cc2540 simpleBLEcentral
Other Parts Discussed in Thread: CC2541
Hello everyone,
I need to know how notification or indication is handled in simpleBLEcentral project. All I have found is this function,  GATT_RegisterForInd( simpleBLETaskId );  // Register to receive incoming ATT Indications/Notifications. I have to make use of the data sent through notification.
Can anyone tell me how to access notification data?
maharjanbk
  • Hi Maharjanbk,
    Have a look at the simpleBLECentralProcessGATTMsg function, found in simpleBLECentral. That's where you'll fetch your GATT messages, such as notifications and indications.
    Best Regards
  • Hi Nick,
    Thank you for your prompt response.
    I could see there is a value assignment statement  uint8 valueRead = pMsg->msg.readRsp.value[0];  in the function you described. This is just one byte data but notifications could be several bytes long.
    Just wanted to know your opinion, is it that if I am sending multiple byte notification, the size should be fixed and I need to keep track of bytes that I have received?
    Please look into my I2C slave on cc2541 post also when you have time.
    maharjanbk
    So, you can check the length of the notification with pMsg->msg.handleValueNoti.len and access the data by pMsg->msg.handleValueNoti.value for example. Might be that looping through value[i] until i=len is you solution.
    Best Regards
  • Hi Nick,
    Thank you very much for the response. I will try out this suggestion.
    maharjanbk
  • hii...
    can i register for single characteristic's notification..??? plz tell me which api shud i use??/
  • Hi thereMaharjanbk ,
    I am newbie to ble and RTOS ! ,so please bear with me on this. In BlEperipheral we have configured notification for Characteristic 4 right? and in the periodic event the value gets updated( correct me if i am wrong ) .But why are we unable to see the change in central? Or why is it not getting printed in the LCD???
