Error while compiling sample codes for cc256xqfnem on keil 4.72.0.0
Other Parts Discussed in Thread: CODECOMPOSER
hi,
I am trying to compile the spp.demo sample code in keil and getting the following errors " L6002U: Could not open file driverlib.lib". Please help me in dealing with
this error.
Thank you.
My output:
Build target 'SPP (DK-TM4C123G) Debug Target
Before Build - User command #1: ..\..\..\..\BuildScripts\SetTivaWarePath.bat
C:\ti\Connectivity\CC256X BT\CC256x M4 Bluetopia SDK\v1.2 R2\Cortex_M4\Sample\SPPDemo\NoOS\RVMDK>if NOT ! == ! GOTO TIVAWARE_PATH_DEFINED
C:\ti\Connectivity\CC256X BT\CC256x M4 Bluetopia SDK\v1.2 R2\Cortex_M4\Sample\SPPDemo\NoOS\RVMDK>set TIVAWARE_PATH=C:\ti\TivaWare_C_Series-2.1.0.12573
C:\ti\Connectivity\CC256X BT\CC256x M4 Bluetopia SDK\v1.2 R2\Cortex_M4\Sample\SPPDemo\NoOS\RVMDK>set HOME_PATH=.
C:\ti\Connectivity\CC256X BT\CC256x M4 Bluetopia SDK\v1.2 R2\Cortex_M4\Sample\SPPDemo\NoOS\RVMDK>IF ! == ! GOTO :CHECK_PATH
C:\ti\Connectivity\CC256X BT\CC256x M4 Bluetopia SDK\v1.2 R2\Cortex_M4\Sample\SPPDemo\NoOS\RVMDK>set SCRIPT_PATH=.\..\..\..\..\
C:\ti\Connectivity\CC256X BT\CC256x M4 Bluetopia SDK\v1.2 R2\Cortex_M4\Sample\SPPDemo\NoOS\RVMDK>IF EXIST .\..\..\..\..\\BuildScripts GOTO :SCRIPT_PATH_EXISTS
C:\ti\Connectivity\CC256X BT\CC256x M4 Bluetopia SDK\v1.2 R2\Cortex_M4\Sample\SPPDemo\NoOS\RVMDK>echo -IC:\ti\TivaWare_C_Series-2.1.0.12573 1>.\..\..\..\..\\BuildScripts\TivaWarePath_DK_TM4C123G_RVMDK.txt
C:\ti\Connectivity\CC256X BT\CC256x M4 Bluetopia SDK\v1.2 R2\Cortex_M4\Sample\SPPDemo\NoOS\RVMDK>echo -IC:\ti\TivaWare_C_Series-2.1.0.12573\third_party 1>>.\..\..\..\..\\BuildScripts\TivaWarePath_DK_TM4C123G_RVMDK.txt
C:\ti\Connectivity\CC256X BT\CC256x M4 Bluetopia SDK\v1.2 R2\Cortex_M4\Sample\SPPDemo\NoOS\RVMDK>echo -IC:\ti\TivaWare_C_Series-2.1.0.12573\examples\board\dk-tm4c123g 1>>.\..\..\..\..\\BuildScripts\TivaWarePath_DK_TM4C123G_RVMDK.txt
C:\ti\Connectivity\CC256X BT\CC256x M4 Bluetopia SDK\v1.2 R2\Cortex_M4\Sample\SPPDemo\NoOS\RVMDK>echo --userlibpath=C:\ti\TivaWare_C_Series-2.1.0.12573\driverlib\rvmdk 1>.\..\..\..\..\\BuildScripts\TivaWarePath_DK_TM4C123G_LD_RVMDK.txt
C:\ti\Connectivity\CC256X BT\CC256x M4 Bluetopia SDK\v1.2 R2\Cortex_M4\Sample\SPPDemo\NoOS\RVMDK>echo --userlibpath=C:\ti\TivaWare_C_Series-2.1.0.12573\grlib\rvmdk 1>>.\..\..\..\..\\BuildScripts\TivaWarePath_DK_TM4C123G_LD_RVMDK.txt
C:\ti\Connectivity\CC256X BT\CC256x M4 Bluetopia SDK\v1.2 R2\Cortex_M4\Sample\SPPDemo\NoOS\RVMDK>echo -IC:\ti\TivaWare_C_Series-2.1.0.12573 1>.\..\..\..\..\\BuildScripts\TivaWarePath_DK_TM4C129X_RVMDK.txt
C:\ti\Connectivity\CC256X BT\CC256x M4 Bluetopia SDK\v1.2 R2\Cortex_M4\Sample\SPPDemo\NoOS\RVMDK>echo -IC:\ti\TivaWare_C_Series-2.1.0.12573\third_party 1>>.\..\..\..\..\\BuildScripts\TivaWarePath_DK_TM4C129X_RVMDK.txt
