LAUNCHXL-CC2640R2: Help with CC2650 Launch Pad
Part Number: LAUNCHXL-CC2640R2
Other Parts Discussed in Thread: CC2640, CC2650
Hi TI support team,
I am trying to use CC2650 LaunchPad with SmartRF Flash Programmer 2 to flash the CC2640 on my PCB board. However, I am running into this error.
I have removed all jumper pins except the GND.
________________________________________________________________________________________________
>Initiate access to target: COM6 using 2-pin cJTAG.
>No response from device. Device may not be in bootloader mode. Reset device and try again.
If problem persists, check connection and baud rate.
>Connecting over serial bootloader failed: No response from device. Device may not be in bootloader mode. Reset device and try again.
>Failed to create device object.
  • Hi Joshua,
    Thank you for reaching out.
    May I ask why you have removed all the jumpers except ground. The required pins in cJTAG-mode are VDDS, GND, RESET, TCK and TMS. Kindly, connect these jumpers and try again.
    Faizan Habib
