</font></td></tr>
<tr bgcolor="408080"><td><font color="ffffff">21:21:09.021 Incoming Dump:</font></td></tr>
<tr bgcolor="408080"><td><font color="ffffff">21:21:09.021     0000: 04 0e 0c 01 03 10 00 ff fe 2d fe db ff 7b 87    .........-...{.</font></td></tr>
<tr bgcolor="fff7fa"><td><font color="006400">21:21:09.021 --</font></td></tr>
<tr bgcolor="fff7fa"><td><font color="006400">21:21:09.021 Packet "HCI_Command_Complete_Read_Local_Supported_Features_Event", Opcode 0x1003</font></td></tr>
<tr bgcolor="fff7fa"><td><font color="006400">21:21:09.021 Parameters:</font></td></tr>
<tr bgcolor="fff7fa"><td><font color="006400">21:21:09.021 | Number HCI commands : 0x01</font></td></tr>
<tr bgcolor="fff7fa"><td><font color="006400">21:21:09.021 | Command Opcode      : 0x1003</font></td></tr>
<tr bgcolor="fff7fa"><td><font color="006400">21:21:09.021 | Status              : 0x00 (Success)</font></td></tr>
<tr bgcolor="fff7fa"><td><font color="006400">21:21:09.021 | Supported Commands  : "FF:FE:2D:FE:DB:FF:7B:87"</font></td></tr>
<tr bgcolor="ffffe6"><td><font color="0000c0">21:21:18.488 --</font></td></tr>
<tr bgcolor="ffffe6"><td><font color="0000c0">21:21:18.488 Packet "HCI_Read_BD_ADDR", Opcode 0x1009</font></td></tr>
<tr bgcolor="60c0c0"><td><font color="ffffff">21:21:18.488 Outgoing Dump:</font></td></tr>
<tr bgcolor="60c0c0"><td><font color="ffffff">21:21:18.488     0000: 01 09 10 00                                     ....</font></td></tr>
<tr bgcolor="408080"><td><font color="ffffff">21:21:18.491 Incoming Dump:</font></td></tr>
<tr bgcolor="408080"><td><font color="ffffff">21:21:18.491     0000: 04 0e 0a 01 09 10 00 36 0e 37 b4 04 08          .......6.7...</font></td></tr>
<tr bgcolor="fff7fa"><td><font color="006400">21:21:18.491 --</font></td></tr>
<tr bgcolor="fff7fa"><td><font color="006400">21:21:18.491 Packet "HCI_Command_Complete_Read_BD_ADDR_Event", Opcode 0x1009</font></td></tr>
<tr bgcolor="fff7fa"><td><font color="006400">21:21:18.491 Parameters:</font></td></tr>
<tr bgcolor="fff7fa"><td><font color="006400">21:21:18.491 | Number HCI commands : 0x01</font></td></tr>
<tr bgcolor="fff7fa"><td><font color="006400">21:21:18.491 | Command Opcode      : 0x1009</font></td></tr>
<tr bgcolor="fff7fa"><td><font color="006400">21:21:18.491 | Status              : 0x00 (Success)</font></td></tr>
<tr bgcolor="fff7fa"><td><font color="006400">21:21:18.491 | BD Address          : "08:04:B4:37:0E:36"</font></td></tr>
<tr bgcolor="ffffff"><td><font color="000000">21:21:43.683 *** Script Started: ***</font></td></tr>
<tr bgcolor="ffffe6"><td><font color="0000c0">21:21:43.683 --</font></td></tr>
<tr bgcolor="ffffe6"><td><font color="0000c0">21:21:43.683 Packet "HCI_Read_BD_ADDR", Opcode 0x1009</font></td></tr>
<tr bgcolor="60c0c0"><td><font color="ffffff">21:21:43.683 Outgoing Dump:</font></td></tr>
<tr bgcolor="60c0c0"><td><font color="ffffff">21:21:43.683     0000: 01 09 10 00                                     ....</font></td></tr>
<tr bgcolor="408080"><td><font color="ffffff">21:21:43.687 Incoming Dump:</font></td></tr>
<tr bgcolor="408080"><td><font color="ffffff">21:21:43.687     0000: 04 0e 0a 01 09 10 00 36 0e 37 b4 04 08          .......6.7...</font></td></tr>
<tr bgcolor="fff7fa"><td><font color="006400">21:21:43.687 --</font></td></tr>
<tr bgcolor="fff7fa"><td><font color="006400">21:21:43.687 Packet "HCI_Command_Complete_Read_BD_ADDR_Event", Opcode 0x1009</font></td></tr>
<tr bgcolor="fff7fa"><td><font color="006400">21:21:43.687 Parameters:</font></td></tr>
<tr bgcolor="fff7fa"><td><font color="006400">21:21:43.687 | Number HCI commands : 0x01</font></td></tr>
<tr bgcolor="fff7fa"><td><font color="006400">21:21:43.687 | Command Opcode      : 0x1009</font></td></tr>
<tr bgcolor="fff7fa"><td><font color="006400">21:21:43.687 | Status              : 0x00 (Success)</font></td></tr>
<tr bgcolor="fff7fa"><td><font color="006400">21:21:43.687 | BD Address          : "08:04:B4:37:0E:36"</font></td></tr>
<tr bgcolor="ffc0a0"><td><font color="000000">21:21:43.687 ERROR - Unknown 'BD_ADDR'</font></td></tr>
<tr bgcolor="ffc0a0"><td><font color="000000">21:21:43.687 ERRORed Line (11): Wait_HCI_Command_Complete_Read_BD_ADDR_Event 5000, any, HCI_Read_BD_ADDR, 0x00, BD_ADDR</font></td></tr>
<tr bgcolor="ffffff"><td><font color="000000">21:21:43.687 --</font></td></tr>
<tr bgcolor="ffffff"><td><font color="000000">21:21:43.687 *** Script End ***</font></td></tr>
<tr bgcolor="ffffff"><td><font color="000000">21:21:56.427 *** Script Started: ***</font></td></tr>
<tr bgcolor="ffffe6"><td><font color="0000c0">21:21:56.427 --</font></td></tr>
<tr bgcolor="ffffe6"><td><font color="0000c0">21:21:56.427 Packet "HCI_Read_BD_ADDR", Opcode 0x1009</font></td></tr>
<tr bgcolor="60c0c0"><td><font color="ffffff">21:21:56.427 Outgoing Dump:</font></td></tr>
<tr bgcolor="60c0c0"><td><font color="ffffff">21:21:56.427     0000: 01 09 10 00                                     ....</font></td></tr>
<tr bgcolor="408080"><td><font color="ffffff">21:21:56.431 Incoming Dump:</font></td></tr>
<tr bgcolor="408080"><td><font color="ffffff">21:21:56.431     0000: 04 0e 0a 01 09 10 00 36 0e 37 b4 04 08          .......6.7...</font></td></tr>
