Problem in GAP profile (when connecting ) under Windows 7 and newer.
Hi Stonestreet,
My device export SPP profile and should transfert data with Window 7 computer.
The problem is, after receiving message "atLinkKeyRequest", I don't get anything else, and the stack is in "unkown state" since it is waiting for a connection or a pincode message.
In my console log, I get these traces:
[debug]
[debug]_open_stack().
[debug]Bluetooth Stack ID: 1
[debug]Device Chipset: 4.0
[debug]BD_ADDR: 0x0018343A7A6A
[debug]HCI_Reconfigure_Driver(921600): Success.
[debug]spp set config succedded...
[debug]Server Opened: 1.
[debug]Change buffer succedded.
[debug]Succedded to open spp port
[debug]atLinkKeyRequest
[debug]GAP_Authentication_Response succedded
.... and nothing else...
Can you help me please ?
Mikael
  • Hi Mikael,
    SSO should be able to help. BTW, what procedure are you following on the Windows side and did you make any significant changes to your code?
  • Hi Mikael,
    Could you outline the steps you used and any changes you made so that we can reproduce the issue from our side?
    Stonestreet One
  • Hi Stonestreet ,
    Here attached, my "gap.c" and "spp.c" file ...
    Mikael
    #include "SS1BTPS.h"             /* Main SS1 Bluetooth Stack Header.          */
    #include "BTPSKRNL.h"            /* BTPS Kernel Header.                       */
    #include "cardicell_board.h"
    #include "cardicell_app.h"
    #include "spp.h"
    #include "EHCILL.h"              /* eHCILL Implementation Header.             */
    #include "utils.h"
    #include "gap.h"
    #define REQUEST_LINK_KEY_TABLE          1
    #define SEND_LINK_KEY                   2
    extern unsigned int BluetoothStackID;
    static st_gap_context gap_context ;
    static char debug_buffer[256];
    static BD_ADDR_t gap_null_bd_addr;
    typedef enum
      enGAP_INIT = 0,
      enGAP_TEMPO,
      enGAP_SENDPINCODE
    }enState;
    static unsigned int _gap_tempo;
    static enState _gap_state;
    // The following string table is used to map the API I/O Capabilities values to
    // an easily displayable string.
    static BTPSCONST char *IOCapabilitiesStrings[] =
       "Display Only",
       "Display Yes/No",
       "Keyboard Only",
       "No Input/Output"
    void _gap_request_linkkey( unsigned char src_port,  unsigned char dest_port ,unsigned int size )
      unsigned int checksum = 0;
      unsigned char msg_type = REQUEST_LINK_KEY_TABLE;
      checksum += (size + sizeof(msg_type));
      checksum += src_port;
      checksum += dest_port;
      checksum += msg_type;
      msg_send_header( src_port, dest_port, size );
      drv_main_interface_transmit_buffer( (const char*)msg_type, sizeof(char) );
      drv_main_interface_transmit_buffer( (const char*)&checksum, sizeof(unsigned int) );
    void _gap_send_linkkey( char * ptr,  unsigned char src_port,  unsigned char dest_port ,unsigned int size )
      unsigned int checksum ;
      unsigned char msg_type = SEND_LINK_KEY;
      checksum = (size + sizeof(msg_type));
      checksum += calculate_checksum( ptr, size );
      drv_main_interface_transmit_buffer( (const char*)ptr, sizeof(LinkKeyInfo_t) );
    static void _set_tempo(  unsigned int delay )
      _gap_tempo = delay;
      _gap_state = enGAP_TEMPO;
    // The following function is responsible for issuing a GAP
    // Authentication Response with a PIN Code value specified via the
    // input parameter.  This function returns zero on successful
    // execution and a negative value on all errors.
    static int _pin_code_response( unsigned int bt_stack_id )
      int                                  result;
      int                                  ret_val;
      PIN_Code_t                           pin_code;
      GAP_Authentication_Information_t     GAP_Authentication_Information;
      // First, check that valid Bluetooth Stack ID exists.
      if( !bt_stack_id )
        return INVALID_STACK_ID_ERROR;
      // First, check to see if there is an on-going Pairing operation active.
      if(!COMPARE_BD_ADDR(gap_context.currentRemoteAddr, gap_null_bd_addr))
        if( BTPS_StringLength( BT_PIN_CODE ) <= sizeof(PIN_Code_t) )
          // Initialize the PIN code.
          ASSIGN_PIN_CODE(pin_code, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0);
          BTPS_MemCopy(&pin_code, BT_PIN_CODE, BTPS_StringLength(BT_PIN_CODE));
          // Populate the response structure.
          GAP_Authentication_Information.GAP_Authentication_Type      = atPINCode;
          GAP_Authentication_Information.Authentication_Data_Length   = BTPS_StringLength(BT_PIN_CODE);
          GAP_Authentication_Information.Authentication_Data.PIN_Code = pin_code;
          // Submit the Authentication Response.
          result = GAP_Authentication_Response(bt_stack_id, gap_context.currentRemoteAddr, &GAP_Authentication_Information);
          // Check the return value for the submitted command for success.
          if(!result)
            // Operation was successful, inform the user.
            drv_debug_log("GAP_Authentication_Response(), Pin Code Response Success.\r\n");
            // Flag success to the caller.
            ret_val = 0;
          else
            // Inform the user that the Authentication Response was
            // not successful.
            drv_debug_log("GAP_Authentication_Response() Failed\n\r");
            ret_val = FUNCTION_ERROR;
          // Flag that there is no longer a current Authentication
          // procedure in progress.
          ASSIGN_BD_ADDR(gap_context.currentRemoteAddr, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00);
        else
          // One or more of the necessary parameters is/are invalid.
          drv_debug_log("PINCodeResponse [PIN Code]");
          ret_val = INVALID_PARAMETERS_ERROR;
      else
        // There is not currently an on-going authentication operation, inform
        // the user of this error condition.
        drv_debug_log("PIN Code Authentication Response: Authentication not in progress.\r\n");
      return ret_val;
    static void _process_remote_name_request_event( GAP_Event_Data_t * GAP_Event_Data )
      GAP_Remote_Name_Event_Data_t     *GAP_Remote_Name_Event_Data;
      // Bluetooth Stack has responded to a previously issued Remote Name Request that was issued.
      GAP_Remote_Name_Event_Data = GAP_Event_Data->Event_Data.GAP_Remote_Name_Event_Data;
      if(GAP_Remote_Name_Event_Data)
        if(GAP_Remote_Name_Event_Data->Remote_Name)
          //TODO: Notify main interface
          strncpy( gap_context.remoteDeviceNameBuffer, GAP_Remote_Name_Event_Data->Remote_Name, MAX_NAME_LENGTH );
          gap_context.remoteDeviceNameBuffer[MAX_NAME_LENGTH-1]=0;
          SprintF(gap_context.unsolicited_buffer,"remote device: %s\n\r", gap_context.remoteDeviceNameBuffer);
          //cmd_line_put_unsolicited_response((const char *)gap_context.unsolicited_buffer);
          drv_debug_log((const char *)gap_context.unsolicited_buffer);
    static void _process_authentication_event( GAP_Event_Data_t * GAP_Event_Data )
      int i, result;
      GAP_IO_Capability_t               remote_io_capability;
      Boolean_t                         oob_data;
      Boolean_t                         mitm;
      switch(GAP_Event_Data->Event_Data.GAP_Authentication_Event_Data->GAP_Authentication_Event_Type)
      case atLinkKeyRequest:
        drv_debug_log("\r\natLinkKeyRequest\r\n");
        // Setup the authentication information response structure.
