Part Number: CC2745R10-Q1
Other Parts Discussed in Thread: UNIFLASH, SYSCONFIG
Hello;
In fact, we are trying to use the OAD on-chip project to test it and flash the board with the new image.
So, we referred to " https://dev.ti.com/tirex/explore/node?node=A__ASIs1Z.Aaff8jdoi4xRghw__SIMPLELINK-ACADEMY-CC23XX__gsUPh5j__LATEST" in following the steps,
First, we have built the oad_onchip project.
Second, we select our board on Uniflash, and choose the images as described on picture below. As, we have understanded from previous questions that we can use the oad_onchip_sb.hex file instead of the mcuboot_oad_onchip.hex file.
For the load address, we choose that address because the other addresses as mentioned on the .map file does not work we always have an overlapping problem.
We succeed in flashing the board with the 3 images with that load address as shown in picture below.
But the problem here is that when we try to use BTOOL to flash the new image (we have upgraded the image version to 2.0 and rename the new image to oad_onchip_v2.bin),
Now, we click on send, it goes for device reset, then it stuck into establish connection, then the failure to download OAD download.
So, could you please help us in this subject because it has been a while facing this issue, can you also tell us if our steps are right or if we are missing ones.
Thank you for your response.
Best regards;
