CC2540 FW share
Other Parts Discussed in Thread: CC2540
I've several questions about CC2540 Firmware and sources.
Can I modify firmware and share only its binaries (for example on a public git repository)?
Can I  share firmware sources and modifications I've done on it?
"The License limits your use, and you acknowledge, that the Software may not be modified,
copied or distributed unless embedded on a Texas Instruments microcontroller
or used solely and exclusively in conjunction with a Texas Instruments radio
frequency transceiver, which is integrated into your product."
Indeed, sensor tag FW delivered by TI often changes. Having for example a git repo with different versions would be nice to compare it.
Lahorde
