Part Number: CC2340R5
While debugging Local variables shows 0, or 'no location, value may have been optimized out'
How can I see the values ?
CCS 20 on Windows 10
Version: 20.1.1.8__1.7.1
Default VS Code API: 1.92.2
XDS110 debugger
XDS110 debugger
Hello Itamar Cohen,
I hope you are doing well. We can try changing the optimization level of the local project (right click on the project, go-to properties and under the Arm Compiler click on Optimization) from default "z" to "0"; which should remove the optimization, this will make your project larger though.
Alex F
Hi Alex
This really helped.
Is there a way to see how much Free/Used RAM and Flash the project consume ?
Hello Itamar Cohen,
Yes, click on "view" and then on "memory allocation"
Alex F