<tr bgcolor="fff7fa"><td><font color="006400">21:21:56.431 --</font></td></tr>
<tr bgcolor="fff7fa"><td><font color="006400">21:21:56.431 Packet "HCI_Command_Complete_Read_BD_ADDR_Event", Opcode 0x1009</font></td></tr>
<tr bgcolor="fff7fa"><td><font color="006400">21:21:56.431 Parameters:</font></td></tr>
<tr bgcolor="fff7fa"><td><font color="006400">21:21:56.431 | Number HCI commands : 0x01</font></td></tr>
<tr bgcolor="fff7fa"><td><font color="006400">21:21:56.431 | Command Opcode      : 0x1009</font></td></tr>
<tr bgcolor="fff7fa"><td><font color="006400">21:21:56.431 | Status              : 0x00 (Success)</font></td></tr>
<tr bgcolor="fff7fa"><td><font color="006400">21:21:56.431 | BD Address          : "08:04:B4:37:0E:36"</font></td></tr>
<tr bgcolor="ffffff"><td><font color="000000">21:21:56.431 --</font></td></tr>
<tr bgcolor="ffffff"><td><font color="000000">21:21:56.431 *** Script End ***</font></td></tr>
<tr bgcolor="ffffff"><td><font color="000000">21:22:21.633 *** Script Started: ***</font></td></tr>
<tr bgcolor="ffffe6"><td><font color="0000c0">21:22:21.634 --</font></td></tr>
<tr bgcolor="ffffe6"><td><font color="0000c0">21:22:21.634 Packet "HCI_Read_BD_ADDR", Opcode 0x1009</font></td></tr>
<tr bgcolor="60c0c0"><td><font color="ffffff">21:22:21.634 Outgoing Dump:</font></td></tr>
<tr bgcolor="60c0c0"><td><font color="ffffff">21:22:21.634     0000: 01 09 10 00                                     ....</font></td></tr>
<tr bgcolor="408080"><td><font color="ffffff">21:22:21.637 Incoming Dump:</font></td></tr>
<tr bgcolor="408080"><td><font color="ffffff">21:22:21.637     0000: 04 0e 0a 01 09 10 00 36 0e 37 b4 04 08          .......6.7...</font></td></tr>
<tr bgcolor="fff7fa"><td><font color="006400">21:22:21.637 --</font></td></tr>
<tr bgcolor="fff7fa"><td><font color="006400">21:22:21.637 Packet "HCI_Command_Complete_Read_BD_ADDR_Event", Opcode 0x1009</font></td></tr>
<tr bgcolor="fff7fa"><td><font color="006400">21:22:21.637 Parameters:</font></td></tr>
<tr bgcolor="fff7fa"><td><font color="006400">21:22:21.637 | Number HCI commands : 0x01</font></td></tr>
<tr bgcolor="fff7fa"><td><font color="006400">21:22:21.637 | Command Opcode      : 0x1009</font></td></tr>
<tr bgcolor="fff7fa"><td><font color="006400">21:22:21.637 | Status              : 0x00 (Success)</font></td></tr>
<tr bgcolor="fff7fa"><td><font color="006400">21:22:21.637 | BD Address          : "08:04:B4:37:0E:36"</font></td></tr>
<tr bgcolor="ffffe6"><td><font color="0000c0">21:22:21.638 --</font></td></tr>
<tr bgcolor="ffffe6"><td><font color="0000c0">21:22:21.638 Packet "HCI_Read_Country_Code", Opcode 0x1007</font></td></tr>
<tr bgcolor="60c0c0"><td><font color="ffffff">21:22:21.638 Outgoing Dump:</font></td></tr>
<tr bgcolor="60c0c0"><td><font color="ffffff">21:22:21.638     0000: 01 07 10 00                                     ....</font></td></tr>
<tr bgcolor="408080"><td><font color="ffffff">21:22:21.640 Incoming Dump:</font></td></tr>
<tr bgcolor="408080"><td><font color="ffffff">21:22:21.640     0000: 04 0e 04 01 07 10 01                            .......</font></td></tr>
<tr bgcolor="fff7fa"><td><font color="006400">21:22:21.640 --</font></td></tr>
<tr bgcolor="fff7fa"><td><font color="006400">21:22:21.640 Packet "HCI_Command_Complete_Read_Country_Code_Event", Opcode 0x1007</font></td></tr>
<tr bgcolor="fff7fa"><td><font color="006400">21:22:21.640 Parameters:</font></td></tr>
<tr bgcolor="fff7fa"><td><font color="006400">21:22:21.640 | Number HCI commands : 0x01</font></td></tr>
<tr bgcolor="fff7fa"><td><font color="006400">21:22:21.640 | Command Opcode      : 0x1007</font></td></tr>
<tr bgcolor="fff7fa"><td><font color="006400">21:22:21.640 | Status              : 0x01 (Unknown HCI Command)</font></td></tr>
<tr bgcolor="fff7fa"><td><font color="006400">21:22:21.640 | Country Code        : 0x00</font></td></tr>
<tr bgcolor="ffc0a0"><td><font color="000000">21:22:21.640 ERROR - Packet Size. Got: 7 (0x07), Expected: 8 (0x08)</font></td></tr>
<tr bgcolor="ffc0a0"><td><font color="000000">21:22:21.640 ERROR - Status mismatch. Expected: 0x00,  Got: 0x01 (Unknown HCI Command)</font></td></tr>
<tr bgcolor="ffc0a0"><td><font color="000000">21:22:21.640 ERRORed Line (15): Wait_HCI_Command_Complete_Read_Country_Code_Event 5000, any, HCI_Read_Country_Code, 0x00, 0x00</font></td></tr>
<tr bgcolor="ffffff"><td><font color="000000">21:22:21.641 --</font></td></tr>
<tr bgcolor="ffffff"><td><font color="000000">21:22:21.641 *** Script End ***</font></td></tr>
<tr bgcolor="ffc0a0"><td><font color="000000">21:22:54.792 ERROR - Aborted by Operator</font></td></tr>
<tr bgcolor="ffc0a0"><td><font color="000000">21:22:54.793 ERRORed Line (1): Wait_HCI_Command_Complete_Read_Country_Code_Event 5000, any, Any, 0x00, 0x00</font></td></tr>
<tr bgcolor="ffffff"><td><font color="000000">21:22:59.105 *** Script Started: ***</font></td></tr>
<tr bgcolor="ffffe6"><td><font color="0000c0">21:22:59.105 --</font></td></tr>
<tr bgcolor="ffffe6"><td><font color="0000c0">21:22:59.105 Packet "HCI_Read_BD_ADDR", Opcode 0x1009</font></td></tr>
