Part Number: CC2745R10-Q1
Hello, TI support team
I am currently testing the Bluetooth Channel Sounding feature for distance measurement and have encountered an issue for which I would like to request technical support.
My current development environment is as follows:
SDK: SimpleLink Low Power F3 SDK v9.14.02.16
car_node:
CC2745 LaunchPad
Dual antenna configuration
key_node:
CC2340R53 LaunchPad
or a custom CC2340R53 hardware board
The observed behavior is described below:
When the key_node remains stationary, the continuously measured distance values are relatively stable with only small fluctuations.
For example:
The initial measured distance is around 160
Subsequent readings remain stable around this value
However, if the key_node is slightly moved and then placed back to the original position, the measured distance changes significantly, even though the physical position is nearly unchanged.
For example:
The initial stable value is around 160
After moving and placing it back, the stable value may become around 100
The new readings are also stable, but with a noticeable offset from the previous value
Currently observed characteristics:
The readings are stable over short periods when stationary
After repositioning, the measurement settles to a different stable value
Even after returning the device to the original location, the measured distance does not recover to the previous value
I would like to ask the following questions:
Is this behavior considered normal for the current Channel Sounding implementation?
Are there any possible solutions or recommended debugging methods for this issue?
Thank you for your support.
Jiahao Fan.
