Hi All,
My application requires me to perform service discovery on remote Android devices. I need to search for remote channel number. I referred to following post and wrote code according to that-
http://e2e.ti.com/support/wireless_connectivity/f/660/p/169706/652369.aspx#652369
But looks like this code is for older version of Bluetopia BTPS kernel, because I could not modify _malloc function as told in the thread, I got errors when I replaced the _malloc function with the function definition given in the thread.
Following is the code I am using for starting service discovery to Android phone.
static void BTPSAPI SDP_EventCallback(
unsigned int BluetoothStackID,
unsigned int SDPRequestID,
SDP_Response_Data_t *SDP_Response_Data,
unsigned long CallbackParameter)
int Index;
int ServerPort;
int RFCOMMPortList[30];
/* First, check to see if the required parameters appear to be */
/* semi-valid. */
if((SDP_Response_Data != NULL) && (BluetoothStackID))
/* The parameters appear to be semi-valid, now check to see what */
/* type the incoming Event is. */
switch(SDP_Response_Data->SDP_Response_Data_Type)
case rdTimeout:
/* A SDP Timeout was received, display a message indicating */
/* this. */
Display(("\r\n"));
Display(("SDP Timeout Received (Size = 0x%04X).\r\n", sizeof(SDP_Response_Data_t)));
break;
case rdConnectionError:
/* A SDP Connection Error was received, display a message */
/* indicating this. */
Display(("\r\n"));
Display(("SDP Connection Error Received (Size = 0x%04X).\r\n", sizeof(SDP_Response_Data_t)));
break;
case rdErrorResponse:
/* A SDP error response was received, display all relevant */
/* information regarding this event. */
Display(("\r\n"));
Display(("SDP Error Response Received (Size = 0x%04X) - Error Code: %d.\r\n", sizeof(SDP_Response_Data_t), SDP_Response_Data->SDP_Response_Data.SDP_Error_Response_Data.Error_Code));
break;
case rdServiceSearchResponse:
/* A SDP Service Search Response was received, display all */
/* relevant information regarding this event */
Display(("\r\n"));
Display(("SDP Service Search Response Received (Size = 0x%04X) - Record Count: %d\r\n", sizeof(SDP_Response_Data_t), SDP_Response_Data->SDP_Response_Data.SDP_Service_Search_Response_Data.Total_Service_Record_Count));
/* First, check to see if any SDP Service Records were */
/* found. */
if(SDP_Response_Data->SDP_Response_Data.SDP_Service_Search_Response_Data.Total_Service_Record_Count)
Display(("Record Handles:\r\n"));
for(Index = 0; (Word_t)Index < SDP_Response_Data->SDP_Response_Data.SDP_Service_Search_Response_Data.Total_Service_Record_Count; Index++)
Display(("Record %u: 0x%08X\r\n", (Index + 1), (unsigned int)SDP_Response_Data->SDP_Response_Data.SDP_Service_Search_Response_Data.Service_Record_List[Index]));
else
Display(("No SDP Service Records Found.\r\n"));
break;
case rdServiceAttributeResponse:
/* A SDP Service Attribute Response was received, display */
/* all relevant information regarding this event */
Display(("\r\n"));
Display(("SDP Service Attribute Response Received (Size = 0x%04X)\r\n", sizeof(SDP_Response_Data_t)));
break;
case rdServiceSearchAttributeResponse:
/* A SDP Service Search Attribute Response was received, */
/* display all relevant information regarding this event */
Display(("\r\n"));
Display(("SDP Service Search Attribute Response Received (Size = 0x%04X)\r\n", sizeof(SDP_Response_Data_t)));
BTPS_MemInitialize(RFCOMMPortList, 0, sizeof(RFCOMMPortList));
/* Call only when you queried for Attribute ID PROTOCOL DESCRIPTOR LIST (0x0004) */
if(ExtractRFCOMMPortNumber(&SDP_Response_Data->SDP_Response_Data.SDP_Service_Search_Attribute_Response_Data, RFCOMMPortList) == 0)
Index = 0;
while(RFCOMMPortList[Index])
Display(("RFCOMM Server Port Found at: %d", RFCOMMPortList[Index]));
Index++;
else
Display(("No RFCOMM Server found"));
break;
default:
/* An unknown/unexpected SDP event was received. */
Display(("\r\n"));
Display(("Unknown SDP Event.\r\n"));
break;
else
/* There was an error with one or more of the input parameters. */
Display(("\r\n"));
Display(("SDP callback data: Response_Data = NULL.\r\n"));
/* The following function is responsible for issuing a Service Search*/
/* Attribute Request to a Remote SDP Server. This function returns */
/* zero if successful and a negative value if an error occurred. */
int
SPPServiceDiscovery(BD_ADDR_t RemoteBDAddr)
int Result;
int ret_val;
int Index;
BD_ADDR_t NullADDR;
SDP_UUID_Entry_t SDPUUIDEntry;
SDP_Attribute_ID_List_Entry_t AttributeID;
ASSIGN_BD_ADDR(NullADDR, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00);