        GAP_Authentication_Information.GAP_Authentication_Type    = atLinkKey;
        GAP_Authentication_Information.Authentication_Data_Length = 0;
        // See if we have stored a Link Key for the specified device.
        for(i=0;i< MAX_SUPPORTED_LINK_KEYS;i++)
          if(COMPARE_BD_ADDR(gap_context.LinkKeyInfo[i].BD_ADDR,
                             GAP_Event_Data->Event_Data.GAP_Authentication_Event_Data->Remote_Device))
            /* Link Key information stored, go ahead and    */
            /* respond with the stored Link Key.            */
            GAP_Authentication_Information.Authentication_Data_Length   = sizeof(Link_Key_t);
            GAP_Authentication_Information.Authentication_Data.Link_Key = gap_context.LinkKeyInfo[i].LinkKey;
            break;
        // Submit the authentication response.
        if(!GAP_Authentication_Response(BluetoothStackID,
                                             GAP_Event_Data->Event_Data.GAP_Authentication_Event_Data->Remote_Device,
                                             &GAP_Authentication_Information))
          drv_debug_log("GAP_Authentication_Response succedded\n\r");
        else
          drv_debug_log("GAP_Authentication_Response error\n\r");
        break;
      case atPINCodeRequest:
        // A pin code request event occurred, first display the BD_ADD of the
        // remote device requesting the pin.
        drv_debug_log("\r\natPINCodeRequest\r\n");
       // Note the current Remote BD_ADDR that is requesting the PIN Code.
       gap_context.currentRemoteAddr = GAP_Event_Data->Event_Data.GAP_Authentication_Event_Data->Remote_Device;
    #if 0
        //Send a PIN Code Response.
        _pin_code_response( BluetoothStackID );
    #else
        _set_tempo( 3000 );
    #endif
        break;
      case atAuthenticationStatus:
        // An authentication status event occurred, display all relevant information.
        SprintF(debug_buffer,"\r\natAuthenticationStatus: %d.\r\n",
                GAP_Event_Data->Event_Data.GAP_Authentication_Event_Data->Authentication_Event_Data.Authentication_Status);
        drv_debug_log(debug_buffer);
        // Flag that there is no longer a current Authentication procedure in progress.
        break;
      case atLinkKeyCreation:
          // A link key creation event occurred, first display the remote device that caused this event
          drv_debug_log("atLinkKeyCreation\r\n");
          for(i=0; i< MAX_SUPPORTED_LINK_KEYS ;i++)
              drv_debug_log("Already in the memory\r\n");
              gap_context.current_linkkey_index = i;
              return;
          if(gap_context.nb_key_in_table < MAX_SUPPORTED_LINK_KEYS)
            gap_context.LinkKeyInfo[gap_context.nb_key_in_table].BD_ADDR = GAP_Event_Data->Event_Data.GAP_Authentication_Event_Data->Remote_Device;
            gap_context.LinkKeyInfo[gap_context.nb_key_in_table].LinkKey = GAP_Event_Data->Event_Data.GAP_Authentication_Event_Data->Authentication_Event_Data.Link_Key_Info.Link_Key;
            gap_context.current_linkkey_index = gap_context.nb_key_in_table;
            drv_debug_log("The link key table is full, remove last element to store last linkkey.\n\r");
            // Send to upper board the link key.
            _gap_send_linkkey((char *)&gap_context.LinkKeyInfo[gap_context.nb_key_in_table], 2, 14 , sizeof(LinkKeyInfo_t));
            gap_context.nb_key_in_table++;
          else
            gap_context.LinkKeyInfo[MAX_SUPPORTED_LINK_KEYS-1].BD_ADDR = GAP_Event_Data->Event_Data.GAP_Authentication_Event_Data->Remote_Device;
            gap_context.LinkKeyInfo[MAX_SUPPORTED_LINK_KEYS-1].LinkKey = GAP_Event_Data->Event_Data.GAP_Authentication_Event_Data->Authentication_Event_Data.Link_Key_Info.Link_Key;
            _gap_send_linkkey((char *)&gap_context.LinkKeyInfo[MAX_SUPPORTED_LINK_KEYS-1], 2, 14 , sizeof(LinkKeyInfo_t));
          drv_debug_log("Link Key sent.\r\n");
        break;
      case atIOCapabilityRequest:
        drv_debug_log("\n\ratIOCapabilityRequest\r\n");
        // Setup the Authentication Information Response structure.
        GAP_Authentication_Information.GAP_Authentication_Type                                      = atIOCapabilities;
        GAP_Authentication_Information.Authentication_Data_Length                                   = sizeof(GAP_IO_Capabilities_t);
        GAP_Authentication_Information.Authentication_Data.IO_Capabilities.IO_Capability            = (GAP_IO_Capability_t)gap_context.io_capability;
        GAP_Authentication_Information.Authentication_Data.IO_Capabilities.MITM_Protection_Required = gap_context.mitm_protection;
        GAP_Authentication_Information.Authentication_Data.IO_Capabilities.OOB_Data_Present         = gap_context.oob_support;
        result = GAP_Authentication_Response(BluetoothStackID,
        // Check the result of the submitted command.
        if(!result)
          drv_debug_log("Auth success");
        else
          drv_debug_log("Auth error");
        break;
      case atIOCapabilityResponse:
        drv_debug_log("\n\ratIOCapabilityResponse.\r\n");
        remote_io_capability = GAP_Event_Data->Event_Data.GAP_Authentication_Event_Data->Authentication_Event_Data.IO_Capabilities.IO_Capability;
        mitm               = (Boolean_t)GAP_Event_Data->Event_Data.GAP_Authentication_Event_Data->Authentication_Event_Data.IO_Capabilities.MITM_Protection_Required;
        oob_data           = (Boolean_t)GAP_Event_Data->Event_Data.GAP_Authentication_Event_Data->Authentication_Event_Data.IO_Capabilities.OOB_Data_Present;
        SprintF(debug_buffer,"Capabilities: %s%s%s\r\n", IOCapabilitiesStrings[remote_io_capability], ((mitm)?", MITM":""), ((oob_data)?", OOB Data":""));
        break;
      case atUserConfirmationRequest:
        drv_debug_log("atUserConfirmationRequest !!! I don't know what I need to responds\n\r");
        break;
      case atPasskeyRequest:
        drv_debug_log("atPasskeyRequest\r\n");
        // Note the current Remote BD_ADDR that is requesting the Passkey.
        // Inform the user that they will need to respond with a Passkey Response.
        drv_debug_log("Respond with: PassKeyResponse\r\n");
        break;
      case atRemoteOutOfBandDataRequest:
        drv_debug_log("atRemoteOutOfBandDataRequest\r\n");
        // This application does not support OOB data so respond with a data length
        // of Zero to force a negative reply.
        GAP_Authentication_Information.GAP_Authentication_Type    = atOutOfBandData;
        result = GAP_Authentication_Response(BluetoothStackID, GAP_Event_Data->Event_Data.GAP_Authentication_Event_Data->Remote_Device, &GAP_Authentication_Information);
        if(!result)
          drv_debug_log("GAP_Authentication_Response succedded");
        else
          drv_debug_log("GAP_Authentication_Response failed\n\r");
        break;
      case atPasskeyNotification:
        drv_debug_log("atPasskeyNotification\r\n");
        SprintF(debug_buffer,"Passkey Value: %lu\r\n", GAP_Event_Data->Event_Data.GAP_Authentication_Event_Data->Authentication_Event_Data.Numeric_Value);
        break;
      case atKeypressNotification:
        drv_debug_log("atKeypressNotification\r\n");
        SprintF(debug_buffer,"Keypress: %d\r\n", (int)GAP_Event_Data->Event_Data.GAP_Authentication_Event_Data->Authentication_Event_Data.Keypress_Type);
        break;
      default:
        drv_debug_log("Un-handled Auth. Event.\r\n");
        break;
       /*                         Event Callbacks                           */
       /* The following function is for the GAP Event Receive Data Callback.*/
       /* This function will be called whenever a Callback has been         */
       /* registered for the specified GAP Action that is associated with   */
       /* the Bluetooth Stack.  This function passes to the caller the GAP  */
       /* Event Data of the specified Event and the GAP Event Callback      */
       /* Parameter that was specified when this Callback was installed.    */
       /* The caller is free to use the contents of the GAP Event Data ONLY */
       /* in the context of this callback.  If the caller requires the Data */
       /* for a longer period of time, then the callback function MUST copy */
       /* the data into another Data Buffer.  This function is guaranteed   */
       /* NOT to be invoked more than once simultaneously for the specified */
       /* installed callback (i.e.  this function DOES NOT have be          */
       /* reentrant).  It Needs to be noted however, that if the same       */
       /* Callback is installed more than once, then the callbacks will be  */
       /* called serially.  Because of this, the processing in this function*/
       /* should be as efficient as possible.  It should also be noted that */
       /* this function is called in the Thread Context of a Thread that the*/
       /* User does NOT own.  Therefore, processing in this function should */
       /* be as efficient as possible (this argument holds anyway because   */
       /* other GAP Events will not be processed while this function call is*/
       /* outstanding).                                                     */
       /* * NOTE * This function MUST NOT Block and wait for events that    */
       /*          can only be satisfied by Receiving other GAP Events.  A  */
       /*          Deadlock WILL occur because NO GAP Event Callbacks will  */
       /*          be issued while this function is currently outstanding.  */
    void BTPSAPI gap_event_callback(unsigned int BluetoothStackID, GAP_Event_Data_t *GAP_Event_Data, unsigned long CallbackParameter)
       // First, check to see if the required parameters appear to be semi-valid.
