Where to change the simpleblecentral default connection timeout value?
I use the simpleblecentral and simplebleperipheral to comminicate with each other, but found if I poweroff the central device when it is connected, then power on again and try to find the peripheral again, i should wait about 20S , so is there some setting on central device that i can change to short this time? Thanks!
Chris