C:\ti\Connectivity\CC256X BT\CC256x M4 Bluetopia SDK\v1.2 R2\Cortex_M4\Sample\SPPDemo\NoOS\RVMDK>echo -IC:\ti\TivaWare_C_Series-2.1.0.12573\examples\boards\dk-tm4c129x 1>>.\..\..\..\..\\BuildScripts\TivaWarePath_DK_TM4C129X_RVMDK.txt
C:\ti\Connectivity\CC256X BT\CC256x M4 Bluetopia SDK\v1.2 R2\Cortex_M4\Sample\SPPDemo\NoOS\RVMDK>echo --userlibpath=C:\ti\TivaWare_C_Series-2.1.0.12573\driverlib\rvmdk 1>.\..\..\..\..\\BuildScripts\TivaWarePath_DK_TM4C129X_LD_RVMDK.txt
C:\ti\Connectivity\CC256X BT\CC256x M4 Bluetopia SDK\v1.2 R2\Cortex_M4\Sample\SPPDemo\NoOS\RVMDK>echo --userlibpath=C:\ti\TivaWare_C_Series-2.1.0.12573\grlib\rvmdk 1>>.\..\..\..\..\\BuildScripts\TivaWarePath_DK_TM4C129X_LD_RVMDK.txt
C:\ti\Connectivity\CC256X BT\CC256x M4 Bluetopia SDK\v1.2 R2\Cortex_M4\Sample\SPPDemo\NoOS\RVMDK>echo -IC:\ti\TivaWare_C_Series-2.1.0.12573 1>.\..\..\..\..\\BuildScripts\TivaWarePath_DK_TM4C123G_EWARM.txt
C:\ti\Connectivity\CC256X BT\CC256x M4 Bluetopia SDK\v1.2 R2\Cortex_M4\Sample\SPPDemo\NoOS\RVMDK>echo -IC:\ti\TivaWare_C_Series-2.1.0.12573\third_party 1>>.\..\..\..\..\\BuildScripts\TivaWarePath_DK_TM4C123G_EWARM.txt
C:\ti\Connectivity\CC256X BT\CC256x M4 Bluetopia SDK\v1.2 R2\Cortex_M4\Sample\SPPDemo\NoOS\RVMDK>echo -IC:\ti\TivaWare_C_Series-2.1.0.12573\examples\board\dk-tm4c123g 1>>.\..\..\..\..\\BuildScripts\TivaWarePath_DK_TM4C123G_EWARM.txt
C:\ti\Connectivity\CC256X BT\CC256x M4 Bluetopia SDK\v1.2 R2\Cortex_M4\Sample\SPPDemo\NoOS\RVMDK>echo --search C:\ti\TivaWare_C_Series-2.1.0.12573\driverlib\ewarm\exe 1>.\..\..\..\..\\BuildScripts\TivaWarePath_DK_TM4C123G_LD_EWARM.txt
C:\ti\Connectivity\CC256X BT\CC256x M4 Bluetopia SDK\v1.2 R2\Cortex_M4\Sample\SPPDemo\NoOS\RVMDK>echo --search C:\ti\TivaWare_C_Series-2.1.0.12573\grlib\ewarm\exe 1>>.\..\..\..\..\\BuildScripts\TivaWarePath_DK_TM4C123G_LD_EWARM.txt
C:\ti\Connectivity\CC256X BT\CC256x M4 Bluetopia SDK\v1.2 R2\Cortex_M4\Sample\SPPDemo\NoOS\RVMDK>echo -IC:\ti\TivaWare_C_Series-2.1.0.12573 1>.\..\..\..\..\\BuildScripts\TivaWarePath_DK_TM4C129X_EWARM.txt
C:\ti\Connectivity\CC256X BT\CC256x M4 Bluetopia SDK\v1.2 R2\Cortex_M4\Sample\SPPDemo\NoOS\RVMDK>echo -IC:\ti\TivaWare_C_Series-2.1.0.12573\third_party 1>>.\..\..\..\..\\BuildScripts\TivaWarePath_DK_TM4C129X_EWARM.txt
C:\ti\Connectivity\CC256X BT\CC256x M4 Bluetopia SDK\v1.2 R2\Cortex_M4\Sample\SPPDemo\NoOS\RVMDK>echo -IC:\ti\TivaWare_C_Series-2.1.0.12573\examples\boards\dk-tm4c129x 1>>.\..\..\..\..\\BuildScripts\TivaWarePath_DK_TM4C129X_EWARM.txt
C:\ti\Connectivity\CC256X BT\CC256x M4 Bluetopia SDK\v1.2 R2\Cortex_M4\Sample\SPPDemo\NoOS\RVMDK>echo --search C:\ti\TivaWare_C_Series-2.1.0.12573\driverlib\ewarm\exe 1>.\..\..\..\..\\BuildScripts\TivaWarePath_DK_TM4C129X_LD_EWARM.txt
