Btool connection after it is cut without permission
Genius 5960 points
Other Parts Discussed in Thread: CC2541, CC2540
I am using KeyFob and CC2541 USB dongle.
From the power supply and ground to an external serial driver for the soldered pin header
We pull out the line.
However, it will be disconnected automatically after only two or three times lead after connecting to the btool.
Please tell me if there is a point to be worried about.
Best Regards
hamada
  • Hello. You mean CC2540 USB dongle, correct?
    Can you please explain in more detail what it is you are doing?  How have you modified the hardware? What line are you referring to?
    What software have you loaded on the dongle?
    A sniffer capture would also be helpful.
    Best wishes,
    Tim
