Hi All,
I would like to oscillate a crystal unit, input the oscillation signal, and use it for an RTC inside a microcontroller, using the circuit diagram as shown in the attached figure (crystal unit circuit).
In this case, there is an item “RTC XOSC LF Compensation” on the syscfg setting,
I believe this is to compensate the frequency of the external crystal oscillator.
By checking the “Custom RTC XOSC Coefficients” setting, you can set the coefficients required for the correction.
How do I set the value of this coefficient?
I looked at this document but could not understand it.
Ito
