Red light is always on (cc2540 mini keyfob)
Other Parts Discussed in Thread: CC2540
Hello
There is a problem when I insert bettery to cc2540 keyfob
when I input the bettery to keyfob , the red light on keyfob is always on and  smart flash programmer doesn't recognize it.
It was connected to debugger at first successfully and work correctly, but It happened after I plugged out cc debugger with keyfob on erase process.
Is there any solution or reset keyfob to solve this problem?
please reply
Thank you
  • Hi Donghyun,
    Looks like the firmware did not program successfully when you unplugged it during erase. You will always be able to recover the functionality using the CCDebugger to program it. Make sure you have a good battery connected when you plug in the CCDebugger.
    Peder
