Attributes Long value
I want to write a uint8[4] Array in my Attributes, but when i want to write it with btool, then i receive the following error Message: "Writing attributes of length gt 2 not implemented". How can i implementing it?
I use the SensorTag.
  • Hello Brian,
    If you are using the SensorTag project, then you can look at the accelerometer profile.  It sends 3 data bytes.  The length of data is specified as 3.   Using this as a guide, you can change your attribute to 4.
