CC2340R5: Impossibile to read memory after erase
Part Number: CC2340R5
After connecting to the device in question, I performed the chip erase.
From that moment it is no longer possible to read the memory but I can only do erase and blank check.
Do I have to change any setting to be able to read the erased device?
Thank you,
  • Hi Cinqueonce,
    The SACI JTAG interface will fail to read device memory if it detects that the device is blank.  Since a blank device check confirms that flash memory contents are all 0xFF, what is your reason for needing to read an erased device?
    Ryan