       if((BluetoothStackID) && (GAP_Event_Data))
          switch(GAP_Event_Data->Event_Data_Type)
          case etInquiry_Result:
            // No Inquiry should be done in our application.
            drv_debug_log("\n\retInquiry_Result\n\r");
            break;
          case etInquiry_Entry_Result:
            drv_debug_log("\n\retInquiry_Entry_Result\n\r");
            break;
          case etAuthentication:
            // An authentication event occurred, determine which type of authentication event occurred.
            _process_authentication_event( GAP_Event_Data );
            break;
          case etRemote_Name_Result:
            _process_remote_name_request_event( GAP_Event_Data );
            break;
          case etEncryption_Change_Result:
            drv_debug_log("\n\retEncryption_Change_Result\n\r");
    #if 0
            BD_ADDRToStr(GAP_Event_Data->Event_Data.GAP_Encryption_Mode_Event_Data->Remote_Device, Callback_BoardStr);
            Display(("\r\netEncryption_Change_Result for %s, Status: 0x%02X, Mode: %s.\r\n", Callback_BoardStr,
                         GAP_Event_Data->Event_Data.GAP_Encryption_Mode_Event_Data->Encryption_Change_Status,
                         ((GAP_Event_Data->Event_Data.GAP_Encryption_Mode_Event_Data->Encryption_Mode == emDisabled)?"Disabled": "Enabled")));
    #endif
            break;
          default:
            //An unknown/unexpected GAP event was received.
            SprintF(debug_buffer,"\r\nUnknown Event: %d.\r\n", GAP_Event_Data->Event_Data_Type);
            break;
    // The following function is responsible for placing the Local
    // Bluetooth Device into Connectable Mode.  Once in this mode the
    // Device will respond to Page Scans from other Bluetooth Devices.
    // This function requires that a valid Bluetooth Stack ID exists
    // before running.  This function returns zero on success and a
    // negative value if an error occurred.
    static int _set_connectable( unsigned int bt_stack_id )
      // First, check that a valid Bluetooth Stack ID exists.
      if( !bt_stack_id )
      // Attempt to set the attached Device to be Connectable.
      if( GAP_Set_Connectability_Mode( bt_stack_id , cmConnectableMode) )
        return -1;
      else
        return 0;
    // Bluetooth Device into General Discoverablity Mode.  Once in this
    // mode the Device will respond to Inquiry Scans from other Bluetooth
    // Devices.  This function requires that a valid Bluetooth Stack ID
    // exists before running.  This function returns zero on successful
    // execution and a negative value if an error occurred.
    static int _set_discoverable( unsigned int bt_stack_id )
      if( !bt_stack_id )
      if( GAP_Set_Discoverability_Mode(bt_stack_id, dmGeneralDiscoverableMode, 0) )
        return -1;
      else
        return 0;
    // The following function is responsible for placing the local
    // Bluetooth device into Pairable mode.  Once in this mode the device
    // will response to pairing requests from other Bluetooth devices.
    // This function returns zero on successful execution and a negative
    // value on all errors.
    static int _set_pairable( unsigned int bt_stack_id )
      if( !bt_stack_id )
      // Attempt to set the attached device to be pairable.
      if(GAP_Set_Pairability_Mode( bt_stack_id , pmPairableMode ))
        return -1;
      // The device has been set to pairable mode, now register an Authentication
      // Callback to handle the Authentication events
      if(GAP_Register_Remote_Authentication(bt_stack_id, gap_event_callback, (unsigned long)0))
        return -1;
      return 0;
    static void _init_gap_value( void )
      ASSIGN_BD_ADDR( gap_null_bd_addr , 0x00, 0x00, 0x00, 0x00, 0x00, 0x00);
      // Initialize the default Secure Simple Pairing parameters.
      gap_context.io_capability     =       DEFAULT_IO_CAPABILITY;
      gap_context.oob_support       =       FALSE;
      gap_context.mitm_protection   =       DEFAULT_MITM_PROTECTION;
      _gap_request_linkkey(GAP_SRC_PORT,GAP_DEST_PORT,0);
      gap_context.nb_key_in_table = 0;
      gap_context.current_linkkey_index = 0;
      _gap_tempo = 0;
      _gap_state = enGAP_INIT;
    int gap_init( unsigned int bt_stack_id )
      if( !bt_stack_id )
      _init_gap_value( );
      if(_set_connectable( BluetoothStackID ) < 0)
        return -1;
      if( _set_discoverable( BluetoothStackID ) < 0)
        return -1;
      if( _set_pairable( BluetoothStackID ) < 0)
        return -1;
      return 0;
    // The following function is responsible for setting the name of the
    // local Bluetooth Device to a specified name.  This function returns
    // zero on successful execution and a negative value on all errors.
    int gap_set_local_name( unsigned int bt_stack_id, char * arg )
       if( !bt_stack_id )
       if( !arg )
         return INVALID_PARAMETERS_ERROR;
       if(strlen( arg ) > MAX_NAME_LENGTH )
         arg[MAX_NAME_LENGTH-1] = 0;
       if(GAP_Set_Local_Device_Name( bt_stack_id , arg ))
         return FUNCTION_ERROR;
       return 0;
    // The following function is responsible for querying the Bluetooth
    // Device Name of the specified remote Bluetooth Device.  This
    // function returns zero on successful execution and a negative value
    // on all errors.
    int gap_get_remote_name( unsigned int bt_stack_id , BD_ADDR_t BD_ADDR )
      if( !bt_stack_id )
      // Attempt to submit the command.
      if(GAP_Query_Remote_Device_Name(bt_stack_id, BD_ADDR , gap_event_callback, (unsigned long)0))
        return -1;
      return 0;
    void gap_base_time_1ms( void )
      if(_gap_tempo)
        _gap_tempo--;
    void gap_task_handler( void * param )
      switch( _gap_state )
      case enGAP_INIT:
        //nothing to do...
