Can the CC2541 Keyfob be purchased without the developer kit. A $100 beacon is going to be a tough sell.
Bob Roth
Bob Roth
Swap out the profiles and change the GPIOs associated with the buttons. The sensors are disabled by default. You could leave out the services that enable them. Unless the buzzer is important to you, the products should be interchangeable.
That's the saltiest thing I've read all day. I'm not a TI employee.
How about you go back to blinking LEDs on Arduino n00b.
Peter,
Thanks for the insight. The project is running and is back on track.
As for Melissa, Hey this ain't Facebook!! Although I understand your frustration with customer support, it is a industry wide problem. It is not just Ti.
When you work at this level you may as well get used to being on your own. Grab the schematic and dig into the code.
That's why this forum is such an important resource. We are all pulling together and supporting one another. It is our Community. We all have the same goal here; to create exciting products that hopefully will make a buck.
Once again, thank you Peter for all your help.
Bob Roth
