Part Number: CC2340R5
I designed lpn node using CC2340r5MODA. During provisioning I publish battery model to be transmitted periodically. After provisioning everything works correctly. Battery information is correctly periodically transmitted, but after cycling power model publish information is lost, probably never storded to flash or never extract back, but address to publish is rememberd. Everything else is working correctly.
What do I need to do to to make it work correctly. Publish address for battery model is correct and rememberd duriong cycling power (it used to send other command messages from lpn node), but battery information never gets published after cycling power.
Michael Ostrovsky