          break;
      case enGAP_TEMPO:
        if(_gap_tempo == 0)
          _gap_state = enGAP_SENDPINCODE;
          break;
      case enGAP_SENDPINCODE:
          break;
    void gap_push_bt_link_key( char * ptr )
      if(gap_context.nb_key_in_table >= MAX_SUPPORTED_LINK_KEYS)
        return;
      BTPS_MemCopy(&gap_context.LinkKeyInfo[gap_context.nb_key_in_table],ptr,sizeof(LinkKeyInfo_t));
    #include "spp.h"
    #include "gap.h"
    #include "utils.h"
    #include "EHCILL.h"
    #define MAX_SPP_PORT    16
       /* Internal Variables to this Module (Remember that all variables    */
       /* declared static are initialized to 0 automatically by the         */
       /* compiler as part of standard C/C++).                              */
    unsigned int        BluetoothStackID;        /* Variable which holds the Handle */
                                                        /* of the opened Bluetooth Protocol*/
                                                        /* Stack.                          */
    static int                 SerialPortID;            /* Variable which contains the     */
                                                        /* Handle of the most recent       */
                                                        /* SPP Port that was opened.       */
    static int                 ServerPortID[MAX_SPP_PORT];            /* Variable which contains the     */
                                                        /* Handle of the SPP Server Port   */
                                                        /* that was opened.                */
    static Word_t              Connection_Handle;       /* Holds the Connection Handle of  */
                                                        /* the most recent SPP Connection. */
    Boolean_t           Connected;               /* Variable which flags whether or */
                                                        /* not there is currently an active*/
                                                        /* connection.                     */
    static DWord_t             SPPServerSDPHandle[MAX_SPP_PORT];      /* Variable used to hold the Serial*/
                                                        /* Port Service Record of the      */
                                                        /* Serial Port Server SDP Service  */
                                                        /* Record.                         */
    static LinkKeyInfo_t       LinkKeyInfo[MAX_SUPPORTED_LINK_KEYS]; /* Variable holds     */
                                                        /* BD_ADDR <-> Link Keys for       */
                                                        /* pairing.                        */
    static BD_ADDR_t           SelectedBD_ADDR;         /* Holds address of selected Device*/
    static BoardStr_t          Callback_BoardStr;       /* Holds a BD_ADDR string in the   */
                                                        /* Callbacks.                      */
    static BD_ADDR_t        remoteConnectedDevice;
    static char             _closed_port_indication;
    static char             BluetoothAddress[15]; // Address of the chipset in string format.
    static char             board_name[32]; // published SPP name.
    static unsigned long    spp_tempo;
    #ifndef DMA_APPROACH
    static void _send_data( void );
    #endif
    static unsigned char _need_to_close_stack;
    static enSPP_STATE _spp_state = SPP_UNINIT;
       /* The following string table is used to map HCI Version information */
       /* to an easily displayable version string.                          */
    static BTPSCONST char *HCIVersionStrings[] =
       "1.0b",
       "1.1",
       "1.2",
       "2.0",
       "2.1",
       "3.0",
       "4.0",
       "Unknown (greater 4.0)"
    #define NUM_SUPPORTED_HCI_VERSIONS              (sizeof(HCIVersionStrings)/sizeof(char *) - 1)
    #define SPP_BUFFER_SIZE         300
    // Internal function prototypes.
    static int _delete_link_key(BD_ADDR_t BD_ADDR);
    static int _set_config_params(Word_t MaximumFrameSize,
                                  unsigned int TransmitBufferSize ,
                                  unsigned int ReceiveBufferSize );
    static void _reset_spp_data( void );
    static int _set_baud_rate( double baudrate );
    static int _open_stack(HCI_DriverInformation_t *HCI_DriverInformation);
    static int _close_stack( void );
    static int _start_server( int comm_port );
    static int _open_server( unsigned int port );
    // BTPS Callback function prototypes.
    static void BTPSAPI SPP_Event_Callback(unsigned int BluetoothStackID,
                                           SPP_Event_Data_t *SPP_Event_Data,
                                           unsigned long CallbackParameter);
    static void BTPSAPI HCI_Event_Callback(unsigned int BluetoothStackID,
                                           HCI_Event_Data_t *HCI_Event_Data,
    // The following function is responsible for opening the SS1
    // Bluetooth Protocol Stack.  This function accepts a pre-populated
    // HCI Driver Information structure that contains the HCI Driver
    // Transport Information.  This function returns zero on successful
       int                        Result;
       int                        ret_val = 0;
       Byte_t                     Status;
       BD_ADDR_t                  BD_ADDR;
       HCI_Version_t              HCIVersion;
       L2CA_Link_Connect_Params_t L2CA_Link_Connect_Params;
       /* First check to see if the Stack has already been opened.          */
       if(!BluetoothStackID)
          /* Next, makes sure that the Driver Information passed appears to */
          /* be semi-valid.                                                 */
          if(HCI_DriverInformation)
             drv_debug_log("\r\n");
             drv_debug_log("_open_stack().\r\n");
             /* Initialize the Stack                                        */
             Result = BSC_Initialize(HCI_DriverInformation, 0);
             /* Next, check the return value of the initialization to see if*/
             /* it was successful.                                          */
             if(Result > 0)
                /* The Stack was initialized successfully, inform the user  */
                /* and set the return value of the initialization function  */
                /* to the Bluetooth Stack ID.                               */
                BluetoothStackID = Result;
                SprintF(debug_buffer,"Bluetooth Stack ID: %d\r\n", BluetoothStackID);
                if(!HCI_Version_Supported(BluetoothStackID, &HCIVersion))
                  SprintF(debug_buffer,"Device Chipset: %s\r\n", (HCIVersion <= NUM_SUPPORTED_HCI_VERSIONS)?HCIVersionStrings[HCIVersion]:HCIVersionStrings[NUM_SUPPORTED_HCI_VERSIONS]);
                /* Let's output the Bluetooth Device Address so that the    */
                /* user knows what the Device Address is.                   */
                if(!GAP_Query_Local_BD_ADDR(BluetoothStackID, &BD_ADDR))
                   BD_ADDRToStr(BD_ADDR, BluetoothAddress);
    				SprintF(debug_buffer,"BD_ADDR: %s\r\n", BluetoothAddress);
                /* Go ahead and allow Master/Slave Role Switch.             */
                L2CA_Link_Connect_Params.L2CA_Link_Connect_Request_Config  = cqAllowRoleSwitch;
                L2CA_Link_Connect_Params.L2CA_Link_Connect_Response_Config = csMaintainCurrentRole;
                L2CA_Set_Link_Connection_Configuration(BluetoothStackID, &L2CA_Link_Connect_Params);
                if(HCI_Command_Supported(BluetoothStackID, HCI_SUPPORTED_COMMAND_WRITE_DEFAULT_LINK_POLICY_BIT_NUMBER) > 0)
                   HCI_Write_Default_Link_Policy_Settings(BluetoothStackID, (HCI_LINK_POLICY_SETTINGS_ENABLE_MASTER_SLAVE_SWITCH|HCI_LINK_POLICY_SETTINGS_ENABLE_SNIFF_MODE), &Status);
                /* Delete all Stored Link Keys.                             */
                ASSIGN_BD_ADDR(BD_ADDR, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00);
                _delete_link_key(BD_ADDR);
             else
                /* The Stack was NOT initialized successfully, inform the   */
                /* user and set the return value of the initialization      */
                /* function to an error.                                    */
                drv_debug_log("Stack Init Failed");
                BluetoothStackID = 0;
                ret_val          = UNABLE_TO_INITIALIZE_STACK;
          else
             /* One or more of the necessary parameters are invalid.        */
       return(ret_val);
    // The following function is responsible for closing the SS1
    // Bluetooth Protocol Stack.  This function requires that the
    // Bluetooth Protocol stack previously have been initialized via the
    // _open_stack() function.  This function returns zero on successful
    static int _close_stack(void)
      // First check to see if the Stack has been opened.
      if(BluetoothStackID == 0)
        drv_debug_log(("error, BluetoothStackID is null.\r\n"));
        // A valid Stack ID does not exist, inform to user.
        return UNABLE_TO_INITIALIZE_STACK;
      // Simply close the Stack
      BSC_Shutdown(BluetoothStackID);
      // Free BTPSKRNL allocated memory.
      // We can keep BTPS initialized.