<tr bgcolor="60c0c0"><td><font color="ffffff">21:22:59.105 Outgoing Dump:</font></td></tr>
<tr bgcolor="60c0c0"><td><font color="ffffff">21:22:59.105     0000: 01 09 10 00                                     ....</font></td></tr>
<tr bgcolor="408080"><td><font color="ffffff">21:22:59.108 Incoming Dump:</font></td></tr>
<tr bgcolor="408080"><td><font color="ffffff">21:22:59.108     0000: 04 0e 0a 01 09 10 00 36 0e 37 b4 04 08          .......6.7...</font></td></tr>
<tr bgcolor="fff7fa"><td><font color="006400">21:22:59.108 --</font></td></tr>
<tr bgcolor="fff7fa"><td><font color="006400">21:22:59.108 Packet "HCI_Command_Complete_Read_BD_ADDR_Event", Opcode 0x1009</font></td></tr>
<tr bgcolor="fff7fa"><td><font color="006400">21:22:59.108 Parameters:</font></td></tr>
<tr bgcolor="fff7fa"><td><font color="006400">21:22:59.108 | Number HCI commands : 0x01</font></td></tr>
<tr bgcolor="fff7fa"><td><font color="006400">21:22:59.108 | Command Opcode      : 0x1009</font></td></tr>
<tr bgcolor="fff7fa"><td><font color="006400">21:22:59.108 | Status              : 0x00 (Success)</font></td></tr>
<tr bgcolor="fff7fa"><td><font color="006400">21:22:59.108 | BD Address          : "08:04:B4:37:0E:36"</font></td></tr>
<tr bgcolor="ffffe6"><td><font color="0000c0">21:22:59.108 --</font></td></tr>
<tr bgcolor="ffffe6"><td><font color="0000c0">21:22:59.108 Packet "HCI_Read_Country_Code", Opcode 0x1007</font></td></tr>
<tr bgcolor="60c0c0"><td><font color="ffffff">21:22:59.108 Outgoing Dump:</font></td></tr>
<tr bgcolor="60c0c0"><td><font color="ffffff">21:22:59.108     0000: 01 07 10 00                                     ....</font></td></tr>
<tr bgcolor="408080"><td><font color="ffffff">21:22:59.111 Incoming Dump:</font></td></tr>
<tr bgcolor="408080"><td><font color="ffffff">21:22:59.111     0000: 04 0e 04 01 07 10 01                            .......</font></td></tr>
<tr bgcolor="fff7fa"><td><font color="006400">21:22:59.111 --</font></td></tr>
<tr bgcolor="fff7fa"><td><font color="006400">21:22:59.111 Packet "HCI_Command_Complete_Read_Country_Code_Event", Opcode 0x1007</font></td></tr>
<tr bgcolor="fff7fa"><td><font color="006400">21:22:59.111 Parameters:</font></td></tr>
<tr bgcolor="fff7fa"><td><font color="006400">21:22:59.111 | Number HCI commands : 0x01</font></td></tr>
<tr bgcolor="fff7fa"><td><font color="006400">21:22:59.111 | Command Opcode      : 0x1007</font></td></tr>
<tr bgcolor="fff7fa"><td><font color="006400">21:22:59.111 | Status              : 0x01 (Unknown HCI Command)</font></td></tr>
<tr bgcolor="fff7fa"><td><font color="006400">21:22:59.111 | Country Code        : 0x00</font></td></tr>
<tr bgcolor="ffc0a0"><td><font color="000000">21:22:59.111 ERROR - Packet Size. Got: 7 (0x07), Expected: 8 (0x08)</font></td></tr>
<tr bgcolor="ffc0a0"><td><font color="000000">21:22:59.111 ERROR - Status mismatch. Expected: 0x00,  Got: 0x01 (Unknown HCI Command)</font></td></tr>
<tr bgcolor="ffc0a0"><td><font color="000000">21:22:59.111 ERRORed Line (15): Wait_HCI_Command_Complete_Read_Country_Code_Event 5000, any, Any, 0x00, 0x00</font></td></tr>
<tr bgcolor="ffffff"><td><font color="000000">21:22:59.111 --</font></td></tr>
<tr bgcolor="ffffff"><td><font color="000000">21:22:59.111 *** Script End ***</font></td></tr>
<tr bgcolor="ffc0a0"><td><font color="000000">21:23:49.483 ERROR - Script parse Error</font></td></tr>
<tr bgcolor="ffc0a0"><td><font color="000000">21:23:49.483 ERRORed Line (1): Handle</font></td></tr>
<tr bgcolor="ffc0a0"><td><font color="000000">21:23:49.483 Script:   -- Aborted</font></td></tr>
<tr bgcolor="ffffff"><td><font color="000000">21:23:53.578 *** Script Started: ***</font></td></tr>
<tr bgcolor="ffffe6"><td><font color="0000c0">21:23:53.579 --</font></td></tr>
<tr bgcolor="ffffe6"><td><font color="0000c0">21:23:53.579 Packet "HCI_Read_BD_ADDR", Opcode 0x1009</font></td></tr>
<tr bgcolor="60c0c0"><td><font color="ffffff">21:23:53.579 Outgoing Dump:</font></td></tr>
<tr bgcolor="60c0c0"><td><font color="ffffff">21:23:53.579     0000: 01 09 10 00                                     ....</font></td></tr>
<tr bgcolor="408080"><td><font color="ffffff">21:23:53.583 Incoming Dump:</font></td></tr>
<tr bgcolor="408080"><td><font color="ffffff">21:23:53.583     0000: 04 0e 0a 01 09 10 00 36 0e 37 b4 04 08          .......6.7...</font></td></tr>
<tr bgcolor="fff7fa"><td><font color="006400">21:23:53.583 --</font></td></tr>
<tr bgcolor="fff7fa"><td><font color="006400">21:23:53.583 Packet "HCI_Command_Complete_Read_BD_ADDR_Event", Opcode 0x1009</font></td></tr>
<tr bgcolor="fff7fa"><td><font color="006400">21:23:53.583 Parameters:</font></td></tr>
<tr bgcolor="fff7fa"><td><font color="006400">21:23:53.583 | Number HCI commands : 0x01</font></td></tr>
<tr bgcolor="fff7fa"><td><font color="006400">21:23:53.583 | Command Opcode      : 0x1009</font></td></tr>
<tr bgcolor="fff7fa"><td><font color="006400">21:23:53.583 | Status              : 0x00 (Success)</font></td></tr>
<tr bgcolor="fff7fa"><td><font color="006400">21:23:53.583 | BD Address          : "08:04:B4:37:0E:36"</font></td></tr>
