change tx-power and gain settings while connection is open
i want to change the RX-gain and the TX-power via HCI_EXT_SetTxPowerCmd and HCI_EXT_SetRxGainCmd while a connection is active.
Will that work?
Andre
  • Hello Andre,
    Yes you can change the Tx power level when the device is connected using that command.
    You can see an example of this in any of the projects.  It is done in the _HandleKeys() function.
