Part Number: CC2340R5
We have recently encountered an issue that is likely related to something during the manufacturing process that results in the CC2340R53 on our pcb drawing an absurd amount of current. Likely, something internally on the MCU is getting damaged. For example, our application normally averages between 10-20uA during operation, but units that exhibit this state end up drawing anywhere from hundreds of uA to hundreds of mA on average instead. The application seemingly works like normal otherwise when put on a test fixture.
I was wondering if there were any helpful registers that could be monitored to see what internally has happened to the MCU. One note is that if the problematic MCU is swapped out for a known good one, the current draw returns to normal, so we have narrowed it down to something happening to the MCU.
Alex Trujillo