<tr bgcolor="ffffe6"><td><font color="0000c0">21:23:53.583 --</font></td></tr>
<tr bgcolor="ffffe6"><td><font color="0000c0">21:23:53.583 Packet "HCI_Read_Country_Code", Opcode 0x1007</font></td></tr>
<tr bgcolor="60c0c0"><td><font color="ffffff">21:23:53.583 Outgoing Dump:</font></td></tr>
<tr bgcolor="60c0c0"><td><font color="ffffff">21:23:53.583     0000: 01 07 10 00                                     ....</font></td></tr>
<tr bgcolor="408080"><td><font color="ffffff">21:23:53.587 Incoming Dump:</font></td></tr>
<tr bgcolor="408080"><td><font color="ffffff">21:23:53.587     0000: 04 0e 04 01 07 10 01                            .......</font></td></tr>
<tr bgcolor="fff7fa"><td><font color="006400">21:23:53.587 --</font></td></tr>
<tr bgcolor="fff7fa"><td><font color="006400">21:23:53.587 Packet "HCI_Command_Complete_Read_Country_Code_Event", Opcode 0x1007</font></td></tr>
<tr bgcolor="fff7fa"><td><font color="006400">21:23:53.587 Parameters:</font></td></tr>
<tr bgcolor="fff7fa"><td><font color="006400">21:23:53.587 | Number HCI commands : 0x01</font></td></tr>
<tr bgcolor="fff7fa"><td><font color="006400">21:23:53.587 | Command Opcode      : 0x1007</font></td></tr>
<tr bgcolor="fff7fa"><td><font color="006400">21:23:53.587 | Status              : 0x01 (Unknown HCI Command)</font></td></tr>
<tr bgcolor="fff7fa"><td><font color="006400">21:23:53.587 | Country Code        : 0x00</font></td></tr>
<tr bgcolor="ffc0a0"><td><font color="000000">21:23:53.587 ERROR - Packet Size. Got: 7 (0x07), Expected: 8 (0x08)</font></td></tr>
<tr bgcolor="ffc0a0"><td><font color="000000">21:23:53.588 ERROR - Status mismatch. Expected: 0x00,  Got: 0x01 (Unknown HCI Command)</font></td></tr>
<tr bgcolor="ffc0a0"><td><font color="000000">21:23:53.588 ERRORed Line (15): Wait_HCI_Command_Complete_Read_Country_Code_Event 5000, any, Any, 0x00, 0x00</font></td></tr>
<tr bgcolor="ffffff"><td><font color="000000">21:23:53.588 --</font></td></tr>
<tr bgcolor="ffffff"><td><font color="000000">21:23:53.588 *** Script End ***</font></td></tr>
<tr bgcolor="ffffff"><td><font color="000000">21:24:29.510 *** Script Started: ***</font></td></tr>
<tr bgcolor="ffffe6"><td><font color="0000c0">21:24:29.511 --</font></td></tr>
<tr bgcolor="ffffe6"><td><font color="0000c0">21:24:29.511 Packet "HCI_Read_BD_ADDR", Opcode 0x1009</font></td></tr>
<tr bgcolor="60c0c0"><td><font color="ffffff">21:24:29.511 Outgoing Dump:</font></td></tr>
<tr bgcolor="60c0c0"><td><font color="ffffff">21:24:29.511     0000: 01 09 10 00                                     ....</font></td></tr>
<tr bgcolor="408080"><td><font color="ffffff">21:24:29.514 Incoming Dump:</font></td></tr>
<tr bgcolor="408080"><td><font color="ffffff">21:24:29.514     0000: 04 0e 0a 01 09 10 00 36 0e 37 b4 04 08          .......6.7...</font></td></tr>
<tr bgcolor="fff7fa"><td><font color="006400">21:24:29.514 --</font></td></tr>
<tr bgcolor="fff7fa"><td><font color="006400">21:24:29.514 Packet "HCI_Command_Complete_Read_BD_ADDR_Event", Opcode 0x1009</font></td></tr>
<tr bgcolor="fff7fa"><td><font color="006400">21:24:29.514 Parameters:</font></td></tr>
<tr bgcolor="fff7fa"><td><font color="006400">21:24:29.514 | Number HCI commands : 0x01</font></td></tr>
<tr bgcolor="fff7fa"><td><font color="006400">21:24:29.514 | Command Opcode      : 0x1009</font></td></tr>
<tr bgcolor="fff7fa"><td><font color="006400">21:24:29.514 | Status              : 0x00 (Success)</font></td></tr>
<tr bgcolor="fff7fa"><td><font color="006400">21:24:29.514 | BD Address          : "08:04:B4:37:0E:36"</font></td></tr>
<tr bgcolor="ffffe6"><td><font color="0000c0">21:24:29.514 --</font></td></tr>
<tr bgcolor="ffffe6"><td><font color="0000c0">21:24:29.514 Packet "HCI_Read_Country_Code", Opcode 0x1007</font></td></tr>
<tr bgcolor="60c0c0"><td><font color="ffffff">21:24:29.515 Outgoing Dump:</font></td></tr>
<tr bgcolor="60c0c0"><td><font color="ffffff">21:24:29.515     0000: 01 07 10 00                                     ....</font></td></tr>
<tr bgcolor="408080"><td><font color="ffffff">21:24:29.518 Incoming Dump:</font></td></tr>
<tr bgcolor="408080"><td><font color="ffffff">21:24:29.518     0000: 04 0e 04 01 07 10 01                            .......</font></td></tr>
<tr bgcolor="fff7fa"><td><font color="006400">21:24:29.518 --</font></td></tr>
<tr bgcolor="fff7fa"><td><font color="006400">21:24:29.518 Packet "HCI_Command_Complete_Read_Country_Code_Event", Opcode 0x1007</font></td></tr>
<tr bgcolor="fff7fa"><td><font color="006400">21:24:29.518 Parameters:</font></td></tr>
<tr bgcolor="fff7fa"><td><font color="006400">21:24:29.518 | Number HCI commands : 0x01</font></td></tr>
<tr bgcolor="fff7fa"><td><font color="006400">21:24:29.518 | Command Opcode      : 0x1007</font></td></tr>
<tr bgcolor="fff7fa"><td><font color="006400">21:24:29.518 | Status              : 0x01 (Unknown HCI Command)</font></td></tr>
<tr bgcolor="fff7fa"><td><font color="006400">21:24:29.518 | Country Code        : 0x36</font></td></tr>
<tr bgcolor="ffc0a0"><td><font color="000000">21:24:29.518 ERROR - Packet Size. Got: 7 (0x07), Expected: 8 (0x08)</font></td></tr>
