Is CC2340R5 support Long Range? Is there any measured data for TI? How far can you usually go, 100 meters to 200 meters? Do you have specific data and test data?
Hi Tonyx,
What PHY are you using and are you using the maximum TX output power of +8 dBm? Distance supported will depend on the RF stack being used, the quality of the antenna and matching circuit, and physical barriers (such as walls) or other interferers (such as channel noise or traffic).
Ryan
I addition to Ryans feedback, you can explore the range of various PHYs with the following tool:
RF-RANGE-ESTIMATOR Calculation tool | TI.com
Is there a specific application you are targeting?