      //BTPS_DeInit();
      drv_debug_log(("Stack Shutdown.\r\n"));
      // Flag that the Stack is no longer initialized.
      return 0;
    // The following function is a utility function that exists to delete
    // the specified Link Key from the Local Bluetooth Device.  If a NULL
    // Bluetooth Device Address is specified, then all Link Keys will be
    // deleted.
    static int _delete_link_key( BD_ADDR_t BD_ADDR )
       int       Result;
       Byte_t    Status_Result;
       Word_t    Num_Keys_Deleted = 0;
       BD_ADDR_t NULL_BD_ADDR;
       Result = HCI_Delete_Stored_Link_Key(BluetoothStackID, BD_ADDR, TRUE, &Status_Result, &Num_Keys_Deleted);
       /* Any stored link keys for the specified address (or all) have been */
       /* deleted from the chip.  Now, let's make sure that our stored Link */
       /* Key Array is in sync with these changes.                          */
       /* First check to see all Link Keys were deleted.                    */
       ASSIGN_BD_ADDR(NULL_BD_ADDR, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00);
       if(COMPARE_BD_ADDR(BD_ADDR, NULL_BD_ADDR))
          BTPS_MemInitialize(LinkKeyInfo, 0, sizeof(LinkKeyInfo));
       else
          /* Individual Link Key.  Go ahead and see if know about the entry */
          /* in the list.                                                   */
          for(Result=0;(Result<sizeof(LinkKeyInfo)/sizeof(LinkKeyInfo_t));Result++)
             if(COMPARE_BD_ADDR(BD_ADDR, LinkKeyInfo[Result].BD_ADDR))
                LinkKeyInfo[Result].BD_ADDR = NULL_BD_ADDR;
                break;
       return(Result);
    // The following function is responsible for opening a Serial Port
    // Server on the Local Device.  This function opens the Serial Port
    // Server on the specified RFCOMM Channel.  This function returns
    // zero if successful, or a negative return value if an error
    // occurred.
       int  ret_val;
       char *ServiceName;
       if(port > MAX_SPP_PORT-1 )
       // First check to see if a valid Bluetooth Stack ID exists.
       if(BluetoothStackID)
          // Make sure that there is not already a Serial Port Server open.
          if(!ServerPortID[port])
             // Next, check to see if the parameters specified are valid.
             if( port > 0 )
                // Simply attempt to open an Serial Server, on RFCOMM Server Port 1.
                ret_val = SPP_Open_Server_Port(BluetoothStackID, port, SPP_Event_Callback, (unsigned long)0);
                /* If the Open was successful, then note the Serial Port    */
                /* Server ID.                                               */
                if(ret_val > 0)
                   /* Note the Serial Port Server ID of the opened Serial   */
                   /* Port Server.                                          */
                   ServerPortID[port] = ret_val;
                   // Create a Buffer to hold the Service Name.
                   if((ServiceName = BTPS_AllocateMemory(64)) != NULL)
                      /* The Server was opened successfully, now register a */
                      /* SDP Record indicating that an Serial Port Server   */
                      /* exists. Do this by first creating a Service Name.  */
                      BTPS_SprintF(ServiceName, "SPP port %d", port);
                      /* Now that a Service Name has been created try to    */
                      /* Register the SDP Record.                           */
                      ret_val = SPP_Register_SDP_Record(BluetoothStackID,
                                                        ServerPortID[port],
                                                        NULL,
                                                        ServiceName,
                                                        &SPPServerSDPHandle[port]);
                      /* If there was an error creating the Serial Port     */
                      /* Server's SDP Service Record then go ahead an close */
                      /* down the server an flag an error.                  */
                      if(ret_val < 0)
                        SprintF(debug_buffer,"Unable to Register Server SDP Record, Error = %d.\r\n", ret_val);
                        SPP_Close_Server_Port(BluetoothStackID, ServerPortID[port]);
                         /* Flag that there is no longer an Serial Port     */
                         /* Server Open.                                    */
                         ServerPortID[port] = 0;
                         /* Flag that we are no longer connected.           */
                         Connected    = FALSE;
                         ret_val      = UNABLE_TO_REGISTER_SERVER;
                      else
                        // Simply flag to the user that everything initialized correctly.
                        SprintF(debug_buffer,"Server Opened: %d.\r\n", port);
                        ret_val = 0;
                      // Free the Service Name buffer.
                      BTPS_FreeMemory(ServiceName);
                   else
                      drv_debug_log("Failed to allocate buffer to hold Service Name in SDP Record.\r\n");
    #ifdef __FIX_PACKET_LOSS__
                   if( SPP_Change_Buffer_Size(BluetoothStackID,ServerPortID[port], 512 , 512) >= 0)
                     drv_debug_log("Change buffer succedded.\n\r");
                   else
                     drv_debug_log("Change buffer failed.\n\r");
    #endif
                else
    				SprintF(debug_buffer,"Unable to Open Server on: %d, Error = %d.\r\n", port, ret_val);
             else
          else
             // A Server is already open, this program only supports one Server or Client at a time.                                 */
             drv_debug_log("Server already open.\r\n");
       else
          // No valid Bluetooth Stack ID exists.
          ret_val = INVALID_STACK_ID_ERROR;
       return(ret_val);
    // The following function is responsible for closing a Serial Port
    // Server that was previously opened via a successful call to the
    // OpenServer() function.  This function returns zero if successful
    // or a negative return error code if there was an error.
    int spp_close_server( unsigned char port )
      int ret_val = 0;
      if(port > MAX_SPP_PORT -1)
      if(BluetoothStackID <= 0)
      // If a Serial Port Server is already opened, then simply close it
      if(ServerPortID[port])
        /* If there is an SDP Service Record associated with the Serial*/
        /* Port Server then we need to remove it from the SDP Database.*/
        if(SPPServerSDPHandle[port])
          SPP_Un_Register_SDP_Record(BluetoothStackID, SerialPortID, SPPServerSDPHandle[port]);
          /* Flag that there is no longer an SDP Serial Port Server   */
          /* Record.                                                  */
          SPPServerSDPHandle[port] = 0;
        /* Finally close the Serial Port Server.                       */
        ret_val = SPP_Close_Server_Port(BluetoothStackID, ServerPortID[port]);
        if(ret_val < 0)
          drv_debug_log("SPP_Close_Server_Port failed\n");
        else
          ret_val = 0;
        /* Flag that there is no Serial Port Server currently open.    */
        SerialPortID         = 0;
        Connected    = FALSE;
        drv_gpio_clear_connected();
        drv_debug_log( "spp disconnected.\n\r" );
        drv_debug_log("Server Closed.\r\n");
      else
        drv_debug_log("NO Server open.\r\n");
      return(ret_val);
    // The following function is responsible for setting the current
    // configuration parameters that are used by SPP.  This function will
    // return zero on successful execution and a negative value on
    // errors.
       int                        ret_val;
       SPP_Configuration_Params_t SPPConfigurationParams;
       /* First check to see if the parameters required for the execution of*/
       /* this function appear to be semi-valid.                            */
             /* Parameters have been specified, go ahead and write them to  */
             /* the stack.                                                  */
             SPPConfigurationParams.MaximumFrameSize   = (unsigned int) MaximumFrameSize;
             SPPConfigurationParams.TransmitBufferSize = (unsigned int) TransmitBufferSize;
             SPPConfigurationParams.ReceiveBufferSize  = (unsigned int) ReceiveBufferSize;
             ret_val = SPP_Set_Configuration_Parameters(BluetoothStackID, &SPPConfigurationParams);
             if(ret_val >= 0)
    #if 0
                Display(("SPP_Set_Configuration_Parameters(): Success\r\n", ret_val));
                Display(("   MaximumFrameSize   : %d (0x%X)\r\n", SPPConfigurationParams.MaximumFrameSize, SPPConfigurationParams.MaximumFrameSize));
                Display(("   TransmitBufferSize : %d (0x%X)\r\n", SPPConfigurationParams.TransmitBufferSize, SPPConfigurationParams.TransmitBufferSize));
                Display(("   ReceiveBufferSize  : %d (0x%X)\r\n", SPPConfigurationParams.ReceiveBufferSize, SPPConfigurationParams.ReceiveBufferSize));
    #endif
                /* Flag success.                                            */
                ret_val = 0;
             else
    #if 0
                /* Error setting the current parameters.                    */
                Display(("SPP_Set_Configuration_Parameters(): Error %d.\r\n", ret_val));
    #endif
       else
       return(ret_val);
    //    The following thread is responsible for checking changing the
    //    current Baud Rate used to talk to the Radio.
