Is there any way to determine if there were any packet lost on the sender side, using the EtherMind BT stack, used in the CC2560/PAN1315 dev kit examples?
Adam.
Adam.
Migule,
Just to see that I got it right, I send a packet, and the errors I might get are internal errors, and the SPP_SEND_CNF event success or fail, is just an internal event saying, I've [sent/failed to send] the packet, regardless if the peer got the packet or not.
Adam.
Miguel,
After long time learning the subject, I've transmitted around 500k packets so far, and I must say I disagree with your input. My research has shown that there is no case that a SPP_SEND_CNF is returned successful, and a packet not arriving on the other end, which makes me believe that there is a packet validation process in the BT stack, and that all packets which are indicated as successful indeed reach the other peer.
Adam.
