Hello everyone, I'm building a standalone prototype with the CC2640 and I've seen the datasheets in the ti.com web but I'm a bit confused, I don't know wich schematic use.
The application I'm building is about a push button: when you press down the push, a signal with data will be sent to a smartphone and a LED will turn on in the board, when you release the push, an other signal with data will be sent to the smartphone and a LED will turn off in the board. This application is very simple, so, if anyone can tellme which schematic I can use I will appreciate very much.
