Part Number: LP-EM-CC2340R53
HI,TI
I followed the documentation(https://dev.ti.com/tirex/explore/node?node=A__Afldgct56i7LcbjG6qeBYw__SIMPLELINK-ACADEMY-CC23XX__gsUPh5j__8.10.05.00 How to Add Bluetooth Low Energy (LE) Over the Air Download (OAD) to Basic Example) to integrate OAD into the TI\simplelink_lowpower_f3_sdk_9_12_00_19\examples\rtos\LP_EM_CC2340R53\ble\key_node example code.
However, after completing the integration, I encountered an issue: whenever I use Btool to establish a Bluetooth connection and then initiate the OAD process, the Bluetooth connection disconnects due to a timeout—ultimately causing the OAD to fail.
Could you tell me what additional modifications or configurations are needed, beyond following the steps in this document, to successfully complete the OAD?