/* First, check that valid Bluetooth Stack ID exists. */
if(g_uiBluetoothStackID)
/* First let's build the UUID 32 value(s). */
SDPUUIDEntry.SDP_Data_Element_Type = deUUID_16;
ASSIGN_UUID_16(SDPUUIDEntry.UUID_Value.UUID_16, 0x11, 0x01);
AttributeID.Attribute_Range = (Boolean_t)FALSE;
AttributeID.Start_Attribute_ID = PROTOCOL_DESCRIPTOR_LIST_ATTR;
AttributeID.End_Attribute_ID = 0;
/* Finally submit the SDP Request. */
Result = SDP_Service_Search_Attribute_Request(g_uiBluetoothStackID,
RemoteBDAddr,
1,
&SDPUUIDEntry,
1,
&AttributeID,
SDP_EventCallback,
(unsigned long)0);
if(Result > 0)
/* The SDP Request was submitted successfully. */
Display(("SDP_Service_Search_Attribute_Request Success.\r\n"));
/* Flag success to the caller. */
ret_val = 0;
else
/* There was an error submitting the SDP Request. */
Display(("SDP_Service_Search_Attribute_Request Failure: %d.\r\n"));
ret_val = 0;
else
/* No valid Bluetooth Stack ID exists. */
ret_val = -1;
return(ret_val);
static int
ExtractRFCOMMPortNumber(SDP_Service_Search_Attribute_Response_Data_t *SDPServiceSearchAttributeResponse, int *RFCOMMPortList)
int NumberOfAttributes;
int NumberOfRecords;
int RFCOMMChannel;
int RetVal=-1;
int Index;
int RecordIndex;
int NumberElements;
int PortCount=0;
UUID_128_t UUID_128;
UUID_128_t RFCOMM_UUID;
SDP_Data_Element_t *SDP_Data_Element;
SDP_Data_Element_t *SDP_Data_Element1;
SDP_ASSIGN_RFCOMM_UUID_128(RFCOMM_UUID);
/* This is a response received when we queried Attribute ID 0x04 */
NumberOfRecords = SDPServiceSearchAttributeResponse->Number_Service_Records;
Display(("Number of Records: %d ", NumberOfRecords));
for(RecordIndex = 0; RecordIndex < NumberOfRecords; RecordIndex++)
NumberOfAttributes = SDPServiceSearchAttributeResponse->SDP_Service_Attribute_Response_Data[RecordIndex].Number_Attribute_Values;
if(NumberOfAttributes)
SDP_Data_Element = SDPServiceSearchAttributeResponse->SDP_Service_Attribute_Response_Data[RecordIndex].SDP_Service_Attribute_Value_Data[0].SDP_Data_Element;
if((SDP_Data_Element->SDP_Data_Element_Type == deSequence) && (SDP_Data_Element->SDP_Data_Element_Length))
/* Data Element Sequence Exists, now */
/* let's loop through the Data Element */
/* Sequence. */
for(Index=0; Index < SDP_Data_Element->SDP_Data_Element_Length;Index++)
if(((SDP_Data_Element1 = &(SDP_Data_Element->SDP_Data_Element.SDP_Data_Element_Sequence[Index])) != NULL) && (SDP_Data_Element1->SDP_Data_Element_Type == deSequence) && ((NumberElements = SDP_Data_Element1->SDP_Data_Element_Length) > 0) && ((SDP_Data_Element1 = SDP_Data_Element1->SDP_Data_Element.SDP_Data_Element_Sequence) != NULL))
if((SDP_Data_Element1->SDP_Data_Element_Type == deUUID_16) || (SDP_Data_Element1->SDP_Data_Element_Type == deUUID_32) || (SDP_Data_Element1->SDP_Data_Element_Type == deUUID_128))
/* Initialize the BASE UUID. */
SDP_ASSIGN_BASE_UUID(UUID_128);
switch(SDP_Data_Element1->SDP_Data_Element_Type)
case deUUID_16:
/* First normal-lize the*/
/* 16 Bit UUID to 128 */
/* Bits. */
ASSIGN_UUID_16_TO_UUID_128(UUID_128, SDP_Data_Element1->SDP_Data_Element.UUID_16);
break;
case deUUID_32:
/* 32 Bit UUID to 128 */
/* Bits. */
ASSIGN_UUID_32_TO_UUID_128(UUID_128, SDP_Data_Element1->SDP_Data_Element.UUID_32);
break;
case deUUID_128:
/* Simply assign the */
/* 128 Bit UUID to the */
/* UUID value. */
UUID_128 = SDP_Data_Element1->SDP_Data_Element.UUID_128;
break;
/* Now let's check to see if */
/* there is a match to RFCOMM */
if((COMPARE_UUID_128(RFCOMM_UUID, UUID_128)) && (NumberElements > 1))
if(SDP_Data_Element1[1].SDP_Data_Element_Type == deUnsignedInteger1Byte)
RFCOMMChannel = SDP_Data_Element1[1].SDP_Data_Element.UnsignedInteger1Byte;
/* Add server port to return data */
RFCOMMPortList[PortCount] = RFCOMMChannel;
PortCount++;
RetVal = 0;
else
/* Some unknown Protocol */
/* Descriptor, so just ignore */
/* it. */
return(RetVal);
The code is same as mentioned in the thread following is the log I am getting -
3SDP_Service_Search_Attribute_Request Success.
HCI Role Change Event
HCI Connection complete event:
Remote BD_ADDR:cc:c3:ea:54:ca:be
HCI Read_Remote_Extended_Features_Complete_Event:3
HCI Number of completed packets Event
HCI Number of completed packets EventNO SEGMENT FOUND.
Alloc Failed: 44
INVALID POINTER
SDP Service Search Attribute Response Received (Size = 0x000A)
Number of Records: 0 No RFCOMM Server found
My diagnosis is that the memory allocation is failing some where, does any one have a fix for this?
I have one more doubt about SDP_Service_Search_Attribute_Request API-
Can we use 128 bit UUID instead of UUID16?
Thanks in advance,
Sharadanand Karanjkar
