Part Number: CC2745R10-Q1
Let us ask you a question about the VIMS module registers' FLWS1T, FLWS2T, and PTRMC0.
In the CC27XX Technical Reference Manual (swcu195a.pdf), Chapter 8.2.3.3-5 only provides a brief description of the registers.
Since there is no other detailed explanation, it is unclear how to use it.
SDK 9.10 also does not have an API related to these registers.
What is the role of the VIMS registers' FLWS1T, FLWS2T, and PTRMC0?
If I leave the reset value and do not change the settings, will it work without problems?
What are the use cases that require configuration changes?
What is the optimal setting point for normal operation?
