Part Number: CC2340R5
Other Parts Discussed in Thread: SYSCONFIG,
Hi, TI Team.
I observed the startup waveform of HFXT on the LP-EM-CC2340R5. After testing with SDK versions 7.20, 8.40, and 9.10, I found that there are differences in the startup waveform between SDK 7.20 and SDK 8.40 and later. Below is the probing of the X48N pin at power-on. I am using the sample code rfCarrierWave, with LF RCOSC selected in SysConfig and all other settings set to default.
In SDK 7.20, there is a change approximately 100µs after the XTAL startup begins, but this change is not present in SDK 8.40 and later.
Why is this waveform observed in SDK 7.20? What are the differences compared to SDK 8.40 and later?
SDK 7.20
SDK 9.10
Best Regards.
