Part Number: CC2340R5-Q1
Other Parts Discussed in Thread: SYSCONFIG, LP-XDS110ET
Hi teams,
We are testing the frequency on the CC2340, and we know that we can tune the Q1 & Q2 values with SmartRF 8.
We have some questions about the test interface.
In the RF test column "HFXT cap-array tuning", what is the meaning of "disable" & "Use board settings"
1. Does "disable" mean CC2340 does not use the integrated capacitors and needs external load capacitors?
2. Does "Use board settings" mean CC2340 uses the setting with what we set in SysConfig?
If we set Q1 = Q2 = 0 in SysConfig, should the frequency using "Use board settings" be the same as "Enable" with Q1 = Q2 = 0?
Many thanks,
Jesse