<tr bgcolor="ffc0a0"><td><font color="000000">21:24:29.519 ERROR - Status mismatch. Expected: 0x00,  Got: 0x01 (Unknown HCI Command)</font></td></tr>
<tr bgcolor="ffc0a0"><td><font color="000000">21:24:29.519 ERRORed Line (15): Wait_HCI_Command_Complete_Read_Country_Code_Event 5000, any, Any, 0x00, 0x00</font></td></tr>
<tr bgcolor="ffffff"><td><font color="000000">21:24:29.519 --</font></td></tr>
<tr bgcolor="ffffff"><td><font color="000000">21:24:29.519 *** Script End ***</font></td></tr>
<tr bgcolor="ffffff"><td><font color="000000">21:24:31.798 *** Script Started: ***</font></td></tr>
<tr bgcolor="ffffe6"><td><font color="0000c0">21:24:31.798 --</font></td></tr>
<tr bgcolor="ffffe6"><td><font color="0000c0">21:24:31.798 Packet "HCI_Read_BD_ADDR", Opcode 0x1009</font></td></tr>
<tr bgcolor="60c0c0"><td><font color="ffffff">21:24:31.798 Outgoing Dump:</font></td></tr>
<tr bgcolor="60c0c0"><td><font color="ffffff">21:24:31.798     0000: 01 09 10 00                                     ....</font></td></tr>
<tr bgcolor="408080"><td><font color="ffffff">21:24:31.802 Incoming Dump:</font></td></tr>
<tr bgcolor="408080"><td><font color="ffffff">21:24:31.802     0000: 04 0e 0a 01 09 10 00 36 0e 37 b4 04 08          .......6.7...</font></td></tr>
<tr bgcolor="fff7fa"><td><font color="006400">21:24:31.802 --</font></td></tr>
<tr bgcolor="fff7fa"><td><font color="006400">21:24:31.802 Packet "HCI_Command_Complete_Read_BD_ADDR_Event", Opcode 0x1009</font></td></tr>
<tr bgcolor="fff7fa"><td><font color="006400">21:24:31.802 Parameters:</font></td></tr>
<tr bgcolor="fff7fa"><td><font color="006400">21:24:31.802 | Number HCI commands : 0x01</font></td></tr>
<tr bgcolor="fff7fa"><td><font color="006400">21:24:31.802 | Command Opcode      : 0x1009</font></td></tr>
<tr bgcolor="fff7fa"><td><font color="006400">21:24:31.802 | Status              : 0x00 (Success)</font></td></tr>
<tr bgcolor="fff7fa"><td><font color="006400">21:24:31.802 | BD Address          : "08:04:B4:37:0E:36"</font></td></tr>
<tr bgcolor="ffffe6"><td><font color="0000c0">21:24:31.802 --</font></td></tr>
<tr bgcolor="ffffe6"><td><font color="0000c0">21:24:31.802 Packet "HCI_Read_Country_Code", Opcode 0x1007</font></td></tr>
<tr bgcolor="60c0c0"><td><font color="ffffff">21:24:31.802 Outgoing Dump:</font></td></tr>
<tr bgcolor="60c0c0"><td><font color="ffffff">21:24:31.802     0000: 01 07 10 00                                     ....</font></td></tr>
<tr bgcolor="408080"><td><font color="ffffff">21:24:31.805 Incoming Dump:</font></td></tr>
<tr bgcolor="408080"><td><font color="ffffff">21:24:31.805     0000: 04 0e 04 01 07 10 01                            .......</font></td></tr>
<tr bgcolor="fff7fa"><td><font color="006400">21:24:31.805 --</font></td></tr>
<tr bgcolor="fff7fa"><td><font color="006400">21:24:31.805 Packet "HCI_Command_Complete_Read_Country_Code_Event", Opcode 0x1007</font></td></tr>
<tr bgcolor="fff7fa"><td><font color="006400">21:24:31.805 Parameters:</font></td></tr>
<tr bgcolor="fff7fa"><td><font color="006400">21:24:31.805 | Number HCI commands : 0x01</font></td></tr>
<tr bgcolor="fff7fa"><td><font color="006400">21:24:31.805 | Command Opcode      : 0x1007</font></td></tr>
<tr bgcolor="fff7fa"><td><font color="006400">21:24:31.805 | Status              : 0x01 (Unknown HCI Command)</font></td></tr>
<tr bgcolor="fff7fa"><td><font color="006400">21:24:31.805 | Country Code        : 0x00</font></td></tr>
<tr bgcolor="ffc0a0"><td><font color="000000">21:24:31.805 ERROR - Packet Size. Got: 7 (0x07), Expected: 8 (0x08)</font></td></tr>
<tr bgcolor="ffc0a0"><td><font color="000000">21:24:31.805 ERROR - Status mismatch. Expected: 0x00,  Got: 0x01 (Unknown HCI Command)</font></td></tr>
<tr bgcolor="ffc0a0"><td><font color="000000">21:24:31.805 ERRORed Line (15): Wait_HCI_Command_Complete_Read_Country_Code_Event 5000, any, Any, 0x00, 0x00</font></td></tr>
<tr bgcolor="ffffff"><td><font color="000000">21:24:31.805 --</font></td></tr>
<tr bgcolor="ffffff"><td><font color="000000">21:24:31.805 *** Script End ***</font></td></tr>
<tr bgcolor="ffffff"><td><font color="000000">21:24:40.802 *** Script Started: ***</font></td></tr>
<tr bgcolor="ffffe6"><td><font color="0000c0">21:24:40.802 --</font></td></tr>
<tr bgcolor="ffffe6"><td><font color="0000c0">21:24:40.802 Packet "HCI_Read_BD_ADDR", Opcode 0x1009</font></td></tr>
<tr bgcolor="60c0c0"><td><font color="ffffff">21:24:40.802 Outgoing Dump:</font></td></tr>
<tr bgcolor="60c0c0"><td><font color="ffffff">21:24:40.802     0000: 01 09 10 00                                     ....</font></td></tr>
<tr bgcolor="408080"><td><font color="ffffff">21:24:40.806 Incoming Dump:</font></td></tr>
<tr bgcolor="408080"><td><font color="ffffff">21:24:40.806     0000: 04 0e 0a 01 09 10 00 36 0e 37 b4 04 08          .......6.7...</font></td></tr>
<tr bgcolor="fff7fa"><td><font color="006400">21:24:40.806 --</font></td></tr>
<tr bgcolor="fff7fa"><td><font color="006400">21:24:40.806 Packet "HCI_Command_Complete_Read_BD_ADDR_Event", Opcode 0x1009</font></td></tr>
<tr bgcolor="fff7fa"><td><font color="006400">21:24:40.806 Parameters:</font></td></tr>