    //    * NOTE * This function ONLY configures the Baud Rate for a TI
    //             Bluetooth chipset.
    static int _set_baud_rate( double new_baudrate )
       int                              ret_val;
       Byte_t                           Length;
       Byte_t                           Status;
       NonAlignedDWord_t                _BaudRate;
       union
          Byte_t                        Buffer[16];
          HCI_Driver_Reconfigure_Data_t DriverReconfigureData;
       } Data;
          /* Next check to see if the parameters required for the execution */
          /* of this function appear to be semi-valid.                      */
          if( new_baudrate > 0 )
                /* Write the Baud Rate.                                     */
                ASSIGN_HOST_DWORD_TO_LITTLE_ENDIAN_UNALIGNED_DWORD(&_BaudRate, new_baudrate);
                /* Next, write the command to the device.                   */
                Length  = sizeof(Data.Buffer);
                ret_val = HCI_Send_Raw_Command(BluetoothStackID, 0x3F, 0x0336, sizeof(NonAlignedDWord_t), (Byte_t *)&_BaudRate, &Status, &Length, Data.Buffer, TRUE);
                if((!ret_val) && (!Status))
                   /* We were successful, now we need to change the baud    */
                   /* rate of the driver.                                   */
                   BTPS_MemInitialize(&(Data.DriverReconfigureData), 0, sizeof(HCI_Driver_Reconfigure_Data_t));
                   Data.DriverReconfigureData.ReconfigureCommand = HCI_COMM_DRIVER_RECONFIGURE_DATA_COMMAND_CHANGE_PARAMETERS;
                   Data.DriverReconfigureData.ReconfigureData    = (void *)&_BaudRate;
                   ret_val = HCI_Reconfigure_Driver(BluetoothStackID, FALSE, &(Data.DriverReconfigureData));
                   if(ret_val >= 0)
    				   SprintF(debug_buffer,"HCI_Reconfigure_Driver(%lu): Success.\r\n", _BaudRate);
                      /* Flag success.                                      */
                      ret_val = 0;
                   else
    				   SprintF(debug_buffer,"HCI_Reconfigure_Driver(%lu): Failure %d.\r\n", _BaudRate, ret_val);
                else
    				/* Unable to write vendor specific command to chipset.   */
    				SprintF(debug_buffer,"HCI_Send_Raw_Command(%lu): Failure %d, %d.\r\n", _BaudRate, ret_val, Status);
          else
             drv_debug_log("SetBaudRate [BaudRate]");
       else
       return(ret_val);
       /* The following function is for an SPP Event Callback.  This        */
       /* function will be called whenever a SPP Event occurs that is       */
       /* associated with the Bluetooth Stack.  This function passes to the */
       /* caller the SPP Event Data that occurred and the SPP Event Callback*/
       /* The caller is free to use the contents of the SPP SPP Event Data  */
       /* ONLY in the context of this callback.  If the caller requires the */
       /* Data for a longer period of time, then the callback function MUST */
       /* copy the data into another Data Buffer.  This function is         */
       /* guaranteed NOT to be invoked more than once simultaneously for the*/
       /* specified installed callback (i.e.  this function DOES NOT have be*/
       /* another SPP Event will not be processed while this function call  */
       /* is outstanding).                                                  */
       /* * NOTE * This function MUST NOT Block and wait for Events that    */
       /*          can only be satisfied by Receiving SPP Event Packets.  A */
       /*          Deadlock WILL occur because NO SPP Event Callbacks will  */
    static void BTPSAPI SPP_Event_Callback(unsigned int BluetoothStackID, SPP_Event_Data_t *SPP_Event_Data, unsigned long CallbackParameter)
       int       ret_val = 0;
       static char  mybuffer[SPP_BUFFER_SIZE];
       unsigned int   lenghtRxSPPdata;
       unsigned int   currentLenghtRxSPP;
       /* **** SEE SPPAPI.H for a list of all possible event types.  This   */
       /* program only services its required events.                   **** */
       /* First, check to see if the required parameters appear to be       */
       /* semi-valid.                                                       */
       if((SPP_Event_Data) && (BluetoothStackID))
          /* The parameters appear to be semi-valid, now check to see what  */
          /* type the incoming event is.                                    */
          switch(SPP_Event_Data->Event_Data_Type)
             case etPort_Data_Indication:
               lenghtRxSPPdata = SPP_Event_Data->Event_Data.SPP_Data_Indication_Data->DataLength;
               while(lenghtRxSPPdata > 0)
                 if(lenghtRxSPPdata > SPP_BUFFER_SIZE)
                   currentLenghtRxSPP = SPP_Data_Read(BluetoothStackID, SerialPortID, SPP_BUFFER_SIZE, (Byte_t*)&mybuffer);
                 else
                   currentLenghtRxSPP = SPP_Data_Read(BluetoothStackID, SerialPortID, lenghtRxSPPdata, (Byte_t*)&mybuffer);
                 if(currentLenghtRxSPP > 0)
                     drv_main_interface_transmit_buffer( (const char*)mybuffer, currentLenghtRxSPP );
                     if(lenghtRxSPPdata > currentLenghtRxSPP)
                       lenghtRxSPPdata-= currentLenghtRxSPP;
                     else
                       lenghtRxSPPdata = 0;
                 else
               break;
             case etPort_Open_Indication:
                // A remote port is requesting a connection.
                BD_ADDRToStr(SPP_Event_Data->Event_Data.SPP_Open_Port_Indication_Data->BD_ADDR, Callback_BoardStr);
                SprintF(debug_buffer,"SPP Open Indication, ID: 0x%04X, Board: %s.\r\n", SPP_Event_Data->Event_Data.SPP_Open_Port_Indication_Data->SerialPortID, Callback_BoardStr);
                // Flag that we are now connected.