C:\ti\Connectivity\CC256X BT\CC256x M4 Bluetopia SDK\v1.2 R2\Cortex_M4\Sample\SPPDemo\NoOS\RVMDK>echo --search C:\ti\TivaWare_C_Series-2.1.0.12573\grlib\ewarm\exe 1>>.\..\..\..\..\\BuildScripts\TivaWarePath_DK_TM4C129X_LD_EWARM.txt
C:\ti\Connectivity\CC256X BT\CC256x M4 Bluetopia SDK\v1.2 R2\Cortex_M4\Sample\SPPDemo\NoOS\RVMDK>echo -IC:\ti\TivaWare_C_Series-2.1.0.12573 1>.\..\..\..\..\\BuildScripts\TivaWarePath_DK_TM4C123G_CCS.txt
C:\ti\Connectivity\CC256X BT\CC256x M4 Bluetopia SDK\v1.2 R2\Cortex_M4\Sample\SPPDemo\NoOS\RVMDK>echo -IC:\ti\TivaWare_C_Series-2.1.0.12573/third_party 1>>.\..\..\..\..\\BuildScripts\TivaWarePath_DK_TM4C123G_CCS.txt
C:\ti\Connectivity\CC256X BT\CC256x M4 Bluetopia SDK\v1.2 R2\Cortex_M4\Sample\SPPDemo\NoOS\RVMDK>echo -IC:\ti\TivaWare_C_Series-2.1.0.12573/examples/boards/dk-tm4c123g 1>>.\..\..\..\..\\BuildScripts\TivaWarePath_DK_TM4C123G_CCS.txt
C:\ti\Connectivity\CC256X BT\CC256x M4 Bluetopia SDK\v1.2 R2\Cortex_M4\Sample\SPPDemo\NoOS\RVMDK>echo -iC:\ti\TivaWare_C_Series-2.1.0.12573\driverlib\ccs\Debug 1>>.\..\..\..\..\\BuildScripts\TivaWarePath_DK_TM4C123G_CCS.txt
C:\ti\Connectivity\CC256X BT\CC256x M4 Bluetopia SDK\v1.2 R2\Cortex_M4\Sample\SPPDemo\NoOS\RVMDK>echo -iC:\ti\TivaWare_C_Series-2.1.0.12573\grlib\ccs\Debug 1>>.\..\..\..\..\\BuildScripts\TivaWarePath_DK_TM4C123G_CCS.txt
C:\ti\Connectivity\CC256X BT\CC256x M4 Bluetopia SDK\v1.2 R2\Cortex_M4\Sample\SPPDemo\NoOS\RVMDK>echo -IC:\ti\TivaWare_C_Series-2.1.0.12573 1>.\..\..\..\..\\BuildScripts\TivaWarePath_DK_TM4C129X_CCS.txt
C:\ti\Connectivity\CC256X BT\CC256x M4 Bluetopia SDK\v1.2 R2\Cortex_M4\Sample\SPPDemo\NoOS\RVMDK>echo -IC:\ti\TivaWare_C_Series-2.1.0.12573/third_party 1>>.\..\..\..\..\\BuildScripts\TivaWarePath_DK_TM4C129X_CCS.txt
C:\ti\Connectivity\CC256X BT\CC256x M4 Bluetopia SDK\v1.2 R2\Cortex_M4\Sample\SPPDemo\NoOS\RVMDK>echo -IC:\ti\TivaWare_C_Series-2.1.0.12573/examples/boards/dk-tm4c129x 1>>.\..\..\..\..\\BuildScripts\TivaWarePath_DK_TM4C129X_CCS.txt
C:\ti\Connectivity\CC256X BT\CC256x M4 Bluetopia SDK\v1.2 R2\Cortex_M4\Sample\SPPDemo\NoOS\RVMDK>echo -iC:\ti\TivaWare_C_Series-2.1.0.12573\driverlib\ccs\Debug 1>>.\..\..\..\..\\BuildScripts\TivaWarePath_DK_TM4C129X_CCS.txt
C:\ti\Connectivity\CC256X BT\CC256x M4 Bluetopia SDK\v1.2 R2\Cortex_M4\Sample\SPPDemo\NoOS\RVMDK>echo -iC:\ti\TivaWare_C_Series-2.1.0.12573\grlib\ccs\Debug 1>>.\..\..\..\..\\BuildScripts\TivaWarePath_DK_TM4C129X_CCS.txt
linking...
.\Debug - DK-TM4C123G\SPPDemo.axf: error: L6002U: Could not open file driverlib.lib: No such file or directory
".\Debug - DK-TM4C123G\SPPDemo.axf" - 1 Errors, 0 Warning(s).
Target not created