<tr bgcolor="fff7fa"><td><font color="006400">21:24:40.806 | Number HCI commands : 0x01</font></td></tr>
<tr bgcolor="fff7fa"><td><font color="006400">21:24:40.806 | Command Opcode      : 0x1009</font></td></tr>
<tr bgcolor="fff7fa"><td><font color="006400">21:24:40.806 | Status              : 0x00 (Success)</font></td></tr>
<tr bgcolor="fff7fa"><td><font color="006400">21:24:40.806 | BD Address          : "08:04:B4:37:0E:36"</font></td></tr>
<tr bgcolor="ffffe6"><td><font color="0000c0">21:24:40.806 --</font></td></tr>
<tr bgcolor="ffffe6"><td><font color="0000c0">21:24:40.806 Packet "HCI_Read_Country_Code", Opcode 0x1007</font></td></tr>
<tr bgcolor="60c0c0"><td><font color="ffffff">21:24:40.806 Outgoing Dump:</font></td></tr>
<tr bgcolor="60c0c0"><td><font color="ffffff">21:24:40.806     0000: 01 07 10 00                                     ....</font></td></tr>
<tr bgcolor="408080"><td><font color="ffffff">21:24:40.809 Incoming Dump:</font></td></tr>
<tr bgcolor="408080"><td><font color="ffffff">21:24:40.809     0000: 04 0e 04 01 07 10 01                            .......</font></td></tr>
<tr bgcolor="fff7fa"><td><font color="006400">21:24:40.809 --</font></td></tr>
<tr bgcolor="fff7fa"><td><font color="006400">21:24:40.809 Packet "HCI_Command_Complete_Read_Country_Code_Event", Opcode 0x1007</font></td></tr>
<tr bgcolor="fff7fa"><td><font color="006400">21:24:40.809 Parameters:</font></td></tr>
<tr bgcolor="fff7fa"><td><font color="006400">21:24:40.809 | Number HCI commands : 0x01</font></td></tr>
<tr bgcolor="fff7fa"><td><font color="006400">21:24:40.809 | Command Opcode      : 0x1007</font></td></tr>
<tr bgcolor="fff7fa"><td><font color="006400">21:24:40.809 | Status              : 0x01 (Unknown HCI Command)</font></td></tr>
<tr bgcolor="fff7fa"><td><font color="006400">21:24:40.809 | Country Code        : 0x36</font></td></tr>
<tr bgcolor="ffc0a0"><td><font color="000000">21:24:40.809 ERROR - Packet Size. Got: 7 (0x07), Expected: 8 (0x08)</font></td></tr>
<tr bgcolor="ffc0a0"><td><font color="000000">21:24:40.809 ERROR - Status mismatch. Expected: 0x00,  Got: 0x01 (Unknown HCI Command)</font></td></tr>
<tr bgcolor="ffc0a0"><td><font color="000000">21:24:40.809 ERRORed Line (15): Wait_HCI_Command_Complete_Read_Country_Code_Event 5000, any, Any, 0x00, 0x00</font></td></tr>
<tr bgcolor="ffffff"><td><font color="000000">21:24:40.809 --</font></td></tr>
<tr bgcolor="ffffff"><td><font color="000000">21:24:40.809 *** Script End ***</font></td></tr>
<tr bgcolor="ffffff"><td><font color="000000">21:24:53.469 *** Script Started: ***</font></td></tr>
<tr bgcolor="ffffe6"><td><font color="0000c0">21:24:53.469 --</font></td></tr>
<tr bgcolor="ffffe6"><td><font color="0000c0">21:24:53.469 Packet "HCI_Read_BD_ADDR", Opcode 0x1009</font></td></tr>
<tr bgcolor="60c0c0"><td><font color="ffffff">21:24:53.469 Outgoing Dump:</font></td></tr>
<tr bgcolor="60c0c0"><td><font color="ffffff">21:24:53.469     0000: 01 09 10 00                                     ....</font></td></tr>
<tr bgcolor="408080"><td><font color="ffffff">21:24:53.472 Incoming Dump:</font></td></tr>
<tr bgcolor="408080"><td><font color="ffffff">21:24:53.472     0000: 04 0e 0a 01 09 10 00 36 0e 37 b4 04 08          .......6.7...</font></td></tr>
<tr bgcolor="fff7fa"><td><font color="006400">21:24:53.472 --</font></td></tr>
<tr bgcolor="fff7fa"><td><font color="006400">21:24:53.472 Packet "HCI_Command_Complete_Read_BD_ADDR_Event", Opcode 0x1009</font></td></tr>
<tr bgcolor="fff7fa"><td><font color="006400">21:24:53.472 Parameters:</font></td></tr>
<tr bgcolor="fff7fa"><td><font color="006400">21:24:53.472 | Number HCI commands : 0x01</font></td></tr>
<tr bgcolor="fff7fa"><td><font color="006400">21:24:53.472 | Command Opcode      : 0x1009</font></td></tr>
<tr bgcolor="fff7fa"><td><font color="006400">21:24:53.472 | Status              : 0x00 (Success)</font></td></tr>
<tr bgcolor="fff7fa"><td><font color="006400">21:24:53.472 | BD Address          : "08:04:B4:37:0E:36"</font></td></tr>
<tr bgcolor="ffc0a0"><td><font color="000000">21:24:53.473 ERROR - Unknown 'Handle'</font></td></tr>
<tr bgcolor="ffc0a0"><td><font color="000000">21:24:53.473 ERRORed Line (17): Send_HCI_Read_RSSI Handle</font></td></tr>
<tr bgcolor="ffffff"><td><font color="000000">21:24:53.473 --</font></td></tr>
<tr bgcolor="ffffff"><td><font color="000000">21:24:53.473 *** Script End ***</font></td></tr>
<tr bgcolor="ffffff"><td><font color="000000">21:25:01.994 *** Script Started: ***</font></td></tr>
<tr bgcolor="ffffe6"><td><font color="0000c0">21:25:01.995 --</font></td></tr>
<tr bgcolor="ffffe6"><td><font color="0000c0">21:25:01.995 Packet "HCI_Read_BD_ADDR", Opcode 0x1009</font></td></tr>
<tr bgcolor="60c0c0"><td><font color="ffffff">21:25:01.995 Outgoing Dump:</font></td></tr>
<tr bgcolor="60c0c0"><td><font color="ffffff">21:25:01.995     0000: 01 09 10 00                                     ....</font></td></tr>
<tr bgcolor="408080"><td><font color="ffffff">21:25:01.998 Incoming Dump:</font></td></tr>
<tr bgcolor="408080"><td><font color="ffffff">21:25:01.998     0000: 04 0e 0a 01 09 10 00 36 0e 37 b4 04 08          .......6.7...</font></td></tr>
