CC2745R10-Q1: Channel Sounding example - no data being printed
Part Number: CC2745R10-Q1
Hi Forum,
Since the disccussion is  marked as resolved i am starting a new thread.
The field team shared modified car_node and key_node examples intended for the CC2745R10-Q1 launchpad. Currently, we have only one CC2745R10 board. On the key node side, we are using a CC2340R53 launchpad with the default key_node example from the SDK.
When both car_node and key_node are flashed on CC27xx (i.e., both running on CC2745R10), the distance data is received correctly. However, when using the CC2340R53-based key_node example, the car node connects successfully but does not output any distance data.
Could you clarify why the CC2340R53-based key_node is not working with the modified car_node?
Vaibhav
    The thread you mentioned is still open, and my colleague Eshaan is still supporting your questions.
    Please refrain from opening multiple threads for the same question. I am going to close this ticket, please continue the question on the prior thread.
    Isaac
