error while building GlucoseCollector\CC2540
Other Parts Discussed in Thread: CC2540
when i build GlucoseCollector\CC2540, the following error happen:
Error[e104]: Failed to fit all segments into specified ranges. Problem discovered in segment XDATA_N. Unable to place 2 block(s) (0xc02 byte(s) total) in 0xb76 byte(s) of memory. The problem occurred while processing the segment placement
command "-P(XDATA)XDATA_N=_XDATA_START-_XDATA_END", where at the moment of placement the available memory ranges were "XDATA:138a-1eff"
Error while running Linker
It looks like some memory problem.
I'm building this example for my own board, the lcd driver need about 0.5k bytes pixel data, will this cause the problem?