<tr bgcolor="fff7fa"><td><font color="006400">21:25:01.998 --</font></td></tr>
<tr bgcolor="fff7fa"><td><font color="006400">21:25:01.998 Packet "HCI_Command_Complete_Read_BD_ADDR_Event", Opcode 0x1009</font></td></tr>
<tr bgcolor="fff7fa"><td><font color="006400">21:25:01.998 Parameters:</font></td></tr>
<tr bgcolor="fff7fa"><td><font color="006400">21:25:01.998 | Number HCI commands : 0x01</font></td></tr>
<tr bgcolor="fff7fa"><td><font color="006400">21:25:01.998 | Command Opcode      : 0x1009</font></td></tr>
<tr bgcolor="fff7fa"><td><font color="006400">21:25:01.998 | Status              : 0x00 (Success)</font></td></tr>
<tr bgcolor="fff7fa"><td><font color="006400">21:25:01.998 | BD Address          : "08:04:B4:37:0E:36"</font></td></tr>
<tr bgcolor="ffffe6"><td><font color="0000c0">21:25:01.998 --</font></td></tr>
<tr bgcolor="ffffe6"><td><font color="0000c0">21:25:01.998 Packet "HCI_Read_Local_Version_Information", Opcode 0x1001</font></td></tr>
<tr bgcolor="60c0c0"><td><font color="ffffff">21:25:01.998 Outgoing Dump:</font></td></tr>
<tr bgcolor="60c0c0"><td><font color="ffffff">21:25:01.998     0000: 01 01 10 00                                     ....</font></td></tr>
<tr bgcolor="408080"><td><font color="ffffff">21:25:02.002 Incoming Dump:</font></td></tr>
<tr bgcolor="408080"><td><font color="ffffff">21:25:02.002     0000: 04 0e 0c 01 01 10 00 07 00 00 07 0d 00 1a 9a    ...............</font></td></tr>
<tr bgcolor="fff7fa"><td><font color="006400">21:25:02.002 --</font></td></tr>
<tr bgcolor="fff7fa"><td><font color="006400">21:25:02.002 Packet "HCI_Command_Complete_Read_Local_Version_Information_Event", Opcode 0x1001</font></td></tr>
<tr bgcolor="fff7fa"><td><font color="006400">21:25:02.002 Parameters:</font></td></tr>
<tr bgcolor="fff7fa"><td><font color="006400">21:25:02.002 | Number HCI commands : 0x01</font></td></tr>
<tr bgcolor="fff7fa"><td><font color="006400">21:25:02.002 | Command Opcode      : 0x1001</font></td></tr>
<tr bgcolor="fff7fa"><td><font color="006400">21:25:02.002 | Status              : 0x00 (Success)</font></td></tr>
<tr bgcolor="fff7fa"><td><font color="006400">21:25:02.002 | HCI Version         : 0x07</font></td></tr>
<tr bgcolor="fff7fa"><td><font color="006400">21:25:02.002 | HCI Revision        : 0x0000</font></td></tr>
<tr bgcolor="fff7fa"><td><font color="006400">21:25:02.002 | LMP Version         : 0x07</font></td></tr>
<tr bgcolor="fff7fa"><td><font color="006400">21:25:02.002 | Manufacturer Name   : 0x000d (Texas Instruments Inc.)</font></td></tr>
<tr bgcolor="fff7fa"><td><font color="006400">21:25:02.002 | LMP Subversion      : 0x9a1a</font></td></tr>
<tr bgcolor="ffffff"><td><font color="000000">21:25:02.004 --</font></td></tr>
<tr bgcolor="ffffff"><td><font color="000000">21:25:02.004 *** Script End ***</font></td></tr>
<tr bgcolor="ffffff"><td><font color="000000">21:25:17.655 *** Script Started: ***</font></td></tr>
<tr bgcolor="ffffe6"><td><font color="0000c0">21:25:17.655 --</font></td></tr>
<tr bgcolor="ffffe6"><td><font color="0000c0">21:25:17.655 Packet "HCI_Read_BD_ADDR", Opcode 0x1009</font></td></tr>
<tr bgcolor="60c0c0"><td><font color="ffffff">21:25:17.655 Outgoing Dump:</font></td></tr>
<tr bgcolor="60c0c0"><td><font color="ffffff">21:25:17.655     0000: 01 09 10 00                                     ....</font></td></tr>
<tr bgcolor="408080"><td><font color="ffffff">21:25:17.659 Incoming Dump:</font></td></tr>
<tr bgcolor="408080"><td><font color="ffffff">21:25:17.659     0000: 04 0e 0a 01 09 10 00 36 0e 37 b4 04 08          .......6.7...</font></td></tr>
<tr bgcolor="fff7fa"><td><font color="006400">21:25:17.659 --</font></td></tr>
<tr bgcolor="fff7fa"><td><font color="006400">21:25:17.659 Packet "HCI_Command_Complete_Read_BD_ADDR_Event", Opcode 0x1009</font></td></tr>
<tr bgcolor="fff7fa"><td><font color="006400">21:25:17.659 Parameters:</font></td></tr>
<tr bgcolor="fff7fa"><td><font color="006400">21:25:17.659 | Number HCI commands : 0x01</font></td></tr>
<tr bgcolor="fff7fa"><td><font color="006400">21:25:17.659 | Command Opcode      : 0x1009</font></td></tr>
<tr bgcolor="fff7fa"><td><font color="006400">21:25:17.659 | Status              : 0x00 (Success)</font></td></tr>
<tr bgcolor="fff7fa"><td><font color="006400">21:25:17.659 | BD Address          : "08:04:B4:37:0E:36"</font></td></tr>
<tr bgcolor="ffffe6"><td><font color="0000c0">21:25:17.659 --</font></td></tr>
<tr bgcolor="ffffe6"><td><font color="0000c0">21:25:17.659 Packet "HCI_Read_Local_Version_Information", Opcode 0x1001</font></td></tr>
<tr bgcolor="60c0c0"><td><font color="ffffff">21:25:17.659 Outgoing Dump:</font></td></tr>
<tr bgcolor="60c0c0"><td><font color="ffffff">21:25:17.659     0000: 01 01 10 00                                     ....</font></td></tr>
<tr bgcolor="408080"><td><font color="ffffff">21:25:17.663 Incoming Dump:</font></td></tr>
<tr bgcolor="408080"><td><font color="ffffff">21:25:17.663     0000: 04 0e 0c 01 01 10 00 07 00 00 07 0d 00 1a 9a    ...............</font></td></tr>
<tr bgcolor="fff7fa"><td><font color="006400">21:25:17.663 --</font></td></tr>
