Part Number: CC2744R7-Q1
Hi Forum,
I am working with the CC2744R7 target. After changing the target device in SysConfig, I flashed the basic_ble example. I also tried flashing the HSM image before programming the application binary.
While debugging, I observed that the application enters Exception_handlerSpin() after the following call sequence:
vTaskStartScheduler() → vStartFirstTask() → xPortStartScheduler() → vTaskStartScheduler() → Exception_handlerSpin()
I have reproduced the same behavior with both SDK versions 9.20.00.81 and 9.14.02.16.
It appears that all BLE example projects in these SDK versions exhibit the same issue when built for the CC2744R7 target.
Could you please let me know if any additional configuration or initialization is required for the CC2744R7, or if there are any known limitations with the current SDK support for this device?
Vaibhav
