CC2564MODNCMOET - Certification
Other Parts Discussed in Thread: CC2564
Hello CC2564 team,
I am using the CC2564MODNCMOET and had a question regarding certification.  We are seeking a pre-certified solution, but this would only be pre-certified if the antenna is exactly as on the reference design. However, we would like to just have an SMA connector on the board and then use standard external SMA antennas.  Is it possible to do this and still be certified (or get certified with relatively less testing)?
Another issue is that the antenna does not seem to be easily available in small quantities. Would we be able to order the antenna in small quantities?
Alyssa Chatten
