Does anyone know the power consumption for CC2541 running as an 'observer' role ?
AN092 seems to analyse CC2541 in a 'peripherla' role. Right?
Hi Erez,
You can apply the Application note procedure on a Observer role as well. What you will typically see is the duty cycled RX window that corresponds to the Scan Window / Interval. The Scan Window/Interval can be set by the application and therefore it's a subject to specific use case.
Your question is too generic for me to provide an answer. What is the application?
Best Regards
Joakim
The device i'm building is a battery-powered indicator.
When it receives a command it needs to flash an LED once.
The latency should be minimal, so it needs to scan every 0.1sec
