OAD not loading new Image
I'm currently working on getting OAD to work with the simple peripheral project using the instructions http://processors.wiki.ti.com/images/8/82/OAD_for_CC254x.pdf
I have successfully loaded the bim and images, created the .bin and have transferred it to the OAD manager. Upon connecting to the peripheral the master device finds the OAD chars but dose not start to transfer the new image over.  I have double checked that the bin I am uploading to the manger is for a high version.
Any suggestions on what I might be missed or ways to debug this would be appreciated.
Thank you!
  • Hi Ansgar,
    Did you confirm with a BLE sniffer trace? Did you make any modifications to the default example project?
    Best wishes
  • I figured out my issue. Basically for some strange reason updating the OAD_IMAGE_VERSION number didn't actually update it. After removing the #ifdef around it I was able to get the image version to update.
    While this allowed me to do OAD I'm getting a warning for incompatible definition of macro OAD_IMAGE_VERSION. After a little bit of hunting around I can't find out what is trigger this. Any suggestions on a solution would be appreciated.
