CC2451
Other Parts Discussed in Thread: CC2541
Hi all,
I am going to use CC2451 for an EEG signal to transfer it wireless. My EEG signal is about 1uV, and I need that ADC in the CC2451 to be set as 12 bit. My question is that how I should set the reference voltage and what the range of the reference voltage should be?
Thanks all
  • Hello Hadi,
    I guess you mean CC2541?
    I am not to familiar with the subject, but It depends on the input noise and output impedance of the source of the signal. I think you will need something better as i suspect the signal amplitude might be even less than the input noise. I do not have to much knowledge on the subject, but have a look at a general TI guide:
    ECG and EEG Applications Quick Reference Guide
    Usually you set the reference voltage a little higher than the expected input peak.