                Connected    = TRUE;
                remoteConnectedDevice.BD_ADDR0 = SPP_Event_Data->Event_Data.SPP_Open_Port_Indication_Data->BD_ADDR.BD_ADDR0;
                remoteConnectedDevice.BD_ADDR1 = SPP_Event_Data->Event_Data.SPP_Open_Port_Indication_Data->BD_ADDR.BD_ADDR1;
                remoteConnectedDevice.BD_ADDR2 = SPP_Event_Data->Event_Data.SPP_Open_Port_Indication_Data->BD_ADDR.BD_ADDR2;
                remoteConnectedDevice.BD_ADDR3 = SPP_Event_Data->Event_Data.SPP_Open_Port_Indication_Data->BD_ADDR.BD_ADDR3;
                remoteConnectedDevice.BD_ADDR4 = SPP_Event_Data->Event_Data.SPP_Open_Port_Indication_Data->BD_ADDR.BD_ADDR4;
                remoteConnectedDevice.BD_ADDR5 = SPP_Event_Data->Event_Data.SPP_Open_Port_Indication_Data->BD_ADDR.BD_ADDR5;
                /* Save the Serial Port ID for later use.                   */
                SerialPortID = SPP_Event_Data->Event_Data.SPP_Open_Port_Indication_Data->SerialPortID;
                /* Query the connection handle.                             */
                ret_val = GAP_Query_Connection_Handle(BluetoothStackID, SPP_Event_Data->Event_Data.SPP_Open_Port_Indication_Data->BD_ADDR, &Connection_Handle);
                if(ret_val)
                   /* Failed to Query the Connection Handle.                */
                   drv_debug_log("GAP_Query_Connection_Handle()Failed\n\r");
                   ret_val           = 0;
                   Connection_Handle = 0;
                drv_debug_log("SPP Connected\n\r" );
                spp_get_remote_name( );
                break;
             case etPort_Open_Confirmation:
                /* A Client Port was opened.  The Status indicates the      */
                /* Status of the Open.                                      */
                drv_debug_log(("\r\n"));
                SprintF(debug_buffer,"SPP Open Confirmation, ID: 0x%04X, Status 0x%04X.\r\n", SPP_Event_Data->Event_Data.SPP_Open_Port_Confirmation_Data->SerialPortID,
        SPP_Event_Data->Event_Data.SPP_Open_Port_Confirmation_Data->PortOpenStatus);
                /* Check the Status to make sure that an error did not      */
                /* occur.                                                   */
                if(SPP_Event_Data->Event_Data.SPP_Open_Port_Confirmation_Data->PortOpenStatus)
                   /* An error occurred while opening the Serial Port so    */
                   /* invalidate the Serial Port ID.                        */
                   SerialPortID      = 0;
                   Connected    = FALSE;
                else
                   /* Flag that we are now connected.                       */
                   Connected = TRUE;
                   _reset_spp_data();
                   /* Query the connection Handle.                          */
                   ret_val = GAP_Query_Connection_Handle(BluetoothStackID, SelectedBD_ADDR, &Connection_Handle);
                   if(ret_val)
                      drv_debug_log("GAP_Query_Connection_Handle()failed \n\r");
                      ret_val           = 0;
                break;
             case etPort_Close_Port_Indication:
                /* The Remote Port was Disconnected.                        */
                SprintF(debug_buffer,"SPP Close Port, ID: 0x%04X\r\n", SPP_Event_Data->Event_Data.SPP_Close_Port_Indication_Data->SerialPortID);
                drv_debug_log("spp client disconnected\n\r");
                //SerialPortID = 0; TODO: tester
                Connected = FALSE;
                _closed_port_indication = TRUE;
                break;
             case etPort_Status_Indication:
                /* Display Information about the new Port Status.           */
                SprintF(debug_buffer,"SPP Port Status Indication: 0x%04X, Status: 0x%04X, Break Status: 0x%04X, Length: 0x%04X.\r\n", SPP_Event_Data->Event_Data.SPP_Port_Status_Indication_Data->SerialPortID,
        SPP_Event_Data->Event_Data.SPP_Port_Status_Indication_Data->PortStatus,
        SPP_Event_Data->Event_Data.SPP_Port_Status_Indication_Data->BreakStatus,
        SPP_Event_Data->Event_Data.SPP_Port_Status_Indication_Data->BreakTimeout);
                break;
             case etPort_Send_Port_Information_Indication:
               /* Simply Respond with the information that was sent to us. */
               drv_debug_log("\r\netPort_Send_Port_Information_Indication\n\r");
               ret_val = SPP_Respond_Port_Information(BluetoothStackID, SPP_Event_Data->Event_Data.SPP_Send_Port_Information_Indication_Data->SerialPortID, &SPP_Event_Data->Event_Data.SPP_Send_Port_Information_Indication_Data->SPPPortInformation);
               break;
          case etPort_Send_Port_Information_Confirmation:
            drv_debug_log("\r\netPort_Send_Port_Information_Confirmation , don't know what I need to do\n\r");
            break;
          case etPort_Query_Port_Information_Indication:
            drv_debug_log("\r\netPort_Query_Port_Information_Indication , don't know what I need to do\n\r");
            break;
          case etPort_Query_Port_Information_Confirmation:
            drv_debug_log("\r\netPort_Query_Port_Information_Confirmation , don't know what I need to do\n\r");
            break;
          case etPort_Open_Request_Indication:
    #if 0
              if( BTPSAPI SPP_Open_Port_Request_Response(BluetoothStackID,
                                                         SerialPortID,
                                                         TRUE))
                drv_debug_log("etPort_Open_Request_Indication , don't know what I need to do\n\r");
    #else
    #endif
            break;
          case etPort_Transmit_Buffer_Empty_Indication:
            break;
             default:
               // An unknown/unexpected SPP event was received.
               drv_debug_log("Unknown Event.\r\n");
               break;
          /* Check the return value of any function that might have been    */
          /* executed in the callback.                                      */
          if(ret_val)
             /* An error occurred, so output an error message.              */
             drv_debug_log("Error \r\n");
       else
          /* There was an error with one or more of the input parameters.   */
          drv_debug_log("Null Event\r\n");
       /* The following function is responsible for processing HCI Mode     */
       /* change events.                                                    */
    static void BTPSAPI HCI_Event_Callback(unsigned int BluetoothStackID, HCI_Event_Data_t *HCI_Event_Data, unsigned long CallbackParameter)
       char *Mode;
       /* Make sure that the input parameters that were passed to us are    */
       /* semi-valid.                                                       */
       if((BluetoothStackID) && (HCI_Event_Data))
          /* Process the Event Data.                                        */
          switch(HCI_Event_Data->Event_Data_Type)
             case etMode_Change_Event:
                if(HCI_Event_Data->Event_Data.HCI_Mode_Change_Event_Data)
                   switch(HCI_Event_Data->Event_Data.HCI_Mode_Change_Event_Data->Current_Mode)
                      case HCI_CURRENT_MODE_HOLD_MODE:
                         Mode = "Hold";
                         break;
                      case HCI_CURRENT_MODE_SNIFF_MODE:
                         Mode = "Sniff";
                         break;
                      case HCI_CURRENT_MODE_PARK_MODE:
                         Mode = "Park";
                         break;
                      case HCI_CURRENT_MODE_ACTIVE_MODE:
                      default:
                         Mode = "Active";
                         break;
    		SprintF(debug_buffer,"HCI Mode Change Event, Status: 0x%02X, Connection Handle: %d, Mode: %s, Interval: %d\r\n", HCI_Event_Data->Event_Data.HCI_Mode_Change_Event_Data->Status,
        HCI_Event_Data->Event_Data.HCI_Mode_Change_Event_Data->Connection_Handle,
        Mode,
        HCI_Event_Data->Event_Data.HCI_Mode_Change_Event_Data->Interval);
                break;
    // The following function is used to initialize the application
    // instance.  This function should open the stack and prepare to
    // execute commands based on user input.  The first parameter passed
    // to this function is the HCI Driver Information that will be used
    // when opening the stack and the second parameter is used to pass
    // parameters to BTPS_Init.  This function returns the
    // BluetoothStackID returned from BSC_Initialize on success or a
    // negative error code (of the form APPLICATION_ERROR_XXX).
    static int _init_bluetooth(HCI_DriverInformation_t *HCI_DriverInformation)
      int ret_val = APPLICATION_ERROR_UNABLE_TO_OPEN_STACK;
      memset((void *)&SerialPortID,0,sizeof(int)*MAX_SPP_PORT);
      // makes sure that the Driver Information passed appears to be
      // semi-valid.
      if((HCI_DriverInformation == NULL))
        return APPLICATION_ERROR_INVALID_PARAMETERS;
      // Try to Open the stack and check if it was successful.
      if(!_open_stack(HCI_DriverInformation))
        ret_val = gap_init( BluetoothStackID );
        if(!ret_val)
              // Attempt to register a HCI Event Callback.
              ret_val = HCI_Register_Event_Callback(BluetoothStackID, HCI_Event_Callback, (unsigned long)NULL);
              if(ret_val > 0)
                // Return success to the caller.
                ret_val = (int)BluetoothStackID;
              else
                drv_debug_log("HCI_Register_Event_Callback() failed\n\r");
        else
          drv_debug_log("\n\rError GAP init\n\r");
        /* In some error occurred then close the stack.                */
        if(ret_val < 0)
          /* Close the Bluetooth Stack.                               */
          _close_stack();
      else
        /* There was an error while attempting to open the Stack.      */
        drv_debug_log("Unable to open the stack.\r\n");
      return(ret_val);
    // This function lauch Serial port profile as server mode.
    // It will open a port and will wait for connection
    int spp_open_stack( void )
      int Result;
      HCI_DriverInformation_t HCI_DriverInformation;
      if( BluetoothStackID == 0)
        // Configure the UART Parameters.
