I want to get the RSSI value when peripheral has sent a notification to center device. How could I do?
Is there anything method to get the RSSI value?
Thanks in advance.
Thanks in advance.
Take a look at simpleBleCentral running on SmartRF board project. This example will show RSSI on LCD after connecting and pressing the joystick down. The example uses a callback function which is called when RSSI is updated. To trigger RSSI updates, you need to set the RSSI read period - set the parameter GAPROLE_RSSI_READ_RATE.
BR,
-Greg
First, I am sorry to my incomplete description.
My project is designed as a peripheral. so I can not use "GAPCentralRole_StartRssi()" function to read the RSSI value.
Is there any function to be called in BLE stacks? Thanks.
