Other Parts Discussed in Thread: CC2541
I dont understand the Image A and Image B concept. what is extended image for these images? can you guys explain me? because im not getting these concepts... thanks in advance...
Thank you for your reply. I read that document. what is “OAD-only Image" refers to, in section 8.2. In the Figure 2: OAD Target Context Diagram using the BIM what is Image A part 2 banked code represents. I am confused in these two lines. and what happens if both image does not fit into the flash memory(mine is 256kb, cc2541). this documment is for oad right? is there any separate document for dual image loading through BIM. please explain me these things.thank you...
