A related question is a question created from another question. When the related question is created, it will be automatically linked to the original question.
The simplelink sdk specifies a simplelink connect on the iphone for bluetooth debug. Am only able to find simplelink strarter. Are these interchangable?
Thank you for reaching out. SimpleLink Connect and SimpleLink Starter are two separate apps, SimpleLink Starter is the older, legacy app, while SimpleLink Connect is the current, actively supported app for working with TI's BLE devices.
The most likely reason you're not seeing it on your App Store is an iOS version compatibility issue. If your device's iOS version is older than the minimum version required by the app, the App Store will not show it in search results or allow installation.
If your iOS version doesn't meet the minimum requirement and you're unable to update it, you could use an alternative generic BLE scanner/connection app in the meantime. Keep in mind, though, that these third-party apps won't support TI-specific profiles and features, so your experience may be limited compared to using SimpleLink Connect.