<tr bgcolor="fff7fa"><td><font color="006400">21:25:17.663 Packet "HCI_Command_Complete_Read_Local_Version_Information_Event", Opcode 0x1001</font></td></tr>
<tr bgcolor="fff7fa"><td><font color="006400">21:25:17.663 Parameters:</font></td></tr>
<tr bgcolor="fff7fa"><td><font color="006400">21:25:17.663 | Number HCI commands : 0x01</font></td></tr>
<tr bgcolor="fff7fa"><td><font color="006400">21:25:17.663 | Command Opcode      : 0x1001</font></td></tr>
<tr bgcolor="fff7fa"><td><font color="006400">21:25:17.663 | Status              : 0x00 (Success)</font></td></tr>
<tr bgcolor="fff7fa"><td><font color="006400">21:25:17.663 | HCI Version         : 0x07</font></td></tr>
<tr bgcolor="fff7fa"><td><font color="006400">21:25:17.663 | HCI Revision        : 0x0000</font></td></tr>
<tr bgcolor="fff7fa"><td><font color="006400">21:25:17.663 | LMP Version         : 0x07</font></td></tr>
<tr bgcolor="fff7fa"><td><font color="006400">21:25:17.663 | Manufacturer Name   : 0x000d (Texas Instruments Inc.)</font></td></tr>
<tr bgcolor="fff7fa"><td><font color="006400">21:25:17.663 | LMP Subversion      : 0x9a1a</font></td></tr>
<tr bgcolor="ffffe6"><td><font color="0000c0">21:25:17.665 --</font></td></tr>
<tr bgcolor="ffffe6"><td><font color="0000c0">21:25:17.665 Packet "HCI_Read_Buffer_Size", Opcode 0x1005</font></td></tr>
<tr bgcolor="60c0c0"><td><font color="ffffff">21:25:17.665 Outgoing Dump:</font></td></tr>
<tr bgcolor="60c0c0"><td><font color="ffffff">21:25:17.665     0000: 01 05 10 00                                     ....</font></td></tr>
<tr bgcolor="408080"><td><font color="ffffff">21:25:17.669 Incoming Dump:</font></td></tr>
<tr bgcolor="408080"><td><font color="ffffff">21:25:17.669     0000: 04 0e 0b 01 05 10 00 fd 03 b4 04 00 04 00       ..............</font></td></tr>
<tr bgcolor="fff7fa"><td><font color="006400">21:25:17.669 --</font></td></tr>
<tr bgcolor="fff7fa"><td><font color="006400">21:25:17.669 Packet "HCI_Command_Complete_Read_Buffer_Size_Event", Opcode 0x1005</font></td></tr>
<tr bgcolor="fff7fa"><td><font color="006400">21:25:17.669 Parameters:</font></td></tr>
<tr bgcolor="fff7fa"><td><font color="006400">21:25:17.669 | Number HCI commands        : 0x01</font></td></tr>
<tr bgcolor="fff7fa"><td><font color="006400">21:25:17.669 | Command Opcode             : 0x1005</font></td></tr>
<tr bgcolor="fff7fa"><td><font color="006400">21:25:17.669 | Status                     : 0x00 (Success)</font></td></tr>
<tr bgcolor="fff7fa"><td><font color="006400">21:25:17.669 | ACL Data Packet Length     : 0x03fd</font></td></tr>
<tr bgcolor="fff7fa"><td><font color="006400">21:25:17.669 | SCO Data Packet Length     : 0xb4</font></td></tr>
<tr bgcolor="fff7fa"><td><font color="006400">21:25:17.669 | Total Num ACL Data Packets : 0x0004</font></td></tr>
<tr bgcolor="fff7fa"><td><font color="006400">21:25:17.669 | Total Num SCO Data Packets : 0x0004</font></td></tr>
<tr bgcolor="ffc0a0"><td><font color="000000">21:25:17.669 ERROR - ACL Data Packet Length mismatch. Expected: 0x0000,  Got: 0x03fd</font></td></tr>
<tr bgcolor="ffc0a0"><td><font color="000000">21:25:17.669 ERRORed Line (24): Wait_HCI_Command_Complete_Read_Buffer_Size_Event 5000, any, HCI_Read_Buffer_Size, 0x00, 0x0000, 0x00, 0x0000, 0x0000</font></td></tr>
<tr bgcolor="ffffff"><td><font color="000000">21:25:17.669 --</font></td></tr>
<tr bgcolor="ffffff"><td><font color="000000">21:25:17.669 *** Script End ***</font></td></tr>
<tr bgcolor="ffffff"><td><font color="000000">21:27:09.670 *** Script Started: ***</font></td></tr>
<tr bgcolor="ffffe6"><td><font color="0000c0">21:27:09.670 --</font></td></tr>
<tr bgcolor="ffffe6"><td><font color="0000c0">21:27:09.670 Packet "HCI_Read_BD_ADDR", Opcode 0x1009</font></td></tr>
<tr bgcolor="60c0c0"><td><font color="ffffff">21:27:09.670 Outgoing Dump:</font></td></tr>
<tr bgcolor="60c0c0"><td><font color="ffffff">21:27:09.670     0000: 01 09 10 00                                     ....</font></td></tr>
<tr bgcolor="408080"><td><font color="ffffff">21:27:09.673 Incoming Dump:</font></td></tr>
<tr bgcolor="408080"><td><font color="ffffff">21:27:09.673     0000: 04 0e 0a 01 09 10 00 36 0e 37 b4 04 08          .......6.7...</font></td></tr>
<tr bgcolor="fff7fa"><td><font color="006400">21:27:09.673 --</font></td></tr>
<tr bgcolor="fff7fa"><td><font color="006400">21:27:09.673 Packet "HCI_Command_Complete_Read_BD_ADDR_Event", Opcode 0x1009</font></td></tr>
<tr bgcolor="fff7fa"><td><font color="006400">21:27:09.673 Parameters:</font></td></tr>
<tr bgcolor="fff7fa"><td><font color="006400">21:27:09.673 | Number HCI commands : 0x01</font></td></tr>
<tr bgcolor="fff7fa"><td><font color="006400">21:27:09.673 | Command Opcode      : 0x1009</font></td></tr>
<tr bgcolor="fff7fa"><td><font color="006400">21:27:09.673 | Status              : 0x00 (Success)</font></td></tr>
<tr bgcolor="fff7fa"><td><font color="006400">21:27:09.673 | BD Address          : "08:04:B4:37:0E:36"</font></td></tr>
<tr bgcolor="ffffff"><td><font color="000000">21:27:09.673 --</font></td></tr>
<tr bgcolor="ffffff"><td><font color="000000">21:27:09.673 *** Script End ***</font></td></tr>
</TABLE>
</FONT>
</BODY>
</HTML>
