Part Number: CC2340R5
CC2340R5 module is power on in I.MX93 linux.
In mobile bluetooth scan device is visible, able to connect and pair. But CC2340R5 module is not visible in windows laptop bluetooth scan.
Thank you for reaching out. I have a couple of questions to help figure out what is going on.
1. Is the CC2340R5 advertising? Are you able to see it advertising using the simplelink connect mobile app?
2. What kind of devices are you seeing in the scan device feature of your laptop?
Some desktop OSs restrict the types of advertised devices that show up in the scan results. I don't know if your version of Linux does this, but Windows and MacOs do.
Jan
Hi
Yes CC2340R5 is in advertising. Yes device in visible in simplelink connect mobile app.
want to check the file transfer from mobile app or windows laptop app to CC2340R5 module (linux terminal)
Is it possible to transfer the file instated of data from Mobile Application to CC2340R5
Understood. The mobile app is able to transfer OAD images for OAD update, and this should be re-useable and can be modified to send file transfers. It will require significant changes on the mobile app and the application but should be posible.
Jan