        HCI_DRIVER_SET_COMM_INFORMATION(&HCI_DriverInformation, 1, 115200, cpUART);
        HCI_DriverInformation.DriverInformation.COMMDriverInformation.InitializationDelay = 300;
        // bt configure
        drv_configure_bt_enabled();
        // bt power on
        drv_bt_power_off();
        __delay_cycles(25000000);
        drv_bt_power_on();
        //delay (1 secondes)
        // Initialize the application.
        if((Result = _init_bluetooth(&HCI_DriverInformation)) <= 0)
          return -1;
        // Save the Bluetooth Stack ID.
        BluetoothStackID = (unsigned int)Result;
        // Go ahead an enable HCILL Mode.
        HCILL_Init();
        HCILL_Configure(BluetoothStackID, HCILL_MODE_INACTIVITY_TIMEOUT, HCILL_MODE_RETRANSMIT_TIMEOUT, TRUE);
    #if 1
        SprintF(board_name,"enova_%s", BluetoothAddress);
        spp_set_name( board_name );
    #else
        spp_set_name("enova");
    #endif
        _set_baud_rate( 921600 );
        //_set_baud_rate( 460800 );
        //_set_baud_rate( 230400 );
        //_set_baud_rate( 115200 );
        return BluetoothStackID;
      return -1;
      int ret = 0;
      _closed_port_indication = FALSE;
      main_interface_reset_queue();
    #if 1
      ret = _set_config_params( 50, 300 , 300 );
      if(ret >= 0 )
        drv_debug_log("spp set config succedded...\n\r");
    #endif
      ret = _open_server(comm_port);
      return ret;
    int spp_set_name( char * arg )
      unsigned int len = strlen(arg);
      while(len > 0)
        if(arg[len-1] == '\n')
          arg[len-1] = 0;
        len --;
      return gap_set_local_name( BluetoothStackID, arg );
    int spp_get_remote_name( void )
      if(Connected == TRUE)
        return gap_get_remote_name( BluetoothStackID, remoteConnectedDevice );
      return -1;
    // Base time to delay the machine state
    void spp_base_time_1ms( void )
      if(spp_tempo != 0)
        spp_tempo--;
    // Lauch the machine state
    void spp_init( void )
      if(_spp_state == SPP_UNINIT)
        _spp_state = SPP_OPEN_STACK;
        _need_to_close_stack = 0;
        Connected = 0;
    void spp_stop( void )
        return;
      _need_to_close_stack = 1;
      drv_debug_log("need to close the stack\n\r");
    void spp_task_handler( void * param )
       gap_task_handler( NULL );
      switch(_spp_state)
      case SPP_UNINIT:
        break;
      case SPP_OPEN_STACK:
        if( spp_open_stack() <= 0 )
          main_interface_communication_off();
          drv_debug_log("Open stack failed, return to UNINIT.\n\r");
        else
          _spp_state = SPP_OPEN_PORT;
        if(_need_to_close_stack == 1)
          //Close only the stack.
          _spp_state = SPP_CLOSE_STACK;
        break;
      case SPP_OPEN_PORT:
        if( _start_server( 1 ) >= 0 )
          _spp_state = SPP_IDLE;
          drv_debug_log("Succedded to open spp port\n\r");
          main_interface_communication_on();
        else
          drv_debug_log("\n\rFailed to open spp port\n\r");
        break;
      case SPP_IDLE:
          _spp_state = SPP_CONNECTED;
          drv_gpio_set_connected();
          // Here the stack and the server are opened
          // so we need to close them.
          _spp_state = SPP_TEMPO;
        break;
      case SPP_CONNECTED:
        if( _closed_port_indication == TRUE )
          // Here there is a bug. Sometimes the server is blocked
          // so we need to close the port and restart the server.
          //_spp_state = SPP_TEMPO;
          //spp_tempo = 2000;
        break;
      case SPP_TEMPO:
        if(spp_tempo == 0)
          _spp_state = SPP_CLOSE_SERVER;
        break;
      case SPP_CLOSE_SERVER:
        drv_debug_log("Close port\n\r");
        if(spp_close_server( 1 ) == 0)
          ServerPortID[1] = 0;
          drv_debug_log("Close port succedded\n\r");
        else
          drv_debug_log("Close port failed\n\r");
    #if 0
        if( spp_close_server( 1 ) == 0 )
          ServerPortID = 0;
        }else
    #endif
        break;
      case SPP_CLOSE_STACK:
        drv_debug_log("\n\rShutdown\n\r");
        _close_stack( );
        drv_clock_disable_slow_clock();
        // power down
        drv_bt_power_off();
        // Uninit UART
        // put here
        break;
      if(BluetoothStackID != 0 && SerialPortID != 0)
        SPP_Purge_Buffer( BluetoothStackID, SerialPortID, SPP_PURGE_MASK_TRANSMIT_ABORT_BIT |
                       SPP_PURGE_MASK_RECEIVE_ABORT_BIT);
        SPP_Purge_Buffer( BluetoothStackID, SerialPortID, SPP_PURGE_MASK_TRANSMIT_FLUSH_BIT );
      int delta ;
      unsigned int lenght ;
      __disable_interrupt();
      // if no data in the buffer
      if( backupTxBuffer.push_index == backupTxBuffer.pop_index )
        __enable_interrupt();
        return ;
      // if there is data in the buffer
      if( backupTxBuffer.push_index > backupTxBuffer.pop_index )
        delta = backupTxBuffer.push_index - backupTxBuffer.pop_index;
      else
        delta = MAX_BUFFER_SIZE - backupTxBuffer.pop_index;
      if(delta > 0 )
        lenght = SPP_Data_Write(BluetoothStackID, SerialPortID, delta, &backupTxBuffer.TxSPPBuffer[backupTxBuffer.pop_index]);
        backupTxBuffer.pop_index+= lenght;
        backupTxBuffer.pop_index%=MAX_BUFFER_SIZE;
      else
        while(1);
    #endif
    // return the machine state current state
    enSPP_STATE spp_get_state( void )
      return _spp_state;
    unsigned int spp_send_data( char * ptr_data, unsigned int bytetosend )
      if(BluetoothStackID != 0)
        return SPP_Data_Write(BluetoothStackID, SerialPortID, bytetosend, (Byte_t *)ptr_data);
      else
        return 0;
  • Hi Mikael,
    It sounds like the Link key is not present on your device but Windows has it and so Windows is not initiating a connection to this device. Try deleting the pairing information on Windows and it should work.
    In our sample application we do not store Link key to the flash so it will be lost on power cycle. This may create a case where remote device has it and local device does not. Remote device tries to authenticate and it fails as local device has lost the key. At this time, the behavior of remote device is application dependent. It can delete the link key and try connecting again and that will result in pairing process getting triggered and then the devices will be connected.
    On the local device, the link key-Remote BDADDR combination can be saved to flash and read from it on power up to avoid this.
    Hope this helps,
    Stonestreet One.
  • Hi Stonestreet support,
    I see in SPP demo for MSP430, two API in HCI :  HCI_Delete_Stored_Link_Key and HCI_Write_Stored_Link_Key that are not used in the example.
    Can you give me more information on these API ?
    Are they working on MSP version ? How to use them ?
    How many linkkey it is possible to store ?
    Mikael
  • Hi Mikael
    Those APIs are not used as they offload the link key management to the radio and we recommend that the application should control the link key management as it may happen that the application and radio are not in sync and that may affect user experience. It is better for the radio to ask the application whenever link keys are needed.
    Application can save the link keys/BDaddr pair information to flash and read it on initialization so that the pairing survives power cycles.
    Hope this helps,
    Nikhil
  • Hi stonestreet suport,
    It is very strange.
    When I receive atLinkRequest from Windows 7, if I respond with a null link key, the device send me a notification to enter the PIN code.
    If I respond with the good linkkey, I don't get anything from the GAP ant the connection is in "zombie" state with anymore notification...
    Please help me ....
    Here below my code:
    break;
    else
    break;
  • Mikael
    Can you post a debug log of these two cases?  And also add a debug log to say if you are responding with a link key or if you are responding with a NULL link key?  This will be helpful in tracking this down.
    Tim
